NeoGeo topic
Re: NeoGeo topic
Hello all,
I am new to MISTer and Neo Geo is without question my favorite core. I am having one issue though which is likely due to a missing step on my part. Every time I play a game and save it tells me my memory card is not formatted. I answer yes to format and save. No big deal. Problem is, the next time I play the game it again is not formatted. So it isn't really formatting and saving.
Neo Geo core is configured as MVS but using Unibios set to AES and I have "autosave" set to on. What am I missing?
Thanks,
mario64
Thanks,
mario64
Re: NeoGeo topic
Hi mario I’m not sure but I think there’s an option in the core menu to set your memory card as « plugged »
Re: NeoGeo topic
Thanks. Yep. I have that setkazki wrote:Hi mario I’m not sure but I think there’s an option in the core menu to set your memory card as « plugged »
Re: NeoGeo topic
Try booting your neogeo core while pressing ABCD this should trigger the memory card manager
Re: NeoGeo topic
In general with Mister, even when Autosave is ON you still need to open the OSD before it saves
Neo-Geo Core
Hi everyone. I'm getting graphical glitches in The King of Fighters '94. Is there a way to tell if this is simply how it is with this core in its current state, or if it's an error on my part? Due to settings or file issues. I've gone through all messages in this thread thoroughly, so I'm sure I have all the correct files and games.
Re: NeoGeo topic
Thanks for the suggestions regarding the memory card issue. I will try them.
@Brendle You're not alone in those feelings. I too purchased a MISTer primarily based on those SmokeMonster videos. The impression I got from them was that the available cores are cycle accurate and under continual development. That is certainly untrue. I am quite happy with the Neo Geo core and several others but am very disappointed in the Gameboy and TG16 cores. GB is not even being actively developed any more and TG16 seems to be in the same boat.
A bit off topic but wanted to respond
- BitsNStuff
- Obsessive compulsive Atari behavior
Re: NeoGeo topic
Both those cores are still being worked on, just because you're seeing new releases every day does not mean that people aren't working on them. The PC Engine core in particular has had a lot of work done on it this year.mario64 wrote:Thanks for the suggestions regarding the memory card issue. I will try them.
For the people who are creating MiSTer, it's somthing they do when they're not out working or living their everydayl family lives, you can't realistically expect it to be worked on in the same way as a project that is somebody's career, people do the work to benefit of the entire community. Obviously having more developers twice as many developers working on the project as talented as the ones we already have would be a hell of a bonus to the project but you can't just pull developers out of thin air who would be willing to give their time and ability to the project.
Re: NeoGeo topic
To clear up any confusion with others reading this, I deleted a message of mine in-which I decided I was ranting too much, I didn't want to ruffle anyone's feathers, I wimped out basically. Oh man thanks for responding though, I thought I was going to get shot down but maybe I should have left the original message up. You sure did reply quick, haha. So I decided to replace the message with something else.mario64 wrote:Thanks for the suggestions regarding the memory card issue. I will try them.
@BitsNStuff - In Mario64's defence, he's mostly replying to a message of mine in-which, in a nutshell, I show my disdain for how a lot of people have been saying that certain cores are incredibly accurate, when they are far from it. This was my fault for believing the hype though. Yes, there's a lot of skill that goes into the cores and I for one certainly couldn't do anything close to create such things. I do appropriate the work.
Re: NeoGeo topic
@Brendle I’ve read your initial message, it’s too bad you sold your original games
I haven’t encountered any major issue with the Neogeo core though, have you tested your sdram board ?
I’ve prepped a few MiSTer setups for friends and they all are Neogeo collectors and enthousiasts and as far as I can tell none of them has ever had any major issue as well
If you need more specific help on the subject, I’d be happy to help
Re: NeoGeo topic
Oh wow thank you, I don't have much time right now but I'll post about the issues most likely within the next 24 hours. Maybe screenshots will help. Games do run, just not well. Yes I have tested the sdram board but not thoroughly, I'll do that ASAP.kazki wrote:@Brendle I’ve read your initial message, it’s too bad you sold your original games. I haven’t encountered any major issue with the Neogeo core though, have you tested your sdram board? I’ve prepped a few MiSTer setups for friends and they all are Neogeo collectors and enthusiasts and as far as I can tell none of them has ever had any major issue as well. If you need more specific help on the subject, I’d be happy to help
Re: Neo-Geo Core
Lots of the glitches are mentioned on the issues page:Brendle wrote:Hi everyone. I'm getting graphical glitches in The King of Fighters '94. Is there a way to tell if this is simply how it is with this core in its current state, or if it's an error on my part? Due to settings or file issues. I've gone through all messages in this thread thoroughly, so I'm sure I have all the correct files and games.
https://github.com/MiSTer-devel/NeoGeo_MiSTer/issues
I've noticed others (eg Football Frenzy the touchdown graphics have sprites missing) but haven't bothered to report them yet, probably it's just the same bugs affecting lots of games.
Re: Neo-Geo Core
@kazki here's some info.
- MiSTer v200311, OS v200122, 128MB SD Ram, Heatsink, Fan, USB Board, Power Supply: CableRite OUTPUT 5V-4.0A, INPUT 100-240VAC ~ 50/60Hz 0.8A Max (UK).
Used FileZilla set to Binary to transfer files. I haven't tested sound much so far but KOF'94 sound seems fine. Files in media > fat > games > NeoGeo > 000-lo.lo, King of Fighters '94, The (kof94).neo, romsets.xml, sfix.sfix, uni-bios.rom. All Checksums are the same as the ones that someone posted earlier, apart from romsets.xml, but I assume that's because it's been updated since then.
- Neo-Geo Core v200123 (it says this when running the core, however, the file name is NeoGeo_20200123.rbf)
- System Type: Arcade (MVS)
- Bios: UniBIOS 3.3
- Video Mode: NTSC
- Connection: HDMI
Memory Card: Plugged (this reverts back to plugged even if I save or reset)
Auto Save: Off
DIP Settings: Off
Freeplay: On
Freeze: Off
Width: 320px
Aspect Ratio: Original
Scandoubler Fx: None
Stereo Mix: None
Game: King of Fighters '94, The (kof94).neo (from @MiSTer Pack Add-on - Neo Geo 2019-11-20.7z)
GFX glitch after the '8'
GFX tiles appearing outside the game screen on these two:
Right half of all win quotes flicker on and off:
Memory Test:
https://ibb.co/kq3p2Cm
These are from playing for about 15 mins, I don't know if there's more later. I was unable to screenshot some others such as a glitch on a bird flying by in the England stage at the start, and a glitch once when character was hit. If these are inaccuracies with the core, then fair enough. But if it's something I'm doing wrong and others aren't having these issues, then it would be cool to know. One last question, I use the update script, does it update absolutely everything including the MiSTer (v200311) and the OS?
Thank you for your time.
- Bios: UniBIOS 3.3
- Video Mode: NTSC
- Connection: HDMI
Auto Save: Off
DIP Settings: Off
Freeplay: On
Freeze: Off
Width: 320px
Stereo Mix: None
Memory Test:
Oh right, if that's the case then it's good to know. It's a bit hard to tell what is personal error and what is normal, because a lot of users post issues and then post later saying they've fixed GFX issues by changing files and stuff. I'm pretty sure I have all the right files though.sqwirral wrote:Lots of the glitches are mentioned on the issues page:Brendle wrote:Hi everyone. I'm getting graphical glitches in The King of Fighters '94. Is there a way to tell if this is simply how it is with this core in its current state, or if it's an error on my part? Due to settings or file issues. I've gone through all messages in this thread thoroughly, so I'm sure I have all the correct files and games.
Re: NeoGeo topic
This is interesting
.neo files are roms taken from the NeoSD multicart from Terraonion, they need a proprietary program to convert a .zip into a .neo
although they might work, they aren't the romset you should look for
maybe you should try the Darksoft romset because the romset.xml is tailored to be used with the Darksoft
google up for darksoft roll up
extract the zip (you should obtain FOLDERS containing the files) into your NeoGeo directory
you'll need the romset.xml to get it work, and hopefully you'll notice nearly zero issue at all
can't say for sure for the tiles outside the image because I'm playing on a CRT
edit : I tried kof94 with my darksoft set and indeed the glitches you talked about are present, I even tried on my NeoSD Pro on my AES no glitches at all, but overall the neogeo core is solid and does not have major issues
Re: NeoGeo topic
Hopefully Furrtek can look into this and add Neo CD after he is done with his current Neo CD custom firmware debacles...
Re: NeoGeo topic
Cheers, that's nice of you to help. I was so sure I was using the correct roms for MiSTer, I must be blind. However I got it from a file called 'MiSTer Pack' so I'll give myself SOME credit, haha. I think someone recommended it early in this thread. The one you've suggested, 'Darksoft Roll Up', I think I have it. I think it's the first one I tried but the games didn't work back then due to other issues with non-game files. So I'll give it another try. You added that with it, the KOF'94 glitches are still present, but as Darksoft is recommended, perhaps overall performance will increase.kazki wrote:This is interesting
Haha, I will try it on a CRT soon when the Scart Cable arrives. I'm going to try it on a 4:3 VGA monitor before that.
Re: NeoGeo topic
Those .neo ones are fine, a lot of us use them, easier to work with than the romsets.xml method
- BitsNStuff
Re: NeoGeo topic
@Brendle and @mario64
Don't worry I wasn't taking issue with what either of you said and I am sorry if it sounded like I was, that wasn't the intention. Just anted to point that just because there aren't regular releases on those cores doesn't mean that there isn't work going towards those releases.
I'm not a developer so I don't always understand what I see there but if you have a look on the GitHub listings for those cores you can see that work is being done on them.
https://github.com/MiSTer-devel/TurboGrafx16_MiSTer
https://github.com/MiSTer-devel/Gameboy_MiSTer
Each of theose cores, like all the others do, have their own threads on here too so it's always worth having a look at those threads too. Perhaps the cores haven't seen the most action recently but I suppose that's always going to be the way when there area a limited number of developers working across a project of this scale but I can't imagine many of the developers being happy until everything is as good as it can be.
In relation to the NeoGeo core alignment, it does always appear to be just a few pixels off centre. In many games it doesn't actually show because they use all of the available space anyway. It does stand out far more in the games that you show because of the black bars on the sides which obscure just some of the image.
I assume you're using HDMI like me as I've seen people using analogue output noticing it but that could be because overscan hides it on analogue panels. I know there's an option in the core to reduce the number of visible pixels shown on the horizontal axis but even with that switched on it doesn't quite with it due to the centering being ever so slightly off. I don't whthere that's true of the original hardware though.
Re: NeoGeo topic
Thanks @BitsNStuff. Yes I'm using it on a monitor with HDMI, I should be able to get it on CRT soon though, when the cable arrives. Will also try it on 4:3 VGA monitor. Yeah I know what you mean, concerning screen edges.
A question to you lot - Is there less latency using D-Sub (VGA) than HDMI? I did a little research but there were contradictory opinions.
I'm using those .neo files with the romsets.xml from the Neo-Geo core GitHub page, will that cause issues (and what issues, if you know)? The way you said it makes it sound like I don't need the romsets.xml at all, should I delete it?sqwirral wrote:Those .neo ones are fine, a lot of us use them, easier to work with than the romsets.xml method
Re: NeoGeo topic
The NeoSD (.neo) format is really simple, kinda similar to the de facto standard iNES (.nes) format for NES, where it concatenates the (uncompressed) ROMs into a single file along with a header that describes the sizes and some other metadata. No need for anything "proprietary".kazki wrote:.neo files are roms taken from the NeoSD multicart from Terraonion, they need a proprietary program to convert a .zip into a .neo
For instance I was looking into it recently and found this:
https://gitlab.com/loic.petit/darksoft-to-neosd
Going from a MAME zip to NeoSD would be similarly trivial.
Re: NeoGeo topic
Does the Neo-Geo core work on D-Sub (VGA) monitors? I changed 2 settings in my MiSTer.ini, I activated both forced_scandoubler and vga_scaler by changing them to '1'. the MiSTer boots up, I can see and use the menu but the Neo core must be changing resolution because my monitor loses the signal when I start it. I looked for a ini file for the core but couldn't find one. I'm using an I/O board, not a HDMI to VGA adapter.
Are there other settings I need to change?
EDIT - Nevermind, I turned 'composite_sync' on in MiSTer.ini and now it works. I had to change the Aspect Ratio to Wide in the core settings (because it was horizontally really squished) but I assume that's what you're supposed to do. EDIT 2 - It would be nitpicking to some but, there's a light ripple effect going across the screen using VGA. I tested it with two cables and two monitors but it was the same on both. I thought it was interference from the DE10-Nano itself at first, like maybe the power socket which is close to the VGA socket was doing it (the effect looks like heat rising on the road or if you have a heater under a wall which is being used for a projector... it's hard to describe). But I booted up the Mega Drive core and the issue isn't there. One of my VGA monitors also has DVI, I'm going to see if the same thing happens with that.
EDIT 3 - I fixed it by changing the 'vsync_adjust' from 'Low lag' to 'Match display frequency' in the MiSTer.ini. This adds lag but got rid of the ripple effect on the screen.
Re: NeoGeo topic
Now that the Universal Bios 4 is free, has anyone tried it with their MiSTer NG core yet?
Re: NeoGeo topic
I've been using 4.0 for awhile now from my own dumped mvs bios chip. What concerns do you have?gusmoney wrote:Now that the Universal Bios 4 is free, has anyone tried it with their MiSTer NG core yet?
Re: NeoGeo topic
Same here. Works flawlessly. Current issues are related to the core (let's pray the lord Furrtek will not die surrounded by acetone toxic fumes before that); not the BIOS you use.djsquare wrote:I've been using 4.0 for awhile now from my own dumped mvs bios chip. What concerns do you have?gusmoney wrote:Now that the Universal Bios 4 is free, has anyone tried it with their MiSTer NG core yet?
Re: NeoGeo topic
No concerns per se. This is my first opportunity to use it and wondered if anyone else had given it a try.djsquare wrote:I've been using 4.0 for awhile now from my own dumped mvs bios chip. What concerns do you have?gusmoney wrote:Now that the Universal Bios 4 is free, has anyone tried it with their MiSTer NG core yet?
