Texel sources available
All about the serious stuff.
8bitguy1
Re: Texel sources available
Postby 8bitguy1 » Thu Mar 05, 2020 3:32 am
so is there a full english version of 2.3?
Postby Cyprian » Thu Mar 05, 2020 7:29 am
mikro wrote:
ThorstenOtto wrote:using different names for the functions makes it impossible to load sheets created by the german version with the english app, or vice versa. I think only the descriptions should be translated there, but not the function names.
IIRC this is "normal" - MS Excel works the same way, at least I remember seeing translated function names for SUM(), AVERAGE() etc in its Slovak flavour (and yes, it looked super weird).
ms excel shows function's name in local language but internally still uses its own function ID.
It means when I open foreign (e.g. created in German) document I'll see local (Polish in my case) function names.
Portfolio / Lynx II / Jaguar / TT030 / Mega STe / 800 XL / 1040 STe / Falcon030 / 65 XE / 520 STm / SM124 / SC1435
TheNameOfTheGame
Postby TheNameOfTheGame » Thu Mar 05, 2020 12:37 pm
That's the right way to do it imo.
sashapont
Postby sashapont » Sat Mar 21, 2020 7:55 pm
Is it possible to compile it for firebee?
Atari Falcon, Firebee
ragnar76
Postby ragnar76 » Sat Mar 21, 2020 10:00 pm
imho: i dont think that pure pascal has a coldfire target but i could be wrong but i would be happy to see it to :)
gstoll
Postby gstoll » Sun Mar 22, 2020 6:09 am
sashapont wrote:Is it possible to compile it for firebee?
Not with Pure Pascal. It support only 68000, 020/03.
8bitguy1 wrote:so is there a full english version of 2.3?
Not full english, but the most text are also in english.
vido
Postby vido » Sun Mar 22, 2020 7:39 am
Old versions of Texel works ok with 68kemu on the FireBee.
I believe new versions of Texel will work the same.
Did you try with 68kemu?
sashapont
Postby sashapont » Sun Mar 22, 2020 8:17 am
no :( New version is hang
vido
Postby vido » Sun Mar 22, 2020 8:49 am
sashapont wrote:no :( New version is hang
It works on my FireBee really nice!
PeterS
Postby PeterS » Sun Mar 22, 2020 10:01 am
Many years ago I switched from NAES to Xaaes and the Texel radio buttons and some other dialogue box things don't work properly.
I think it is a clash between ObjectGEM and Xaaes but it would be nice to see a fix somewhere.
ragnar76
Postby ragnar76 » Sun Mar 22, 2020 9:41 pm
so, someone has build a release yet?
vido
Postby vido » Mon Mar 23, 2020 9:51 am
ragnar76 wrote:so, someone has build a release yet?
Yes you can find link to the binnaries in this thread.
ragnar76
Postby ragnar76 » Mon Mar 23, 2020 10:47 am
Oh, yes. Didnt See it
vido
Postby vido » Mon Mar 23, 2020 12:14 pm
Did you try again?
If it still dont work copy 68kemu into texel directory and drop texel binaries to 68kemu with the mouse.
That way it works in my case.
ragnar76
Postby ragnar76 » Mon Mar 23, 2020 2:00 pm
Did you try again?
I've tested it a few times and it's not working reliable on my firebee. Without 68kemu it just crashes and gives me an alertbox. with 68kemu it sometimes work but very often the firebee just hangs and in worst cases i get a black screen and i have to turn it off, wait a few seconds and start it again.
Postby joska » Mon Mar 23, 2020 2:04 pm
Looks like vido is using MyAES and not XaAES. As Peter pointed out, Texel does not work properly under XaAES.
vido
Postby vido » Mon Mar 23, 2020 2:20 pm
joska wrote:Looks like vido is using MyAES and not XaAES. As Peter pointed out, Texel does not work properly under XaAES.
Oh, yes. As Joska says ... I am using MyAES mostly.
And I dont use Texel much but for now I dont have problems with it under 68kemu.
PeterS
Postby PeterS » Mon Mar 23, 2020 5:46 pm
I just tried the download of Vn 2.3 on the Milan with XaAES and it looks like the dialogue issues have been fixed. They look more like normal OS radio buttons and check boxes. This is good news.
I had opened a few files from the menu but when I hit ctrl-O it locked up. Mouse movement only.
gstoll
Postby gstoll » Mon Mar 23, 2020 6:50 pm
PeterS wrote:I had opened a few files from the menu but when I hit ctrl-O it locked up. Mouse movement only.
Do you see the fileselector or when it locked up?
PeterS
Postby PeterS » Mon Mar 23, 2020 10:21 pm
Hmm good question. I can't remember.
I tried to repeat it but couldn't get it to happen again.
Previously I had been testing the behaviour with ctrl-insert and ctrl-shift-insert.
sashapont
Postby sashapont » Tue Mar 24, 2020 7:06 am
Did you try again?
Yes it works with 68kemu. Thank you!
PeterS
Postby PeterS » Tue Mar 24, 2020 6:28 pm
PeterS wrote:Hmm good question. I can't remember.
There was no file selector on the screen when it froze.
ThorstenOtto
Postby ThorstenOtto » Wed Mar 25, 2020 11:37 am
The system unit of PP seems to have a similar problem in _fillchar than the memset() function of PureC:
_fillchar:
[0000083a] 4a80                      tst.l      d0
[0000083c] 6f00 00cc                 ble        $0000090A
[00000840] d1c0                      adda.l     d0,a0
[00000842] 1f01                      move.b     d1,-(a7)
[00000844] 341f                      move.w     (a7)+,d2
[00000846] 1401                      move.b     d1,d2
[00000848] 3202                      move.w     d2,d1
[0000084a] 4841                      swap       d1
[0000084c] 3202                      move.w     d2,d1
That pushes a byte on the stack, then pops a word. The 68k decreases the SP by 2 when pushing a byte on the stack, so this is essentially the same as shift left by 8. However, iirc this gives problems when run on coldfire. At least, for Pure-C, i'm using a patched version of pcstdlib.lib.
It could be patched by replacing
1401                      move.b     d1,d2
by
1401                      move.b     d1,d2
e18a                      lsl.l      #8,d2
1401                      move.b     d1,d2
vido
Postby vido » Wed Mar 25, 2020 12:48 pm
ThorstenOtto wrote:That pushes a byte on the stack, then pops a word. The 68k decreases the SP by 2 when pushing a byte on the stack, so this is essentially the same as shift left by 8. However, iirc this gives problems when run on coldfire. At least, for Pure-C, i'm using a patched version of pcstdlib.lib.
Just theoretical question Otto.
Is such way possible to replace coldfire unfriendly asm commands?
gstoll
Postby gstoll » Wed Mar 25, 2020 2:13 pm
Now I am a bit confused. Did ist happen all time or only sometimes.
ThorstenOtto wrote:At least, for Pure-C, i'm using a patched version of pcstdlib.lib.
I patched my SYSTEM.PPU. We will see, when I make a new version.
Return to “Applications”
