Steem v3.2 Released
A forum for anything about the Steem Engine STE emulator, comments, problems, bug reports etc. Steven Seagal regularly provides updated versions of the original STEem code. The current version is v3.9.4.
Methanoid
Postby Methanoid » Tue Sep 12, 2006 12:51 pm
In the absence of any new versions of STEEM over last 18-24 months does that now mean that there are no bugs left to be fixed and STEEM is "final" ?
aktiv8
Postby aktiv8 » Tue Sep 12, 2006 2:17 pm
I wouldn't say steem is final...
There are still al ot of things whihc have been reported to the authors and things they would like to implement themselves, however - as with a lot of things - real life gets in the way
I dont doubt there will be a new version of Steem appearing in the future, but when - who knows...
So to say again, I wouldn't say steem is final... But as final as it's going to get for a little while
koloth
STeem and USB Joysticks
Postby koloth » Sun Nov 12, 2006 6:51 pm
Greetings!
I just discovered STeem and agree it is great. The information I've found so far acts like joysticks just work. I've configured my joystick in the configuration panel and each direction appears to be assigned when I manipulate the joystick, but when I get into emulation -- Nothing.
Have I missed something ?
SkylineDave
Re: STeem and USB Joysticks
Postby SkylineDave » Mon Nov 13, 2006 9:41 am
koloth wrote:Greetings!
Hi, try switching your scroll lock key on, or from the joystick configuration menu, change to Always On at the top-right.
AKA Megadaz / Black Eagle --- STOS, Dungeon Master and Captive fan!
Proud member of the GameBaseST team.
Founder of the one-man DemoBaseST team!
daeghnao
Postby daeghnao » Mon Nov 13, 2006 3:20 pm
Windows or Linux Steem? USB joystick or something else? Did you remember to make the joystick active in the joysticks dialog?
koloth
Postby koloth » Tue Nov 14, 2006 11:33 am
I'm using Windows Steem and a USB joystick. I've tried all three activation settings. Does the condition (numlock off for example) have to exist before you run STeem or can you change it "on the fly" ?
unseenmenace
Postby unseenmenace » Tue Nov 14, 2006 11:41 am
As far as I recall you can change all joystick settings "on the fly". Does the joystick work with other things?
UNSEEN MENACE
Lynx 2 and Jaguar with JagCD
atarifan2
Postby atarifan2 » Tue Nov 14, 2006 11:13 pm
Hi!
I just had the same problem and figured it out. Make sure you ASSIGN your joystick axes in the Steem joystick menu. Just click on the left box (it goes white) and move your joystick left. Click on the top box and move your joystick up. Keep going for the other two. Don't forget to assign your fire button!
Hope this helps!
koloth
Joystick
Postby koloth » Wed Nov 15, 2006 3:33 am
Yes, I assigned the directions using the joystick and they came up as:
Standard Ports
Port 0 (mouse)
Up = J1Y-
Left = J1X- Right = J1X+
Down = J1Y+
and fire button = J1 But 1
All of which seems reasonable.
Ah, maybe I need to set up Port 1 instead of the mouse!
DUH! :roll: This worked. I should have thought about the ST hardware.
Thanks so much for all your help! :D
Take Care,
Koloth
Argonaut
Postby Argonaut » Wed Nov 15, 2006 8:28 pm
Great work with the new version. The audio is superb now for both the YM and STe digital :-)
Pandino
Postby Pandino » Sun Dec 03, 2006 9:20 pm
Argonaut wrote:Great work with the new version. The audio is superb now for both the YM and STe digital :-)
Yessssss
Da Den Kristne Satte Livet Til
patrick295767
Postby patrick295767 » Fri Dec 29, 2006 3:41 pm
xsteem , I have segmentation fault with xsteem
Is there the sources tar file to make a deb of it ?
NiceGuyUK
Postby NiceGuyUK » Fri Dec 29, 2006 3:46 pm
patrick295767 wrote:xsteem , I have segmentation fault with xsteem
Nope, its not open source at this time. Perhaps you could use gdb to do a trace and post it to the Steem authors?
I've seldom segfaulted it myself - what were you doing at the time?
Also known as Big Boss Man of Demografica
Dew-It
Postby Dew-It » Wed Mar 28, 2007 1:50 am
Can Catweasel 4 be use with Steem? If not are there any plans in the future for support of Catweasel 4 in Steem? I just bought a Catweasel 4 and I'm awaiting shipment of it. Want to see try Atari ST disks with it on my PC.
Have you played Atari Today?
sinbad
Re: Steem v3.2 Released
Postby sinbad » Sat Sep 20, 2008 6:26 am
Considering the age of these posts, am I to guess STEem is no longer being developed and if so, are any ST emulators still under development?
Just out of interest really..
Postby simonsunnyboy » Sat Sep 20, 2008 7:27 am
Hatari is opensource and still under development.
SkylineDave
Postby SkylineDave » Sat Sep 20, 2008 7:47 am
blimey i had a heart flutter then until i looked at the number again! :(
KLund1
Postby KLund1 » Wed Dec 23, 2015 8:26 am
Just loaded Steem 3.2 for the first time in a very long time. This time on my main win7 x64 machine.
After the ST desktop appears, I move my mouse and the ST crashes. I see this, and hear a few hundred ST mouse clicks. There is a lot of cazy distortion at the top white area I can't capture to show. Sometimes I think I can see 4 bombs as 2 pixle dashes.
The ST resets and a scroll accross the bottom says something like ST Crash and Reset. I looked in the settings but nothing jumped out as some way to fix this. I'm sure I'm doing something stupid.
Suggestions?
Postby Cyprian » Wed Dec 23, 2015 9:04 am
KLund1 just try the newest one v3.7.3: http://ataristeven.exxoshost.co.uk/Steem.htm
KLund1
Postby KLund1 » Tue Jan 12, 2016 4:36 am
Fixed,
My ROM images were bad. Got new ones, all good, now. running 1.62us
Next noob Question; how to get a hard drive on the desktop? I have a directory made with "Disk Manager" in steem. I reboot the "ST" no hard drive on the desktop. I seem to recall Steem up one there automatically. i installed one on the desktop, but that did not work. Do I need to go through the HDDriver install process ... I hope not. I looked for DOC's on this but could not find much for Steem.
KLund1
Postby KLund1 » Tue Jan 12, 2016 4:40 am
Also how can I get non copy protected files from an ST image into regular files I can put on my SD card HD for my real ST?
Postby AtariZoll » Tue Jan 12, 2016 8:51 am
You need to create "hard drive" - Disk Menu - Hard Drives - choose some directory for Atari files. Then can copy there from floppy images via Steem.
Of course, will need first to set drive icons on Desktop.
Other, faster way may be using this: http://atari.8bitchip.info/floimgd.php
Moggy2001
Postby Moggy2001 » Sun Jan 24, 2016 5:15 pm
i love the steem emu, its easy to use and plays everything ive put on it, this emu is the reason i bought a st :)
Return to “Steem”
