SWF player for Atari?
All about the serious stuff.
Post by mosaid »
Hello.
Question, Are there (SWF player) for Atari?
Thanks in advance,
Mohamed
Atari Falcon alive :!:
Re: SWF player for Atari?
Post by Eero Tamminen »
Flash is proprietary (nowadays obsolete) de-facto standard from Adobe, which has had only couple of partially working open source implementations besides the Flash support in web-browsers.
It does vector graphics animation, controlled by Java/ActionScript engine (for historical reasons players actually have two versions of those engines), and includes networked multimedia / video framework. That kind of combination is something that I don't think anybody to expect to work on Atari machines at acceptable speeds, even if by some miracle somebody could add Atari platform support to the those ancient open source implementations.
Moulinaie
Post by Moulinaie »
Eero Tamminen wrote: Wed May 05, 2021 5:16 pm Flash is proprietary (nowadays obsolete) de-facto standard from Adobe, which has had only couple of partially working open source implementations besides the Flash support in web-browsers.
What could be useful is a SWF converter to a format more adapted to Atari.
Guillaume.
Estrayk
Post by Estrayk »
Amiga guys have one with source code. Maybe anyone can tyke a look for a port.
http://aminet.net/package/gfx/show/FlashPlayerSrc
ThorstenOtto
Post by ThorstenOtto »
That is based on one of the opensource libraries @eero mentioned. Even if you can get it to compile and work on Atari, you will never be able to achieve decent framerates on stock machines. And even then, it may be of no much use. If you have a SWF file that is accessible locally, it's much easier to convert it some format that is e.g supported by mplay. If is not accessible locally, and only accessed by some webpage, you can only hope that some webbrowser will support it (and that most likely will be only netsurf, if at all).
Post by simonsunnyboy »
Not to mention that thankfully Flash is not in use anymore.
It was a bogus technology from the start and I never saw a serious website using it. It was always only flashy adverts and fronts but never content.
Post by Cyprian »
If I remember correctly (it was 20 years ago) there was a Flash 3 port for MiNT.
http://260ste.atari.org
Post by mosaid »
Cyprian wrote: Fri May 07, 2021 7:44 pm If I remember correctly (it was 20 years ago) there was a Flash 3 port for MiNT.
Do know where can I found it nowadays?
Post by Cyprian »
nah, unfortunately I'm not able to find any hit about that now
Return to “Applications”
