lockdown projects (sprite mouse image editor)
charles
Post by charles »
well ive been very isolated and with the pandemonious feeling slowily decreasing
had time to take on the task of figure out some graphic routines never fully understood .
so I rewrote a gfa basicv2 sprite/mouse/image editor into gfa v3.6tt syntax
would like to add some more features
now that's its current please write with some practical features I should include.
' sof
' Update Source
KILL "b:\spr_edr3.lst"
LIST "b:\spr_edr3.lst"
' Main
@main
' Found The End
END
' Enter Main Program
PROCEDURE main
  LOCAL i&,mx&,my&,mk&
  IF BTST(XBIOS(4),1)
    ' global variables
    ' disk
    a$=""
    b$=""
    ' xy
    x_hotspot&=0
    y_hotspot&=0
    ' grfx
    DIM fore_grd&(15),back_grd&(15)
    ' draw scrn
    @build_screen
    ' main
    escape_flag!=FALSE
    ON MENU KEY GOSUB keyboard
    REPEAT
      ON MENU
      MOUSE mx&,my&,mk&
      IF mk&
        @mouse(mx&,my&,mk&)
      ENDIF
    UNTIL escape_flag!
    GRAPHMODE 1
    COLOR 1
    DEFLINE 1,0,0,0
    FOR i&=0 TO 400 STEP 2
      BOX i&,i&,SUB(639,i&),SUB(399,i&)
      CIRCLE 320,200,SUB(375,i&)
    NEXT i&
    DEFFILL 0,2,8
    PBOX 0,0,639,399
  ELSE
    ALERT 3,"Sprite-Editor only| operate under| monochrome",1,"Oppps!",dummy%
  ENDIF
RETURN
' Screen Image
PROCEDURE build_screen
  LOCAL i&,a&
  GRAPHMODE 1
  DEFLINE 1,1,0,0
  DEFFILL 1,2,4
  PBOX 0,0,639,399
  DEFFILL 1,2,8
  PRBOX 15,35,310,45
  PRBOX 35,75,615,290
  PRBOX 55,305,595,395
  DEFFILL 1,0,8
  PRBOX 10,10,315,40
  PRBOX 30,70,620,285
  PRBOX 50,300,600,390
  PRBOX 440,100,600,260
  PRBOX 450,110,515,250
  DEFFILL 1,2,8
  PRBOX 525,110,590,250
  DEFLINE 1,1,0,0
  FOR i&=0 TO 16
    a&=MUL(i&,10)
    LINE 50,ADD(100,a&),210,ADD(100,a&)
    LINE 250,ADD(100,a&),410,ADD(100,a&)
    LINE ADD(50,a&),100,ADD(50,a&),260
    LINE ADD(250,a&),100,ADD(250,a&),260
  NEXT i&
  DEFLINE 1,3,0,0
  LINE 30,270,620,270
  LINE 50,370,600,370
  DEFTEXT 1,0,0,13
  TEXT 21,27,"Mouse & Sprite Image Editor for GFA"
  DEFTEXT 1,4,0,6
  TEXT 21,37,"Copyright 1986   GFA Systemtechnik "
  DEFTEXT 1,0,0,4
  TEXT 50,280,550,"Please Write  :  Arnfried Griesert, Montanusstr. 8, 5653 Leichlingen"
  DEFTEXT 1,1,0,13
  TEXT 50,90,"Foreground"
  TEXT 250,90,"Background"
  TEXT 440,90,"Sprite Render"
  DEFTEXT 1,0,0,13
  TEXT 72,316,"F1 = Load Sprite"
  TEXT 72,338,"F2 = Save as Editor-File"
  TEXT 72,360,"F3 = Save as Sprite-File"
  TEXT 370,316,"F4 = Save as Mouse-File"
  TEXT 370,338,"F5 = Erase Sprite"
  TEXT 362,360,"F10 = Quit"
  @hot_xy_loc(x_hotspot&,y_hotspot&)
  TEXT 87,386," = XY Hotspot"
  @hot_spot(x_hotspot&,y_hotspot&)
  DEFTEXT 1,0,0,4
  TEXT 400,383,"Re-written 2021 Charles Copp"
RETURN
' KEYBOARD On Menu Interupt
PROCEDURE keyboard
  LOCAL item&
  item&=MENU(14)
  '  PRINT AT(2,2);USING "#####",item& MOD 255
  SELECT item&
  CASE 15104
    @sprite_load("SHP")
  CASE 15360
    @sprite_save("SHP")
  CASE 15616
    @spr_list("LST")
  CASE 15872
    @mos_list("LST")
  CASE 16128
    @reset
  CASE 283,17408
    @escape(item&)
  CASE 18432,19712,20480,19200
    @arrow_buts(item&)
  ENDSELECT
RETURN
PROCEDURE arrow_buts(z&)
  LOCAL x&,y&
  x&=x_hotspot&
  y&=y_hotspot&
  SELECT z&
  CASE 18432 !up
    y_hotspot&=MOD(ADD(y_hotspot&,15),16)
  CASE 19200 !left
    x_hotspot&=MOD(ADD(x_hotspot&,15),16)
  CASE 19712 !right
    x_hotspot&=MOD(ADD(x_hotspot&,1),16)
  CASE 20480 !down
    y_hotspot&=MOD(ADD(y_hotspot&,1),16)
  ENDSELECT
  @draw_sprite(x&,y&,SUB(15,x&))
RETURN
PROCEDURE escape(a&)
  ALERT 2,"|Have you saved |your work?",1,"Yes|No",a&
  escape_flag!=(SUB(a&,2))
RETURN
' Sprite To All 3 Windows
PROCEDURE draw_sprite(x&,y&,a&)
  LOCAL b&,c&
  b&=MUL(x&,10)
  c&=MUL(y&,10)
  ADD b&,50
  ADD c&,100
  GRAPHMODE 1
  IF BTST(fore_grd&(y&),a&)=FALSE
    IF BTST(back_grd&(y&),a&)=FALSE
      DEFFILL 0,2,8
      PBOX ADD(b&,1),ADD(c&,1),ADD(b&,9),ADD(c&,9)
      PBOX ADD(201,b&),ADD(c&,1),ADD(209,b&),ADD(c&,9)
      PSET ADD(555,x&),ADD(172,y&),1
    ELSE
      DEFFILL 1,2,2
      PBOX b&,c&,ADD(b&,10),ADD(c&,10)
      PBOX ADD(200,b&),c&,ADD(210,b&),ADD(c&,10)
      PSET ADD(555,x&),ADD(172,y&),0
    ENDIF
    PSET ADD(475,x&),ADD(172,y&),0
  ELSE
      DEFFILL 1,2,8
    ELSE
      DEFFILL 1,2,8
      DEFFILL 1,2,2
    ENDIF
    PSET ADD(475,x&),ADD(172,y&),1
  ENDIF
  IF x&=x_hotspot& AND y&=y_hotspot&
  ENDIF
RETURN
' XY "HOTSPOT" Indicator
PROCEDURE hot_spot(x&,y&)
  LOCAL i&,a&,b&
  a&=MUL(x&,10)
  b&=ADD(MUL(y&,10),103)
  GRAPHMODE 3
  DEFLINE 1,0,0,0
  DEFFILL 1,2,8
  FOR i&=0 TO 4
    LINE ADD(53,a&),ADD(i&,b&),ADD(57,a&),ADD(i&,b&)
    PBOX ADD(253,a&),ADD(i&,b&),ADD(257,a&),ADD(i&,b&)
  NEXT i&
RETURN
PROCEDURE hot_xy_loc(x&,y&)
  LOCAL a$
  GRAPHMODE 1
  DEFTEXT 1,0,0,13
  a$="  "
  MID$(a$,1)=STR$(ADD(x&,1))
  TEXT 57,386,a$
  a$="  "
  MID$(a$,1)=STR$(ADD(y&,1))
  TEXT 78,386,a$
RETURN
' Load in *.SHP-File (F1)
PROCEDURE sprite_load(ext$)
  LOCAL i&,x&,y&,fore_grd%,back_grd%,dummy&
  FILESELECT "\*."+ext$,b$,a$
  IF LEN(a$)>1 THEN
    IF EXIST(a$) THEN
      b$=RIGHT$(a$,SUB(LEN(a$),1))
      @draw_sprite(x_hotspot&,y_hotspot&,SUB(15,x_hotspot&))
      OPEN "I",#1,a$
      INPUT #1,x_hotspot&,y_hotspot&
      FOR i&=0 TO 15
        INPUT #1,fore_grd%,back_grd%
        CARD{V:fore_grd&(i&)}=fore_grd%
        CARD{V:back_grd&(i&)}=back_grd%
      NEXT i&
      CLOSE #1
      FOR y&=0 TO 15
        FOR x&=0 TO 15
        NEXT x&
      NEXT y&
    ELSE
      ALERT 1,"File Doesn't Exist!",1,"Resume",dummy&
    ENDIF
  ENDIF
RETURN
' Save As *.SHP-File (F2)
PROCEDURE sprite_save(ext$)
  LOCAL i&
  IF LEN(a$)>1 THEN
    OPEN "O",#1,a$
    PRINT #1;x_hotspot&
    PRINT #1;y_hotspot&
    FOR i&=0 TO 15
      PRINT #1;CARD{V:fore_grd&(i&)}
      PRINT #1;CARD{V:back_grd&(i&)}
    NEXT i&
    CLOSE #1
  ENDIF
RETURN
' Save As Basic-Listing (Sprite.LST) (F3)
PROCEDURE sp_list(ext$)
  LOCAL i&,dummy%,shape$
  '  @disk_op(shape$)
  '  PROCEDURE disk_op(VAR shape$)
  IF LEN(a$)>1 THEN
    shape$=a$
    WHILE INSTR(shape$,"\")<>0
      dummy%=SUB(LEN(shape$),INSTR(shape$,"\"))
      shape$=RIGHT$(shape$,dummy%)
    WEND
    dummy%=INSTR(shape$,".")
    IF dummy%<>0 THEN
      shape$=LEFT$(shape$,SUB(dummy%,1))
    ELSE
      a$=a$+"."+ext$
    ENDIF
    OPEN "O",#1,a$
    PRINT #1;"KILL ";CHR$(34);"B:\";shape$;".LST";CHR$(34)
    PRINT #1;"LIST ";CHR$(34);"B:\";shape$;".LST";CHR$(34)
    PRINT #1;"' Sprite-Data in String format "
    PRINT #1;shape$;"$";"=SPACE$(74)"
    PRINT #1;"MID$(";shape$;"$,1,10)=MKI$("+STR$(x_hotspot&)+")+MKI$("+STR$(y_hotspot&)+")+MKI$(0)+MKI$(0)+MKI$(1)"
    PRINT #1;"RESTORE";shape$
    PRINT #1;"FOR i&=0 TO 15"
    PRINT #1;"READ fore_grd%,back_grd%"
    PRINT #1;"MID$(";shape$;"$,ADD(11,(MUL(i&,4))),4)=MKI$(back_grd%)+MKI$(fore_grd%)"
    PRINT #1;"NEXT i&"
    PRINT #1;"'"
    PRINT #1;"SPRITE ";shape$;"$";",30,50"
    PRINT #1;"~INP(2)"
    PRINT #1;"'"
    PRINT #1;shape$;":"
    FOR i&=0 TO 15
      IF i&=8 OR i&=0
        PRINT #1
        PRINT #1;"DATA ";
      ELSE
        PRINT #1;",";
      ENDIF
      PRINT #1;STR$(CARD{V:fore_grd&(i&)});",";STR$(CARD{V:back_grd&(i&)});
    NEXT i&
    PRINT #1
    CLOSE #1
  ENDIF
RETURN
' Save As Basic-Listing (Mouse.LST) (F4)
PROCEDURE mos_list(ext$)
  LOCAL i&,dummy%,a$,b$,shape$
  IF LEN(a$)>1 THEN
    shape$=a$
    WEND
    IF dummy%<>0 THEN
    ELSE
      a$=a$+"."+ext$
    ENDIF
    OPEN "O",#1,a$
    PRINT #1;"' Mouse-Data in String Format"
    PRINT #1;"MID$(";shape$;"$,1,10)=MKI$("+STR$(x_hotspot&)+")+MKI$("+STR$(y_hotspot&)+")+MKI$(1)+MKI$(0)+MKI$(1)"
    PRINT #1;"RESTORE ";shape$
    PRINT #1;"FOR i&=0 TO 31"
    PRINT #1;"READ a%"
    PRINT #1;"MID$(";shape$;"$,ADD(11,(MUL(i&,2))),2)=MKI$(a%)"
    PRINT #1;"NEXT i&"
    PRINT #1;"'"
    PRINT #1;"DEFMOUSE ";shape$;"$"
    PRINT #1;"~INP(2)"
    PRINT #1;"END"
    PRINT #1;"'"
    PRINT #1;shape$;":"
    FOR i&=0 TO 15
      IF i&=0 OR i&=8
        PRINT #1
        PRINT #1;"DATA ";
      ELSE
        PRINT #1;",";
      ENDIF
      PRINT #1;STR$(CARD{V:back_grd&(i&)});
    NEXT i&
    FOR i&=0 TO 15
      IF i&=0 OR i&=8
        PRINT #1
        PRINT #1;"DATA ";
      ELSE
        PRINT #1;",";
      ENDIF
    NEXT i&
    PRINT #1
    CLOSE #1
  ENDIF
RETURN
' Clear (Fore/Back Ground) (F5)
PROCEDURE reset
  LOCAL x&,y&
  ALERT 2,"!!WARNING!! |Sprite Data |Will be lost",2,"Clear|Leave",x&
  IF x&=1 THEN
    HIDEM
    ARRAYFILL fore_grd&(),0
    ARRAYFILL back_grd&(),0
    FOR y&=0 TO 15
      FOR x&=0 TO 15
      NEXT x&
    NEXT y&
    SHOWM
  ENDIF
RETURN
' Handle Mouse Input
PROCEDURE mouse(x&,y&,k&)
  IF y&>99 AND y&<259
    IF x&>49 AND x&<209
      SUB x&,50
      DIV x&,10
      SUB y&,100
      DIV y&,10
      @mouse_1(V:fore_grd&(y&),x&,y&,k&)
    ELSE IF x&>249 AND x&<409
      SUB x&,250
      DIV x&,10
      SUB y&,100
      DIV y&,10
      @mouse_1(V:back_grd&(y&),x&,y&,k&)
    ENDIF
  ENDIF
RETURN
PROCEDURE mouse_1(adr%,x&,y&,k&)
  LOCAL a&,b&
  a&=SUB(15,x&)
  CARD{V:b&}=CARD{adr%}
  IF k&=1 AND BTST(b&,a&)=FALSE
    CARD{adr%}=BSET(b&,a&)
  ELSE IF k&=2 AND BTST(b&,a&)
    CARD{adr%}=BCLR(b&,a&)
  ENDIF
  @draw_sprite(x&,y&,a&)
RETURN
REM ##########################################################################
REM ####                You have hardly reached the END                   ####
' eof
The radioactive half-life : )
Return to “GFA BASIC”
