MiSTer updates and changelog
Re: MiSTer updates and changelog
SNES:
- Fixes from srg320.
- Open OSD at start if boot.rom is not loaded.
MiSTer:
- arcade: search files in zip by CRC32 (if provided) by zakk4223
- Integrated support for Linux framebuffer over VGA/Direct video.
Menu:
- All framebuffer features on VGA and Direct Video (use direct_video=1 to enable)
Note: you have to update both MiSTer binary and Menu core.
Menu:
MiSTer:
- arcade: override core name with 'setname' node in MRA.
- input: fix: PS/2 auto-repeat was disabled.
- input: support for paddle on MadCatz Arcade Stick XBox 360 (RThumb+XBox to enable/disable).
Pacman:
- Add original The Glob and Beastie Feastie games.
Menu:
- Update the framework
- Attempt to eliminate (minimize at least) audio lag from Linux apps increasing over the time.
New core: Arcade MCR3Mono (Rampage,Sage,PowerDrive,MaxRPM).
(Port by alanswx, blue1, me and original devs of core)
Arcade MCR3Mono:
- Support for Demolition Derby.
- some fixes.
- some fixes.
Pacman:
- add Jump Shot game by neurorulez.
Main:
- Arcade: pick most recent rbf if several are present.
- C64: support for T64 files as virtual D64 (by nanner55)
- Adjust framebuffer TV modes.
- Support for auto-mount of boot0-3.vhd
C64:
- Fix sprite priority (by vpelletier).
- Fix PRG RAM injection (by nanner55)
- Fix the scandoubler clock.
- Adjust OPL2 mixing.
C64:
Linux:
- Add TP-Link Archer T2U-nano ID to supported dongles (by Adam Strzelecki)
- BT Tweaks for DualShock 4 pairing (by leonbottou)
- apply jspoll tweak to gamepad class
- add xpad.cpoll tweak (by eniva)
- Update Midilink to latest.
- Other tweaks and fixes.
NeoGeo:
- Fix SMA RNG by Kitrinx
- Update the framework.
Arcade Bagman:
- Support for Super Bagman
Arcade Bagman:
- Merge following arcades: Botanic, Pickin', Squash
- Add spinner option to Squash control.
Genesis:
- Fix lockup when cheats are used with DDR3.
- Open OSD at start if no boot.rom loaded
Arcade Arkanoid:
- Add USB and USER_IO spinner control.
- Add MRAs with cheats (as an example).
Arcade MCR2:
- Many fixes and tweaks.
- SDRAM is not required.
Arcade MCR3:
- Add Discs of Tron game.
- Add Journey game.
- Add Journey game.
Arcade MCR3:
- Fix sound pitch.
- Fix sound pitch.
- Atari nerd
GBA:
- Rewind feature added
- Fixed graphical glitches(e.g. flickering lines)
- Fixed some rarely used CPU instructions
- Repurpose Pause menu option to work when OSD is open
- Combined Desaturate and Shadercolors options
- Game crashes fixed: Hello Kitty, Sonic Pinball Party, Wakeboarding Unleashed, Dragonball Z 2in1
Amstrad:
- Fix PSG.
- Some GA fixes from Gyurco.
- Some other internal updates.
- Fix PSG.
ZX Spectrum:
- Fix PSG.
- Fix PSG.
Main:
- arcade: non-rbf (renamed) file.
- arcade: update in md5 check.
- arcade: support button definition in MRA.
- arcade: support ROM byte interleave/shuffling.
New: Arcade-MCR3Scroll:
Includes Spy Hunter, Crater Rider, Turbo Tag
Requires update to latest Main
Arcade: Scrambler:
- Add games: Anteater, Armored Car, Battle of Atlantis, Calipso, Lost Tomb, Moonwar, Speed Coin, Super Cobra, Tazz-Mania
- Merge-in existing arcades: Amidar, The End, Frogger
Arcade MCR3Mono:
- Adjust VBlank position.
- Tweak Sarge fire buttons.
- Update MRA files with correct MD5/CRC by mrfpga
- Update MRA with game-specific button names, hide unused buttons.
Arcade MCR3:
- Fix the reset.
- Use separate coin button for non-Tron games..
- Fix the reset.
