DemoBaseST updated to v1.10
Moderators: Goldrunner, SkylineDave, Moderator Team
SkylineDave
Post by SkylineDave »
v1.10
LIBRARY:
* 38 new screens
AUTOPLAY:
* Added red "Skip to next screen" button while autoplay is running
* Pause and Stop buttons now won't show at all when autoplay not running
* Play button hoverover says "Restart" not "Start" when autoplay either running or paused
* Play button now won't appear if there are no record matches
* Play button now correctly restarts from top of list if autoplay already playing or paused
* Requerying while autoplay was running now stops autoplay, as the results will be different!
* Clicking Stop button will stop autoplay but not close the current STeem
* Loading and Disk Swap screens will only play for the shorter user-defined period of time if the user is watching a Megademo
ENGINE:
* Updated STeem 4.0.2 R23 to 4.0.2 R29
* If your DemoBaseST file path is too long, you will be informed if you try to run a screen, instead of letting STeem say the snapshot is corrupt
* If DemoBaseST can't find the demoscreen file, it will warn instead of crashing
* Added functionality for DemoBaseST to control STeem disk quick access (Symic demo requires slow disk access)
* Minor filename redundancy removed from database
* Minor mathematical efficiencies
BUG FIX:
* Adding a demo to favourite/jukebox when it was already there and your favourite/jukebox was full would remove it
* Running a screen from the Family Map wouldn't apply the correct settings if you'd ticked Prefer Best STeem version
* Mouse double-clicks now don't also trigger the single-click behaviour afterwards!
* Couple of record fixes in database
UI:
* Screenshot carousel fast-forward speed increased
MISC:
* Default DBST frameskip reduced from Max to High
UPDATE:
* Temporary update folder now removed after any DemoBaseST update applied
AKA Megadaz / Black Eagle --- STOS, Dungeon Master and Captive fan!
Developer of DemoBaseST
JeanMars
Re: DemoBaseST updated to v1.10
Post by JeanMars »
Many thanks !
