DIY MD/SMS/Atari/C= to USB adapter
Re: DIY MD/SMS/Atari/C= to USB adapter
Post by Sorgelig »
You can't delete field. Just make it empty (several space symbols) - it's enough.
witchmaster
Post by witchmaster »
Sorgelig wrote:You can't delete field. Just make it empty (several space symbols) - it's enough.
I made progress with the two controller adapter today but still having problems. I managed to create two separate usb interfaces on the same Arduino for the two adapter ports. The serial number is four spaces.
EDIT: It works now, solution in the next post.
In Windows it just works and it also works in Ubuntu 16.04 without the need of any usbhid quirks. I tested with jstest-gdk and the two adapter ports are seen as two separate controllers and the inputs are not combined.
On MiSTer, two input devices (with js0 and js1) are created when I plug in the adapter without any usbhid quirks applied, but still, the inputs are combined. Controllers in both adapter ports controls the same player. The console output for the two controllers are a little different, there is a number after the vid:pid, so the inputs are to some extent separated, but jnum is the same for both:
// First controller:
Input event: type=EV_ABS, Axis=1, Offset=1, jnum=1, ID:2341:8036:00, abs_min = -1, abs_max = 1
// Second controller:
Input event: type=EV_ABS, Axis=1, Offset=0, jnum=1, ID:2341:8036:01, abs_min = -1, abs_max = 1
This is the console output when connecting the two controller adapter:
Open up to 30 input devices.
opened 0( 0): /dev/input/event0 (046d:4024) 0 "4024-68-5b-8d-7a" "Logitech K400"
opened 1( 0): /dev/input/mouse0 (046d:4024) 0 "4024-68-5b-8d-7a" "Logitech K400"
[  378.831721] usb 1-1.2: new full-speed USB device number 5 using dwc2
[  378.936742] usb 1-1.2: New USB device found, idVendor=2341, idProduct=8036, bcdDevice= 1.00
[  378.945112] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  378.952441] usb 1-1.2: Product: Arduino Leonardo
[  378.957079] usb 1-1.2: Manufacturer: Arduino LLC
[  378.961720] usb 1-1.2: SerialNumber:
[  378.975755] HID usage: 0x00010004, original interval: 1
[  378.981028] JS: endpoint->bInterval=1, interval=1
[  378.985751] HID usage: 0x00010004, applied interval: 1
[  378.991133] input: Arduino LLC Arduino Leonardo as /devices/platform/soc/ffb40000.usb/usb1/1-1/1-1.2/1-1.2:1.2/0003:2341:8036.0007/input/input6
The file js0 was created.
[  379.005543] hid-generic 0003:2341:8036.0007: input,hidraw2: USB HID v1.01 Joystick [Arduino LLC Arduino Leonardo] on usb-ffb40000.usb-1.2/input2
Close all devices.
[  379.026758] HID usage: 0x00010004, original interval: 1
[  379.032023] JS: endpoint->bInterval=1, interval=1
[  379.036747] HID usage: 0x00010004, applied interval: 1
[  379.042161] input: Arduino LLC Arduino Leonardo as /devices/platform/soc/ffb40000.usb/usb1/1-1/1-1.2/1-1.2:1.3/0003:2341:8036.0008/input/input7
[  379.055946] hid-generic 0003:2341:8036.0008: input,hidraw3: USB HID v1.01 Joystick [Arduino LLC Arduino Leonardo] on usb-ffb40000.usb-1.2/input3
opened 0( 0): /dev/input/event3 (2341:8036) 0 "    " "Arduino LLC Arduino Leonardo"
opened 1( 0): /dev/input/event2 (2341:8036) 0 "    " "Arduino LLC Arduino Leonardo"
opened 2( 2): /dev/input/event0 (046d:4024) 0 "4024-68-5b-8d-7a" "Logitech K400"
opened 3( 2): /dev/input/mouse0 (046d:4024) 0 "4024-68-5b-8d-7a" "Logitech K400"
The file event2 was created.
The file js1 was created.
The file event3 was created.
Close all devices.
witchmaster
I now have it working (thanks to bootsector on Discord)! The serial number field is now totally empty and then it works. At least from my initial testing in the Minimig core.
Post by Sorgelig »
Wonderful!
Post by Sorgelig »
Will you publish dual joystick project?
I have Atari paddles, so i want to make a converter.
witchmaster
Sorgelig wrote:Will you publish dual joystick project?
Yes, I will publish it later today!
witchmaster
Ok, I published it (same repository as the single controller adapter)!
Post by Sorgelig »
thanks!
Post by Sorgelig »
Is there any changes in system libraries required?
witchmaster
Sorgelig wrote:Is there any changes in system libraries required?
Shouldn't be, as before I'm only using the HID library that comes with the Arduino IDE. But to clear the serial number I did the small change in USBDesc.h:
#define ISERIAL         3
// to
#define ISERIAL         0
Post by Sorgelig »
it's better to add it in Readme so this info won't get lost.
witchmaster
Sorgelig wrote:it's better to add it in Readme so this info won't get lost.
Yes, I will add some more details to the Readme.
Post by Sorgelig »
Would be good if you would move/fork this repo to MiSTer-devel. I plan to add more converters for other controllers based on your code to the same repo. So we will have official DIY converters for MiSTer.
witchmaster
Sorgelig wrote:Would be good if you would move/fork this repo to MiSTer-devel. I plan to add more converters for other controllers based on your code to the same repo. So we will have official DIY converters for MiSTer.
Yes, I will do some cleanup and then we can fork the repo. I can manage the project on MiSTer-devel right? I have a few other adapter basically ready and NES and SNES in the making.
Post by Sorgelig »
I've sent invitation on github to MiSTer-devel. After accepting it, you will be able to create the repositories in MiSTer-devel
witchmaster
Sorgelig wrote:I've sent invitation on github to MiSTer-devel. After accepting it, you will be able to create the repositories in MiSTer-devel
Thanks! As you probably already noticed, I forked the repository. I don't know if you already started working on the Atari paddle controller adapter but here is the "pinout" I have used for Atari/C= controllers in another project and I used the same for the CD32/C=/Amiga adapter. I guess it's best if we use the same pinout for all the adapters using the Atari standard. A0-A4 are used for pins 5 and 9 of both ports so they can support paddles. I might change to this pinout for the Mega Drive adapter also, I'm not sure though.
// Joystick Port 1
// DB9    Arduino Pro Micro
//  1     TXO  PD3
//  2     RXI  PD2
//  3     3    PD0
//  4     4    PD4
//  5     A0   PF7
//  6     6    PD7
//  7     VCC
//  8     GND
//  9     A1   PF6
// Joystick Port 2
//  1     15   PB1
//  2     14   PB3
//  3     16   PB2
//  4     10   PB6
//  5     A2   PF5
//  6     7    PE6
//  7     VCC
//  8     GND
//  9     A3   PF4
Post by Sorgelig »
I was busy by cores, so didn't start yet.
From your post i see only one Analog input per port which is not enough. Need 2 analog pins per port
Actually i wanted to make a single port adapter with option to emulate a single joystick with paddles on X/Y and 2 joysticks - one per paddle for better compatibility. So basically one port should be enough for paddles.
I'm not really interesting in adapters for generic controllers as i think modern native USB/BT gamepads can do the job better. So i'm more interested in non-standard controllers like paddles, spinners - they aren't popular in modern gamepads.
So it's more up to you what converter for standard retro gamepad to develop.
Post by Sorgelig »
I think Wiki page would be good, so users will know about this converter project.
witchmaster
Sorgelig wrote:I was busy by cores, so didn't start yet.
Two analog pins per port are setup in the pinout above, pins 5 and 9 of both ports (used by paddles) are connected to analog pins. I will at least implement the "common" retro gamepads, like nes and snes still. I can create a wiki page, no problem! :)
Post by Sorgelig »
Ah, sorry.. overlooked it. I will use your pinout.
Post by Sorgelig »
witchmaster wrote:// Joystick Port 1
// 1 TXO PD3
// 2 RXI PD2
// 3 3 PD0
// 4 4 PD4
// 5 A0 PF7
// 6 6 PD7
// 7 VCC
// 8 GND
// 9 A1 PF6
Do we really need VCC on pin 7? I would use GND there. pins 5 and 9 would pulled up by resistor to VCC. This also will minimize risk of shortening VCC to GND using gamepad of other pinout. It also would be better from ADC point of view.
I don't know if VCC is really used by other interested accessories.
witchmaster
// 1 TXO PD3
// 2 RXI PD2
// 3 3 PD0
// 4 4 PD4
// 5 A0 PF7
// 6 6 PD7
// 7 VCC
// 8 GND
// 9 A1 PF6
VCC on pin 7 is not needed for passive joysticks, but for Atari paddles, the CD32 gamepad and joysticks with turbo fire it's needed. Most joysticks using this connector follow the Atari standard, with the exception being the Mega Drive/Genesis gamepad. Connecting that one shouldn't hurt since pin 7 for the Mega Drive is the "select" input pin, not an output.
The Atari paddles has a 1MΩ potentiometer connected between pin 7 (5V) and pin 5 for one paddle and pin 9 for the other. So as I understand it, 1MΩ resistors are needed between pins 5/9 and 8 (GND) to make a voltage divider.
Post by Sorgelig »
Ok, no problem.
Pull down resistor is fine too. But the problem is another side of pot is not connected to GND. So it gives non-linear division..
Higher pull-down resistor - more linear values but lower range. And vice versa.
Post by Sorgelig »
windows somehow sees 3 joysticks from arduino instead of 2
Post by Sorgelig »
after many experiments with different pull down resistors i couldn't make it reliable. The only way to fix it is to connect 3rd (unused) pin of pot to ground (black wire on button). This is simple mod. The one who solder the connector to arduino micro can solder a single jump wire in the paddle.
Pot sliding from GND to VCC gives a nice linear range.
using pull down resistor has 2 major disadvantages:
1) non-linear range
2) non-fixed minimal value as resistivity of pot and pull-down resistor vary from piece to piece.
probably (1) can be minimized using ~4MOhm pull down resistor (i have no such resistor currently), but (2) is hard to fix.
Locked
