Case
Moderators: Mathias, Mug UK, [ProToS], moondog/.tSCc., Galvez, Moderator Team
PeterS
Case
Post by PeterS »
I was about to chuck a Metronic Sat TV box in the recycling because it no longer works very well, it has to be manually tuned.
I wondered if it was about the right size for a Firebee so I measured it. It's just about 26cm long inside so it might be a squeeze. The backplate would need a bit of work.
vido
Re: Case
Post by vido »
The PCB of the FireBee is just about 26 cm long.
Sounds lihe a hard task ...
PeterS
Re: Case
Post by PeterS »
I don't have a Firebee, I just happened to notice that it might fit. Most normal computer cases are usually much too big.
Return to “FireBee”
