HxC USB on STm
Moderators: DrCoolZic, mr.vince, Moderator Team
Marcopolo
HxC USB on STm
Post by Marcopolo »
Hi all, I've trawled through this section of the forum and Lothreks webpages but can't seem to find what I need. My recently resurrected 520STM (1mb upgrade), has an external 14pin floppy and no internal floppy
How would I then connect the HcX up to the machine without having to make a custom cable?
Many thanks,
Marco.
MiggyMog
Re: HxC USB on STm
Post by MiggyMog »
You would need to install in external floppy drive with cable and replace the Internal drive with Hcx.
For preservation sake you may want to find another external drive and install in that so no case cutting or such is needed in the SF drive.
Marcopolo
Re: HxC USB on STm
Post by Marcopolo »
Apologies, not sure what you mean. There is no internal drive or even provision on the motherboard for an FDD plug. The only interface is the external FDD port.......The STM has both external PSU and FDD. Only the modulator is internal.
emcclariion
Re: HxC USB on STm
Post by emcclariion »
Find a broken External drive or use yours, but they are getting hard to fined now, so find one which has a dodgy floppy drive, open it up and plug the HxC into it and cut the casing.
Atari TT Nova card Mach64, Lightning VME, 64MB of RAM, Mega STE 4MB, Nova mach 32 and Atari STE 4MB TOS 2.06 Netusb Ultrasatan 2, Atari Falcon CT60 512MB Netusb
Marcopolo
Re: HxC USB on STm
Post by Marcopolo »
Actually I do have a spare floppy drive. It was the original broken one but luckily I kept it.....good call, thanks!!!!
MiggyMog
Re: HxC USB on STm
Post by MiggyMog »
Apologies, I meant as emcclariion says to put it in the external drive.
