Removing left and right borders
GFA, ASM, STOS, ...
Post by joska »
I'm trying to understand how left/right border removal is working. I found some code in ST-News 5.1:
; BORDERS.S
; The following code will effectively bust any borders present on
; your color monitor.
; Original source by TEX, but it was slightly mutilated by the eager
; fingers of Digital Insanity (of course)
; Have fun with it!
screen		equ	$a0000		; address of new screen
line		equ	(1*8)-1		; scanline where border is gone
x:		pea 	0		; supervisor on
		move	#$20,-(sp)
		trap	#1
		addq.l	#6,sp
		move.l	d0,old_stack
		move.b	#0,$fffa1d	; disable timer C and D
		move	#0,$ff8240	; black screen
		move	#2,-(sp)	; get physbase
		trap	#14
		addq.l	#2,sp
		move.l	d0,oldscr
		move.l	#screen,d0	; set screen address
		lsr.l	#8,d0
		move.b	d0,$ff8203
		lsr 	#8,d0
		move.b	d0,$ff8201
		move.l	#screen+(line+2)*160,newscr	; fill screen
		lea	screen,a0
		moveq	#-1,d1
		move	#11499,d0
clsloop:	move.l	d1,(a0)+
		dbra	d0,clsloop
; put some graphics on the screen to show the effect
		move.l	newscr,a6	; pattern on screen
		moveq	#0,d4
kgloop:		lea	box,a0
		move	#15,d7
gzloop:		move.l	a6,a1
		add.l	#230,a6		; 230 bytes per scanline
		movem.l (a0)+,d0-d1
		move	#27,d6
gsloop:		movem.l d0-d1,(a1)
		addq.l	#8,a1
		dbra	d6,gsloop
		addq	#1,d4
		cmp	#35,d4
		beq	gr_end
		dbra	d7,gzloop
		bra	kgloop
gr_end:
		move	#37,-(sp)		; vsync
		trap	#14
		addq.l	#2,sp
		move.b	#2,$ff820a	; 50 Hz
		move.b	#0,$ff8260	; lo-res
		movem.l palette,d0-d7
		movem.l d0-d7,$ff8240
		trap	#14
		addq.l	#2,sp
; install timer B
		move.l	#noborder,$120
		move.b	#0,$fffa1b
		move.b	#line,$fffa21
		move.b	#8,$fffa1b
		move.b	#200,$fffa21
		bset	#0,$fffa07
		bset	#0,$fffa13
		bra 	wait
; well, this is the routine that does the job!
noborder:	movem.l d0-d7/a0-a6,-(sp)
		move	#$2700,sr
		lea	$ff8209,a0	; video address counter low
		lea	$ff8260,a1	; resolution
		lea	$fffa21,a2	; timer B data
		moveq	#0,d0
		moveq	#0,d1
		moveq	#16,d2
		moveq	#2,d3
		moveq	#0,d4
tbsyncloop:	cmp.b	#199,(a2)
		bne 	tbsyncloop
waitloop:	move.b	(a0),d0
		beq.s	waitloop
		sub	d0,d2
		lsl.w	d2,d1
begin:		dcb.w	92,$4e71
		lea	$ff820a,a0	; sync modus
		move	#34,d0		; number of scanlines to be opened
; repeat this for a number of scanlines
lines:		nop
; switch to mono -> obliterate linker border (MMU: OUCH!!)
		move.b	d3,(a1)		; to monochrome
		move.b	d4,(a1)		; to lo-res
		dcb.w	89,$4e71
; 50/60 Hz for right border (NURSE!!!)
		move.b	d4,(a0)
		move.b	d3,(a0)
		dcb.w	13,$4e71
; another 70Hz shock to make it work on all STs
		move.b	d3,(a1)
		nop
		move.b	d4,(a1)
		dcb.w	9,$4e71
		dbra	d0,lines	; end of loop, we've had 512 cycles
		movem.l	(sp)+,d0-d7/a0-a6
		bclr	#0,$fffa0f
		rte
; end of border-obliterating timer B interrupt!!!
wait:		move	#7,-(sp)
		trap	#1
		addq.l	#2,sp
		move.b	#0,$fffa1b
		bclr	#0,$fffa07
		bclr	#0,$fffa13
		move.b	#$51,$fffa1d
		move	#$777,$ff8240
		move	#0,$ff8240+6
		move.b	#1,$ff8260	; midres
		move.b	#2,$ff820a	; 50Hz
		move.l	oldscr,d0
		lsr.l	#8,d0
		move.b	d0,$ff8203
		lsr	#8,d0
		move.b	d0,$ff8201
		move.l	old_stack(pc),-(sp)
		move	#$20,-(sp)
		trap	#1
		addq.l	#6,sp
		clr.w	-(sp)
		trap	#1
		even
old_stack:	dc.l	0
palette:	dc.w	$0000,$0076,$0210,$0650,$0320,$0760,$0540,$0430
		dc.w	$0527,$0111,$0222,$0333,$0444,$0555,$0666,$0333
box:		dc.w	$0001,$0000,$FFFF,$FFFF,$7FFD,$7FFC,$8003,$FFFF
		dc.w	$4005,$7FFC,$8003,$FFFF,$5FF5,$7FFC,$8003,$FFFF
		dc.w	$5015,$701C,$8FE3,$FFFF,$57D5,$701C,$8FE3,$FFFF
		dc.w	$5455,$739C,$8FE3,$FFFF,$5555,$739C,$8FE3,$FFFF
		dc.w	$5455,$739C,$8FE3,$FFFF,$57D5,$701C,$8FE3,$FFFF
		dc.w	$5015,$701C,$8FE3,$FFFF,$5FF5,$7FFC,$8003,$FFFF
		dc.w	$4005,$7FFC,$8003,$FFFF,$7FFD,$7FFC,$8003,$FFFF
		dc.w	$0001,$0000,$FFFF,$FFFF,$FFFF,$0000,$FFFF,$FFFF
		even
oldscr:		dc.l	0
newscr:		dc.l	0
However, this does not work my my Mega STE (in 8Mhz mode of course), and I don't want to debug code that I don't know how is supposed to work... Is there some simple, easy to follow code out there that opens the left/right borders at a certain scanline?
Re: Removing left and right borders
Post by Cyprian »
There are some differences between ST and STE overscan code, also in case of the ST there are 4 a bit different codes due to “wakeup” modes.
Anyway there you can find a couple of them:
ST Synclock demosystem v1.0 by Evil / DHS
https://dhs.nu/files.php?t=democreation
- 400x273 fullscreen (230 byte lw, ST/STe)
- 400x273 fullscreen (224 byte lw, STe)
- 320x265 screen with syncscrolling (ST/STe)
- 400x265 screen with syncscrolling (ST/STe)
Also there are a nice articles by Evil/DHS:
https://dhs.nu/misc.php?t=special&feature=overscan
http://ae.dhs.nu/hatari_overscan/
http://260ste.atari.org
thomas3
Location: the people's republic of south yorkshire, uk.
Post by thomas3 »
This may not work.
But in the label "lines", where is says "NURSE!" as a comment...
Add a nop between the move.bs and change the subsequent dcb to 12 from 13. Those are the timings I use.
EDIT: the timings of the first switch are also a nop different from what I'd use. As Cyprian says, try the code in Evil's demosystem.
Post by Cyprian »
from that topic: https://www.atari-forum.com/viewtopic.php?t=25002
DHS Evil's code :
		move.b	d7,$ffff8260.w			; Left border
		move.w	d7,$ffff8260.w
		dcb.w	90,$4e71
		move.w	d7,$ffff820a.w			; Right border
		move.b	d7,$ffff820a.w
		dcb.w	26,$4e71
James Ingram's code:
		move.b	d3,(a1)			; Left border
		move.b	d4,(a1)
		dcb.w	90,$4e71
		move.b	d4,(a0)			; Right border
		move.b	d3,(a0)
		dcb.w	13,$4e71
		move.b	d3,(a1)			; Stabilizer
		nop
		move.b	d4,(a1)
		dcb.w	12,$4e71
thomas3
Post by thomas3 »
For the ST/STe overscan, the DHS demosys is the same as Ingham's but adds a nop between the first switch moves, then 89 nops, then another nop between the next switch, then 12 nops, then the stabiliser as above. This is the code I use and its stable.
Post by Cyprian »
as @thomas3 mentioned I did some changes and now it should works:
lines:
		; nop
		; dcb.w	89,$4e71
		dcb.w	90,$4e71
thomas3 wrote: Sun Sep 12, 2021 7:38 pm For the ST/STe overscan, the DHS demosys is the same as Ingham's but adds a nop between the first switch moves, then 89 nops, then another nop between the next switch, then 12 nops, then the stabiliser as above. This is the code I use and its stable.
Both codes work but the screen is skewed by 16 pixels between them. The first picture shows that https://www.atari-forum.com/viewtopic.p ... 54#p231254
Post by joska »
Ok, I have updated the timings with the ones from the DHS demosystem. It is working on emulated ST and STE on Hatari, but not on a real STE or emulated or real Mega STE. I currently don't have a working real ST to test on.
Post by Cyprian »
joska wrote: Mon Sep 13, 2021 11:24 am I currently don't have a working real ST to test on.
Evil's code is for the STE only
James Ingram's code is I guess for a dedicated ST's wakeup mode
Post by joska »
No, I used the ST+STE code from DHS demo system. In my case it is not working on real STE/MSTE. So clearly I'm doing something wrong.
Post by Cyprian »
joska wrote: Mon Sep 13, 2021 12:38 pm So clearly I'm doing something wrong
or maybe you have STE (very early) with different timings
Post by troed »
All STEs have the same fullscreen line timings. Early Level 16 (Union Demo) and ST demoscene timings failed removing the left border when run on STE though.
thomas3
Post by thomas3 »
joska - if you updated the timings for the fullscreen lines, did you also change the first string of NOPs before the very first left border removal, after the hardsync?
This will now also be out by one or two nops (assuming the initial timings is OK) - trial and error at this point I'm afraid....
Post by joska »
The problem is not the border-busting code itself, but that the interrupt is not running on real hardware. So something wrong with the ancient TEX code on my 2.06-equipped STE's. I'll look into this later, no use in messing with the timing until this is fixed :)
thomas3
Post by thomas3 »
Looking at the timer B code, I'm surprised it works at all on anything:
		move.b	#0,$fffa1b
		move.b	#8,$fffa1b
		move.b	#200,$fffa21		; <--------------------
		bset	#0,$fffa07
		bset	#0,$fffa13
I've marked the offending line with an arrow -- for some reason, the starting scanline for the timer B is first set as line but then two commands later changed to 200 - outside the visible screen area?!
Post by czietz »
Just a total shot in the dark: Could it be that (for whatever reason) the "interrupt in service" bit is set for Timer B? In that case, no new interrupts would occur until the bit is reset. Try adding a "bclr #0,$fffa0f" to the part of the code where Timer B interrupt is installed.
Post by ijor »
thomas3 wrote: Tue Sep 14, 2021 8:02 am Hi,
		move.b	#0,$fffa1b
		move.b	#8,$fffa1b
		bset	#0,$fffa07
		bset	#0,$fffa13
Each MFP timer has two separate registers. The reload counter and the actual main counter. If the timer is stopped, writing to the the TxDR register modifies both the reload and the main counter. However if the timer is already enabled, then writes to the TxDR modify the reload counter only. The current counter is not modified, not immediately until timing out and "reloaded".
thomas3
Post by thomas3 »
ijor wrote: Tue Sep 14, 2021 9:46 pm Each MFP timer has two separate registers. The reload counter and the actual main counter. If the timer is stopped, writing to the the TxDR register modifies both the reload and the main counter. However if the timer is already enabled, then writes to the TxDR modify the reload counter only. The current counter is not modified, not immediately until timing out and "reloaded".
I'm rubbish at MFP programming - I didn't know this, and this is interesting. In practice, what function does the reload counter perform?
Post by joska »
I also find the MFP hard to understand. A few years ago I finished a 25 year old demo project, and spent quite some time getting the rasters/bottom border removal correctly working on STE and TOS 2. I will just re-use that code instead of trying to understand the TEX code in this example.
Post by ijor »
thomas3 wrote: Wed Sep 15, 2021 8:26 am I'm rubbish at MFP programming - I didn't know this, and this is interesting. In practice, what function does the reload counter perform?
The reload register let you trigger the timer at a constant period, precisely and without need to reprogramming the timer after each timeout. MFP timers can be used for many purposes, not just for interrupts. In the ST, i.e., they are used to produce the serial port baud rate. How could you implement this without some kind reload functionality? Or say, you may want to produce a waveform with variable period. You start the timer with certain period, and while it is counting with the "old" period, you program the reload register with the next period.
Post by joska »
I used the known working interrupt code, the interrupts are now working properly and I can start figuring out the border removal itself :) Right border removal worked first time, but left is still there so I will have to take a closer look at the timings.
Post by troed »
Right border removal needs to be exact (to four cycles precision) so it's the more difficult one. Once you have that, it's a simple case of counting nops until the left border block.
The canonical Level 16 fullscreen line, with care taken for STE and WS2 compatibility of the left border, is:
lea $ffff820a.w,a0
lea $ffff8260.w,a1
moveq #0,d0
rept 274
; cycle 0 - left border
move.w a0,(a1) ; 8
nop            ; 4
move.b d0,(a1) ; 8
dcb.w $4e71,89 ; 356
; cycle 376 - right border
move.b d0,(a0) ; 8
move.w a0,(a0) ; 8
dcb.w $4e71,13 ; 52
; cycle 444 - L16 Shifter stabilizer
move.w a0,(a1) ; 8
nop            ; 4
move.b d0,(a1) ; 8
dcb.w $4e71,12 ; 48
endr
(Written from memory, apologies if there are errors)
I think your left border switch has been too tight in the posted examples. It was a common mistake to make in the beginning of fullscreen lines.
/Troed
Return to “Coding”
