dshadoff wrote:Televicious wrote:Getting an out of range message on my dell 1908fp when i load the 2-20 version of the core. tried all sorts of configs. The 2-12 version works fine however.
A lot of code changed in that release, but it was mostly just interrupt timing (i.e. what pixel to display, rather than the structure of the display). The only thing I see about the structure of the display is the removal of one excess clock per scanline (commit e2d8703).
Is that a type of monitor ?
Yes, a dell 1908fp lcd monitor.
Does it indicate what type of range is being violated ?
No, just that it is not syncing to 1280x1024 60hz, a box floats around the screen displaying that it is out of range.
Do you have more information on what you were trying to do at the time (i.e. at menu ? not at menu, but game not yet selected ? if playing a game, which one ?) ? Resolution mode is important information.
I set the whole mister to 1280x1024 60hz or specifically video mode 4 , that is the native resolution for this monitor. The 2-20 release is the only build that doesn't sync. Have gotten all other cores working great. Have reverted to the 2-12 and been using that perfectly well. Wish I had more info to help.
