14mb board (various docs, pinout, ctr14 gerber files)
djbase
Re: 14mb board (various docs, pinout, ctr14 gerber files)
Postby djbase » Mon Jul 05, 2010 6:20 pm
I am alive but things will go slowly these days. Its summer you know. :wink:
Saturnin51
Postby Saturnin51 » Mon Jul 26, 2010 1:47 pm
OK I stay in stand by !
I have found one card. It' OK for me.
Falcon 030-14 Mo - FDI Steinberg -Soundpool Analog 8 - SMP24 - Cubase Audio Falcon 2.06 dongle - SC55 - SG64 - Yamaha CBX-T3
jok
Postby jok » Sat Oct 19, 2013 10:18 am
hi simbo, i am definitely interested in 2 of these!
viking272
Postby viking272 » Wed Feb 12, 2014 12:22 am
Great work! Sounds like a great board Simbo.
Perfect for those that missed this one on ebay - check out the final bid price!
http://www.ebay.co.uk/itm/Atari-Falcon-14MB-Memory-Expansion-/131101504792
HuggyOne76
Postby HuggyOne76 » Fri Feb 21, 2014 3:18 pm
Yeeeeeeeeeaaaaaaaaahhhhhhhhh !
Hope that will be real ! Interrested too !
patbud
Postby patbud » Wed Aug 06, 2014 7:02 am
I am a newcomer to the atari forum. I found back my falcon 030 I bought in 1993 and I am looking for a RAM extension. I would be interested in buying one board if possible.
Thanks a lot to everybody who could help me.
best
patbud
Altstar
Postby Altstar » Wed Oct 15, 2014 7:41 am
Does anyone have a copy of the Gerber files? Looks like the site hosting them (one of the first posts) is down.
JustinPayne
Postby JustinPayne » Sun Nov 16, 2014 6:33 am
Any luck hunting those files down?
stryker1983
Postby stryker1983 » Sun Dec 14, 2014 2:43 am
simbo2 wrote:here is the completed pcb and schematics pdf / project files for proteus vsm you can load into their demo on labcenters site
eventually got it too route correctly
now!!!
tidy phase two days {{ completed :) }}
where i make it look pretty and work around any miss tracking
widen what i can in relief try avoid washing effects
dont want them to dis in the etch {add thicker tracks where pos and balance the ground planes}
proteus vsm router is mega stupid
and i prefer to route it by mind as i did here
no auto route it just does not work as well as a brain !!!!
youll notice the chip sequence is 43215678
as doing it 12345678 isnt possible
9 hrs so far and plenty of coffee
its sad when you cant add a via under a top side pad {vcc or ground}
i would like to do this but cant
even v8 is poo i use v7.1 sp0 its where my license ends v8 is terrible they stone washed the app...
5 parts
lots of solders , 1xpcb ,2x connectors, 8xchips , 16x bi-pass capacitors 1X electrolytic
28 components a lean build
Hi!
simbo2
Gerber files with bugs:
- capacitors (type 0402 ???)
- connectors - does not fit pins on the board
I ordered the PCB which will go to the trash ;-)
Arne
Postby Arne » Wed Jan 03, 2018 4:35 pm
I have been manufacturing a new batch of 14MB RAM expansions. Available in my shop.
Postby mikro » Fri Feb 09, 2018 11:57 am
Altstar wrote:Does anyone have a copy of the Gerber files? Looks like the site hosting them (one of the first posts) is down.
Not anymore. ;)
http://powerphenix.com/rodolphe.czuba.f ... museum.htm
http://powerphenix.com/rodolphe.czuba.f ... Layout.zip
toarnold
Postby toarnold » Wed Feb 14, 2018 11:22 am
Not anymore. ;)
But these gerber files are in an old gerber format RS-274-D. This format isn't accept be itead, seeedstudio etc. We need RS-274-X
Postby mikro » Wed Feb 14, 2018 10:32 pm
toarnold wrote:But these gerber files are in an old gerber format RS-274-D. This format isn't accept be itead, seeedstudio etc. We need RS-274-X
In that case, fire up your favourite time machine and talk to Rodolphe to change them. ;)
Altstar
Postby Altstar » Mon Feb 19, 2018 1:22 am
I'll look into redoing it in Eagle. To many projects, not enough time ....
toarnold
Postby toarnold » Mon Feb 19, 2018 11:56 am
Altstar wrote:I'll look into redoing it in Eagle. To many projects, not enough time ....
I'm not an experienced eagle user, but I have done my best. Attached is a schematic, with a (german :angel: ) description how to connect. ECC modules are not supported. 16MB is fixed. 4MB doesn't make sence in my opinion.
-toarnold
mpattonm
Postby mpattonm » Mon Jul 23, 2018 12:27 pm
...and this is how the board could look like.
rj1307
Postby rj1307 » Mon Oct 15, 2018 8:12 pm
Here is a module designed by me. Tested with CT60.
Image Image
Under this link Atari_Falcon_14MB.zip I share the project in Eagle, Gerbery and a list of working memory chips.
cron
