VT100 cartridge dump?
All about the serious stuff.
Post by czietz »
Does someone have a dump of the VT100 (terminal emulator) cartridge that exists for the Atari ST? Yes, I know that probably any other terminal program is better that this; but still, it would enable me to use a system without any disk drives attached as terminal.
marcello
Re: VT100 cartridge dump?
Post by marcello »
I have the cartridge, how to proceed with the dump ?
STMint, try Unix on your 68000 Atari http://subsole.org/st_mint
beel1
Post by beel1 »
Using CART_IMG.PRG from Steem SSE if you can reach the desktop with the cartridge plugged in?
crashman
Post by crashman »
Here you have it!
Post by czietz »
Thank you very much!
Post by czietz »
PS: Atari tried to make this similar to the VT100 terminal, which makes it a bit unintuitive to setup. It helps to have the DEC VT100 user manual http://bitsavers.informatik.uni-stuttga ... _Jan79.pdf and to know that the "Help" key on the Atari corresponds to the "Setup" key. For example, to change the baud rate, press "Help" to enter setup mode, press "5" to go to the "SETUP B" screen, then repeatedly press "8" to cycle through baud rates. Press "Help" again to exit setup mode.
schlika
Post by schlika »
I am currently testing that same cartridge, but cannot find the documentation, does somebody have a scan ? Still previous post is really helpful, thanks a lot !
Return to “Applications”
