Faulty FDD or Atari 1040 STFM?
Johnnii360
Post by Johnnii360 »
Hi guys,
I want to resurrect my ATARI 1040 STFM at the moment but now I'm stuck. I re-capped the SC1224 monitor and the ST and additionally cleaned the FDD. But the FDD might be faulty - I guess.
Symptom at beginning: The FDD spins and does the sound if there is no floppy in it with an without floppy. Then I put out the PCB and checked the solder points. Nothing found. After that I put it in again and tried something. Now the floppy is dead. Put out again and found a broken solder point. Fixed it and now it's just spinning constantly. When the ST is booting the FDD LED lights up shortly but the head don't do a thing anymore. Only the platter is spinning and don't stop.
It's a TDK model but I have no idea what one.
Here's a photo of it:
Does someone know this issue? It's worth just to re-cap the drive or buy a new used one?
But there's an issue regarding re-capping: The platter PCB is riveted and can't be put out easily.
Edit #1: On main PCB it's print »TDK-T4IV«. On the back sticker is »D357« and »S/N 0014620«. On the upper metal shield is »A 7A26B«.
Edit #2: Correction - The platter PCB can be disassemble. Just the motor is riveted to the PCB.
Best regards,
© Johnny
