It's auto-detected but detection happens in Menu core.
So make sure you start Menu core first.
SDRAM board
Re: SDRAM board
Also, I initially had the same issue with my bad PCB board, see a few posts back, menu RAM icon and memtest were acting like SDRAM module was not plugged in. If you built this yourself, you can check continuity between module header and RAM chip and also between the RAM chips to see if the nodes are connected properly.Rikko wrote:Hi all,
would you say that I am correct to assume that adding an SDRAM board does not require any configuration?
Just for transparency, I've got a 128Mb v2.5 that core does not see. Basically, memtest shows 100% failure (multiple versions, all speeds), as if I didn't plug the board in.
Re: SDRAM board
@Sorgelig:
perhaps I'm not doing it right, but it's the Menu that I use to start the memtest.
@richx:
I was afraid of this, and I didn't come up with anything else, before I reached out.
Thank you both for sharing your wisdom with me. I'll post here once I figure it out, for record purposes.
EDIT:
Sorted. It was a "cold solder" on pin 34 of the U1.
Memtest v191220 - 140MHz
Memtest v190920 - 150MHz
Thanks again
@richx:
EDIT:
Thanks again
Re: SDRAM board
No configuration needed. Are you certain you didn't plug it in backwards or something?Rikko wrote:Hi all,
Re: SDRAM board
You know, someone may laugh at this, but I realised it's a challenge to figure out which way things go. Luckily for me, "this side faces outward" was indicative enough to avoid mistakes. I agree it would have been easier if the whole thing is keyed somehow, but with generic 2x40 header, it's not practically feasible to do (excluding replacement of the header itself).reflex wrote: No configuration needed. Are you certain you didn't plug it in backwards or something?
In my case, it turned out to be a poor connection on pin 34 on one of the memory chips.
Re: SDRAM board
Back in the mid-90's I owned a PC repair/build shop. While working very late at night I wasn't paying attention and inserted a 486 CPU (actually an AMD5x86 133Mhz) into the socket backwards (they weren't keyed back then). When I powered it on there was a pop and a flash and I couldn't get it to boot up. When I realized what I had done I assumed I had killed the CPU for good. With nothing to lose I started tinkering. By default this was a 3.45v CPU, but I discovered that if I set the board voltage to 5v, it booted!Rikko wrote:You know, someone may laugh at this, but I realised it's a challenge to figure out which way things go. Luckily for me, "this side faces outward" was indicative enough to avoid mistakes. I agree it would have been easier if the whole thing is keyed somehow, but with generic 2x40 header, it's not practically feasible to do (excluding replacement of the header itself).reflex wrote: No configuration needed. Are you certain you didn't plug it in backwards or something?
I still have that CPU, and it still boots, but only at 5v.
