EmuTOS 1.0
Rustynutt
Re: EmuTOS 1.0
Post by Rustynutt »
joska wrote: Sun Sep 06, 2020 9:00 am
Rustynutt wrote: Sat Sep 05, 2020 6:40 pm Was thinking of a way to get the Falcon hardware up without reading the 4.04 ROM at power up, then allowing the tool kit to start, read TOS into RAM, patch and soft reboot. As long as somewhere in that sequence, the Falcon doesn't go looking for a bootable cartridge ROM.
You could put a stock EmuTOS on cartridge (or even in ROM) and have it loading a patched TOS-image from the auto-folder. It is also possible to put a compressed image of an AB-aware TOS in ROM together with a small loader, that sets up the AB (caches, fast-RAM), unpacks the TOS to fast-RAM and then boots. Then you wouldn't have to boot twice, of the more annoying "features" of the AB :)
Yup, all discussed long ago, but being dusted off :D
Have a few ROM to burn, never picked up the burner to do the job.
Writing a loader is way beyond me. Do know how to capture everything to burn into a ROM from memory. As the configuration never changes, and the ROM can always be replaced, makes most sense to me.
But, need to test the adapter on the AB first, if there is something programmed into the MACH chips that is the issue, back to "just" being an 040 machine.
Using EmuTOS to get the hardware up, if it works, then load a patched TOS captured from memory (I use BSS Debug for this) if AB tools recognizes TOS2ROM before it launches....hell have a mess here.
Rustynutt
Re: EmuTOS 1.0
Post by Rustynutt »
The current hold up, aside from everything else being a hold up, is my original AB with socket mounted cpu is down. AIRC, was toying with the clock distribution IC, replacing it with the tighter controlled 060 version some years ago. The 2nd AB has the cpu soldered in. It works, but useless for these test.
Re: EmuTOS 1.0
Post by Eero Tamminen »
stormy wrote: Sat Sep 05, 2020 10:08 am Does the Falcon DSP work with EmuTOS? (on real hardware)
EmuTOS doesn't implement any of the DSP related (XBios) OS calls. Therefore any application using DSP through them will fail, which is (almost) everything that has support for DSP, and no option for disabling that DSP support. Some Falcon demo programming DSP directly through HW registers (without DSP OS calls) should work though.
Hatari documentation on EmuTOS compatibility includes some notes about this in its Falcon section:
https://hatari.tuxfamily.org/doc/emutos.txt
anodyne
Re: EmuTOS 1.0
Post by anodyne »
EmuTOS does not (yet) support any XBIOS DSP calls. So if a DSP application uses the XBIOS to set up the DSP (which I assume most would), it wouldn't (yet) run under EmuTOS. Of course, if it just accesses the hardware directly, EmuTOS doesn't stand in its way :-).
(Later) Just saw that Eero had already answered this ...
Re: EmuTOS 1.0
Post by Cyprian »
Well done EmuTOS Team!
Below you can find figures from NVDI's GEM_TEST.PRG:
Base machine was clean (no NVDI installed!) 1MB STE with TOS 1.62:
http://260ste.atari.org
ThorstenOtto
Re: EmuTOS 1.0
Post by ThorstenOtto »
Strange results, partly. Why are inquire functions slower with blitter enabled? They should not be affected by blitter setting at all. And why is AES object draw almost identical, which involves a lot of line drawing and rectangle fills?
Re: EmuTOS 1.0
Post by ijor »
Congratulations to the team with this release. Well done!
davemacblack
Re: EmuTOS 1.0
Post by davemacblack »
Thank you for your hard work and congratulations on achieving this important moment!
Do you already have an idea of the direction of further development?
Re: EmuTOS 1.0
davemacblack wrote: Mon Sep 07, 2020 1:43 pm Thank you for your hard work and congratulations on achieving this important moment!
I'm not part of EmuTOS devel team, but there are still few large things missing for TOS v3 & v4 compatibility:
* Falcon 16-bit HiColor mode support for XBios mode setting, and in all VDI drawing functions
* 32 Dsp_* XBios functions + DSP support for 8 XBios sounds functions
* TOS v4 AES 3D look (objc_sysvar)
* TOS v3 AES menu functions
* RSC file color icon support
Most likely these will be available only in the 512k version of EmuTOS. For GEM applications last one is most important, for Falcon games & demos, probably the DSP support.
ThorstenOtto
Re: EmuTOS 1.0
The only thing i know of which is missing from TOS 3.x are wind_get/set(WF_DCOLOR). But since there is no way on TOS 3.x (without appl_getinfo) to detect its presence, i doubt that any program except its CPX module is using it. All other functionality is from TOS 4.x, and EmuTOS does not claim to be compatible with that yet.
Re: EmuTOS 1.0
At end of EmuTOS status.txt: https://raw.githubusercontent.com/emuto ... status.txt
Following is listed:
AES v3.30 (TOS > v3.06):
 -      menu_attach
 -      menu_istart
 -      menu_popup
 -      menu_settings
ThorstenOtto
Re: EmuTOS 1.0
Yes, > does not mean >= ;) Those calls were not implemented before 4.01, and have not been part of TT TOS 3.06 (which is AES v3.20)
Re: EmuTOS 1.0
I see (now, I'm blaming my deteriorating eye-sight). So, only some (a huge amount of) TOS v4 functionality is missing.
anodyne
Re: EmuTOS 1.0
Post by anodyne »
The EmuTOS developers are pleased to announce the release of EmuTOS 1.0.1.
This is a release to fix a serious bug which fortunately can only affect a very small set of users. The bug (and the bug fix) only applies if ALL the following are true:
- you are running on real Falcon hardware
- you have 4MB of ST-RAM installed
- you are booting with EmuTOS in ROM.
In this situation, EmuTOS will fail to boot. No other combination of hardware or software is affected, and there are no other changes to EmuTOS, so only users who plan to use the above hardware combination need to upgrade. Other users of EmuTOS 1.0 can upgrade if they wish, of course, but there is no benefit in doing so.
You can download your preferred binary archive here:
https://sourceforge.net/projects/emutos ... tos/1.0.1/
