New CT60 Boot ROM 1.05
TheNameOfTheGame
Re: New CT60 Boot ROM 1.05
Postby TheNameOfTheGame » Thu Sep 12, 2019 12:07 pm
emcclariion wrote:Just before I cock this up, there are 3 bin files which one do I use ?
I assuming I use flash060 in 60 mode ?
flash060 is used in 030 mode.
From what I understand 'A' bin file is the normal bin and 'B' and 'C' are for those who have SuperVidels and are having issues (not sure why there are 2, but for some people B might work better than C).
Estrayk
Postby Estrayk » Wed Sep 18, 2019 10:20 pm
I flashed without any issues, Thanks !!!!
Estrayk
Postby Estrayk » Wed Sep 18, 2019 10:54 pm
Oh! oh! Bad news! Just for curiosity, playing with the new menus I set the speed to 66Mhz, instead 66,6Mhz and ct60e doesnt boot now. How can I reset the speed value?
In 030 mode it boots but When I try to change the speed with "ct60 config" it shows:
FOR PROGRAM THE CLOCK GENERATOR WITHOUT THE CT60, YOU MUST CONNECT THE MODULE ON MODEM2!
EDIT:
(SOLVED) I change the speed to 90Mhz and it works! like this post:
http://atari-forum.com/viewtopic.php?f=97&t=35542
Can be a bug, check it, minimum value should be 66,6Mhz, not 66Mhz.! thx.
TheNameOfTheGame
Postby TheNameOfTheGame » Thu Sep 19, 2019 12:29 am
Estrayk wrote:I flashed without any issues, Thanks !!!!
Awesome! Nice to hear, glad you were successful. :cheers:
insane
Postby insane » Thu Sep 19, 2019 8:43 am
"Can be a bug, check it, minimum value should be 66,6Mhz, not 66Mhz"
Depends. Do you use a supervidel?
My supervidel-less CT60 runs at 50Mhz f.e.
.tSCc. - low-tech atari cyberpunks since 1990 | http://insane.tscc.de
Estrayk
Postby Estrayk » Thu Sep 19, 2019 1:42 pm
insane wrote:"Can be a bug, check it, minimum value should be 66,6Mhz, not 66Mhz"
nope. Falcon+ct60e only.
Anyway, will be so cool that pressing any combinations of keys at boot or something, it will reset ct60e nvram and all config for these kind of problems.
you think that can be done @insane?
insane
Postby insane » Thu Sep 19, 2019 1:53 pm
Wouldn't help - as when the CTCM malfunctions the 060 wouldn't work at all - so nothing could react to any keypresses :/
Maybe it is somehow possible to program the CTCM from 030 mode - i doubt that but i'll try to find sth.
insane
Postby insane » Thu Sep 19, 2019 2:00 pm
Addendum: There already is some clock reset code in the CT60 bios: Holding ALT+Control on boot seems to reset the Clock speed. (untested)
Estrayk
Postby Estrayk » Fri Sep 20, 2019 1:31 pm
insane wrote:Addendum: There already is some clock reset code in the CT60 bios: Holding ALT+Control on boot seems to reset the Clock speed. (untested)
I didnt know that. thanks insane!
patjomki
Postby patjomki » Sun Dec 01, 2019 4:50 pm
insane wrote:It is made for CTPCI-less CT60,CT63 and CT60e.
Use the A version if you don't have any SuperVidel installed; use B or C if you have.
If you make a mistake you can always flash from 030 mode.
I want to give this version a try. At the moment I have the following version installed (but no ctpci, that was planned but now my ct63 is back in the falcon's original case):
Boot v2.02 beta 15 11/05/2014 22:58
I am a little bit unsure which version to try. The documentation says:
"For some SV users CT60tosA works, for others CT60tosB" but above you say B or C. As I have a supervidel installed I want to make sure to have the correct version.
I also have two strange problems with my ct63 and hope that this version fixes the problems.
1) ide mass storage > 128GB (yes, GB) do not work correctly. I tried it with the latest HDDRIVER 10.17 and a test-version that Uwe Seimet provided. Up to 128GB everything is running fine.
2) floppy disk access lets the falcon crash in particular when I try to copy something to a floppy and it is write protected. The ATARI tells me that "Floppy Disk Drive A: is write protected, Cancel, Retry". If I press Cancel, the ATARI freezes, if I try Retry without removing the write protection the same alert box appears again and I can press Retry for several times until it freezes as well.
Do you think these problems will disappear with Boot ROM 1.05?
Return to “CT60 / CT63 Area”
