All FreeMiNT builds again available and more!
TheNameOfTheGame
Re: All FreeMiNT builds again available and more!
Postby TheNameOfTheGame » Tue Apr 02, 2019 3:00 pm
Well I put the MINT-36C.PRG as the last program in my AUTO folder and copied the MINT folder over to the C-boot drive.
It starts to load MiNT, but hangs at the MFP serial driver...here is a screenshot. What should I do to get it to boot? This is on a Hades060.
frank.lukas
Postby frank.lukas » Tue Apr 02, 2019 4:53 pm
Is it possible that that the network are not working well with the 000 package. I can not make the Network working with the 36C and the USB ASX0 or with a Netusbee enec.xif ...
Postby mikro » Tue Apr 02, 2019 6:10 pm
TheNameOfTheGame wrote:Do I just move these to my hard drive and boot? I notice in the AUTO folder is "mint-36c.prg". But in the "mint/1-19-36c/" folder there is a "mint060.prg". Does the AUTO folder program call the other file?
Yes and yes. :)
Not sure about NVDI situation on Hades but I guess it wont hurt to have it present in AUTO (before mint-36c.prg). Let us know how it went!
EDIT: Oh, you already did. Well, as the first step, try to disable all modules and then enable them one by one. I'm not sure when was the last time somebody tried the latest kernel on a Hades, so it's possible something is not working. It is enough just to rename *.XDD to *.XDX, *.XFS to *.XFX and *.XIF to *.XIX. In both c:\mint\1-19-36c and c:\mint\1-19-36c\hades.
Postby mikro » Tue Apr 02, 2019 6:21 pm
frank.lukas wrote:Is it possible that that the network are not working well with the 000 package. I can not make the Network working with the 36C and the USB ASX0 or with a Netusbee enec.xif ...
Everything is possible. :) Did it work before? (i.e. did you just replace your c:\mint\1-19-cur without any configuration change?)
If so, try to attach some logs / photos.
dhedberg
Postby dhedberg » Tue Apr 02, 2019 6:39 pm
Thanks mikro! Perhaps it's time for me to finally have a go at mint now when I have a TT with plenty of TT-RAM.
frank.lukas
Postby frank.lukas » Tue Apr 02, 2019 7:11 pm
The asix.xif works not with my Mega STE before in 2018 with the Lightning VME. At the time I test with a Lightning ST at a Atari Mega ST not MSTE and it do not work. Also it works not with a Netusbee enec.xif for test.
When I start in a shell ping one line is coming up and than nothing happens anymore.
mint.cnf ...
# USB
exec u:/c/mint/1-19-36c/usb/loader.prg
# Network
exec u:/c/mint/1-19-36c/sysroot/bin/ifconfig.ttp en0 addr 192.168.2.14 netmask 255.255.255.0 up
exec u:/c/mint/1-19-36c/sysroot/bin/route.ttp add default en0 gw 192.168.2.1 metric 1
# The "exec" command is used to launch programs. Note that programs
# so launched are started before GEM is, so they must be TOS/TTP
# programs.
# Start Draconis to MiNT-Net gateway
#exec u:/c/mint/mgw.prg
#echo
# Start Gluestik
#exec u:/c/mint/gluestik.prg
#echo
# NFS Mount
exec u:/c/mint/1-9-36c/sysroot/bin/nfsmount.ttp -v -o rw,rsize=1024,wsize=1024,retrans=10 192.168.2.118:/Users/frank/Downloads/Atari /nfs/MacPro
Postby mikro » Tue Apr 02, 2019 7:34 pm
frank.lukas wrote:The asix.xif works not with my Mega STE before in 2018 with the Lightning VME.
Hmm, so it did work with a kernel from 2018? Do you know which build exactly? If so, it looks like some USB regression, something which David (Galvez here on AF) will be certainly happy to hear about. :) If you can provide more details about the working build/setup, it's a good idea to report it here: https://github.com/freemint/freemint/issues
Kroll
Postby Kroll » Tue Apr 02, 2019 8:39 pm
@TheNameOfTheGame, @mikro:
Yes exactly, on my Hades I had to rename MFP.XDD to MFP.XDX
TheNameOfTheGame
Postby TheNameOfTheGame » Tue Apr 02, 2019 10:21 pm
Kroll wrote:@TheNameOfTheGame, @mikro:
Ok, thanks...and what is the implication of that? Does it cause some loss of functionality?
TheNameOfTheGame
Postby TheNameOfTheGame » Tue Apr 02, 2019 11:12 pm
Ok, renamed MFP.XDD to MFP.XDX and the system boots up to teradesk. However, when I selected the teradesk "about" dialog the system had a total lockup. See associated picture.
frank.lukas
Postby frank.lukas » Wed Apr 03, 2019 5:37 am
The Network do also not work with a 2018 000 kernel. It is not a USB thing because I test it also with a netusbee and it do not work ...
Postby mikro » Wed Apr 03, 2019 6:17 am
TheNameOfTheGame wrote:Ok, renamed MFP.XDD to MFP.XDX and the system boots up to teradesk. However, when I selected the teradesk "about" dialog the system had a total lockup. See associated picture.
Nice. :-)
Is this with NVDI installed? If yes, try to disable other (non-essential) AUTO programs/ACCs. Also, when you see the FreeMiNT boot message, press shift and try to disable memory protection (not nice but if it works, it will give us a hint).
About MFP.XDD: actually, you can read the current state in https://github.com/freemint/freemint/bl ... /ports.txt -- unknown. ;) I erroneously assumed that serial ports in Hades are Atari compatible but they are not: http://www.medusacomputer.com/thes-hades.html. I have disabled it for Hades builds for now. In practice, you wont see the serial ports in u:/dev.
If you have any technical information about the ports (where they are mapped and what circuit they are using), maybe we can do something about it (for the Milan there is a special UART version).
Postby mikro » Wed Apr 03, 2019 6:22 am
frank.lukas wrote:The Network do also not work with a 2018 000 kernel. It is not a USB thing because I test it also with a netusbee and it do not work ...
Can you find any kernel (even as old as 1.18: https://github.com/freemint/freemint/releases) which works for you? I can't test the build on any ST machine right now.
Galvez
Postby Galvez » Wed Apr 03, 2019 7:53 am
We hit the same issue the last year with the ROM-port Ethernet adapter, this confirms that the problem was not in the driver but in the 000 kernel.
viewtopic.php?f=15&t=33189&p=343103#p343508
frank.lukas
Postby frank.lukas » Wed Apr 03, 2019 11:01 am
I will hope it can be fixed !
For such a long time it are not working with the 000 package
The 1-18 package has no inet.xdd and the whole cpu typ folders 000, 030 and so on are all empty ...
TheNameOfTheGame
Postby TheNameOfTheGame » Wed Apr 03, 2019 2:37 pm
Nice. :-)
Yes, Nova-VDI is installed with NVDI for GDOS support. I will back out some of the AUTO folder programs/ACCs as you suggest.
As for the Hades MFP, there is some technical information in the DOKUE101.TXT file in the memory map section:
FFFFFA00 - FFFFFA3F  rw   STMFP like with the ST and TT:
                            IO0: Printer Busy
                            IO1: DCD Modem 1
                            IO2: CTS Modem 1
                            IO3: Interrupt ISA 1
                            IO4: Interrupt ACIAs
                            IO5: Interrupt IDE
                            IO6: RI Modem 1
                            IO7: Interrupt ISA 2
FFFFFA80 - FFFFFABF  rw   TTMFP like with the TT:
                            IO0: Interrupt PCI 1
                            IO1: Interrupt PCI 2
                            IO2: Interrupt PCI 3
                            IO3: RI Modem 2
                            IO4: Floppy Interrupt
                            IO5: Interrupt PCI 4
                            IO6: Clock Interrupt
                            IO7: SCSI Interrupt
frank.lukas
Postby frank.lukas » Wed Apr 03, 2019 2:55 pm
3 ping packs going out and than it stop
I had the network in 2/2016 working with a Atari Mega ST but I have not longer the files ...
-> https://forum.atari-home.de/index.php/t ... #msg203880
Postby mikro » Wed Apr 03, 2019 4:10 pm
frank.lukas wrote:The 1-18 package has no inet.xdd and the whole cpu typ folders 000, 030 and so on are all empty ...
Maybe you didn't look into 'drivers' folder? All modules are compiled for 68000 so don't worry about CPU builds. 1.18.0 was released in 2013, so if you had a working setup in 2/2016, there is a good chance this will work. And it will give us something to start with.
Ah, I see what you mean: you downloaded a 1.18 branch build, not 1.18.0 release from the link I have provided. So please try that instead. :)
Postby mikro » Wed Apr 03, 2019 4:13 pm
TheNameOfTheGame wrote:As for the Hades MFP, there is some technical information in the DOKUE101.TXT file in the memory map section:
                            IO0: Printer Busy
                            IO1: DCD Modem 1
                            IO2: CTS Modem 1
                            IO5: Interrupt IDE
                            IO6: RI Modem 1
                            IO3: RI Modem 2
                            IO7: SCSI Interrupt
This is perhaps why I thought it has Atari compatible serial ports - it has the MFP, all right but most likely not connected to the serial ports which are wired differently (UART?).
frank.lukas
Postby frank.lukas » Wed Apr 03, 2019 5:49 pm
1-18-cur do not work because xaaes is not running.
AESSYS fatal error
ILLEGAL INSTRUCTION
I give up !
Postby mikro » Wed Apr 03, 2019 6:06 pm
Frank: can you at least try that networking? You can try ping without xaaes... (just specify INIT=/c/path/to/bash in mint.cnf). The 68000 build has been long without any attention so it's no surprising it's not working 100%. But without users willing to test things nothing is going to improve.
Btw, the 1.18x snapshot should be complete, this whole time it was using a broken script and nobody has noticed. So you see, it's not very well tested nor used.
frank.lukas
Postby frank.lukas » Wed Apr 03, 2019 6:55 pm
mint.cnf = INIT=u:/bin/bash
ping do not work. One line and than nothing with 1-18-0 and 36c ...
Postby mikro » Thu Apr 04, 2019 6:28 am
Well, in that case networking is really screwed. If you had it working in 02/2016, that must have been some of the daily builds from freemint.org. Maybe I can make you a custom 68000 build from around that era if you would be so kind to test it.
You may also want to try 1.17.0 (https://github.com/freemint/freemint/re ... int-1_17_0) and 1.16.1b (https://github.com/freemint/freemint/re ... eta-1_16_1).
frank.lukas
Postby frank.lukas » Thu Apr 04, 2019 7:06 am
I use always all the trunk stuff with the helmut kernel in 2/2016 because of the TOSFS in the helmut kernel.
frank.lukas
Postby frank.lukas » Thu Apr 04, 2019 8:37 am
I check it cross with the 1-19-36C on a Atari Mega STE and the Network works fine with ASIX.XIF and a Lightning USB VME Interface. The kernel is hanging when SCC.XDD are loading otherwise it is working fine.
