MagiC/MagiCMacX source updated
ThorstenOtto
Re: MagiC/MagiCMacX source updated
Postby ThorstenOtto » Fri Dec 21, 2018 6:45 pm
Okay, going a bit offtopic, but: NTFS does allow to delete an open file. Its the Windows layer that forbids this. They are not identical, eg. Windows allows only 260 char long pathnames, while NTFS can handle up to ~64K. Without this, POSIX layers like MS own subsystem or cygwin would not work.
And the Windows layer does those checks only, because they decided to make it compatible to MSDOS/CPM, where the GEMDOS also derives from.
dhedberg
Postby dhedberg » Fri Dec 21, 2018 6:54 pm
Yes. NTFS is not a bad fs but the Windows layer cripples it in many ways. Not making any distinction between lower- and upper-case letters is another one. It's kind of amusing to see how confused Windows gets in this case.
ThorstenOtto
Postby ThorstenOtto » Sat Jan 12, 2019 9:28 am
There had been some notable updates recently, including automated builds (see link in the first post). Stay tuned!
mpattonm
Postby mpattonm » Sat Jan 12, 2019 11:04 am
Wonderful! Pretty please, keep it up!
BTW The commits list is impressive. I see lot of effort towards CT60, does it mean we can expect CT60 test builds soon? :)
ThorstenOtto
Postby ThorstenOtto » Sat Jan 12, 2019 11:36 am
According to a user of the german forum, they should work already. He used magic_p.tos to patch the resulting magic.ram (source included, but not currently build; has to be verified if that still is needed) and a slightly modified version of the ct60 specific boot program (also not currently build, but that will change soon), the ct60new.s in the kernel/bios/atari/boot folder. With those, he successfully booted MagiC.
Postby Cyprian » Sat Jan 12, 2019 12:01 pm
Hey Otto,
What does this message means?
It is from Steem. I prepared an empty hard disk partition,and I copied then content of "EN" folder from "magicmac-20190112-090039-bin.zip":
https://bintray.com/th-otto/magicmac-fi ... /snapshots
Ektus
Postby Ektus » Sat Jan 12, 2019 12:17 pm
ThorstenOtto wrote:According to a user of the german forum, they should work already. He used magic_p.tos to patch the resulting magic.ram (source included, but not currently build; has to be verified if that still is needed) and a slightly modified version of the ct60 specific boot program (also not currently build, but that will change soon), the ct60new.s in the kernel/bios/atari/boot folder. With those, he successfully booted MagiC.
That would be me. Haven't done any more testing yet, but the machine is up and running, CTPCI and all. That's with the build from post https://forum.atari-home.de/index.php/t ... #msg235546
Regards
Ektus.
ThorstenOtto
Postby ThorstenOtto » Sat Jan 12, 2019 12:58 pm
Cyprian wrote:Hey Otto,
It means that
  • there are still some messages that need to be translated ;)
  • The *.OSD driver was not found when initializing the VDI. I have this error occasionally when running an emulator on a harddisk image that is also mounted in linux. Make sure that is not the case. Otherwise: how was STeem configured (which machine type, resolution etc?)
ThorstenOtto
Postby ThorstenOtto » Sat Jan 12, 2019 3:38 pm
There were some minor mistakes in the layout (themes & pat folder ended up in the wrong location), these are now fixed. But that should not prevent the system to work.
I have uploaded now also a ~16MB sample Harddisk image populated with the english version, that works in Hatari & Aranym. Maybe that should give you also a start for SteeM.
ThorstenOtto
Postby ThorstenOtto » Sat Jan 12, 2019 3:42 pm
oops, duplicate post deleted.
Postby Cyprian » Sat Jan 12, 2019 6:41 pm
Thanks for preparing harddisk image.
I've checked with Hatari 2.1.0 and Steem 3.9.4 (both with EmuTOS 0.9.10) and both of them shows me:
ant then:
ThorstenOtto
Postby ThorstenOtto » Sat Jan 12, 2019 8:29 pm
I don't use Steem, so i can't tell how to set up a harddisk image there. For Hatari it should work however, at least with recent versions on linux. Same for Aranym (where the last official release is quite old). In both cases i'm using current (snapshot) versions.
Maybe for Steem you could try attaching it as a 2nd Harddisk first, and boot from some already working one, to check whether it is recognized at all. It's just a normal partition table with only a single partition in it.
TheNameOfTheGame
Postby TheNameOfTheGame » Sat Jan 12, 2019 8:41 pm
In Steem, I have to use an ASCI drive image for MagiC, could't work with GEMDOS (host system) drive. I believe when the ASCI drive is enabled, GEMDOS drives have to be disable for MagiC to work. Just trying to remember off the top of my head.
Postby Cyprian » Sat Jan 12, 2019 8:59 pm
ThorstenOtto wrote:I don't use Steem, so i can't tell how to set up a harddisk image there. For Hatari it should work however, at least with recent versions on linux. Same for Aranym (where the last official release is quite old). In both cases i'm using current (snapshot) versions.
I'm using Windows, maybe there is something different in how Hatari manages disk image between both systems.
I'll let Hatar and Steem SSE team know about my issue.
Is it ACSI or IDE image?
ThorstenOtto wrote:Maybe for Steem you could try attaching it as a 2nd Harddisk first, and boot from some already working one, to check whether it is recognized at all. It's just a normal partition table with only a single partition in it.
Will try
TheNameOfTheGame wrote:In Steem, I have to use an ASCI drive image for MagiC, could't work with GEMDOS (host system) drive. I believe when the ASCI drive is enabled, GEMDOS drives have to be disable for MagiC to work. Just trying to remember off the top of my head.
I have disabled GemDOS emulation. I can see HD driver message (as posted above) therefore EmuTOS and TOS boots ACSI image.
TheNameOfTheGame
Postby TheNameOfTheGame » Sat Jan 12, 2019 9:06 pm
ASCI image. I have a blank 1GB hdd image if you need it. Then load HDDriver as a floppy image .ST and partition the drive image and install the driver, then do the same for MagiC, etc. I also used a program- PP's Drive Imager v1.35 to put zip files on the drive so I could install software easier, but had to use a VirtualBox linux install as it only works on linux I think. http://atari.8bitchip.info/drimlus.php
TheNameOfTheGame
Postby TheNameOfTheGame » Sat Jan 12, 2019 9:20 pm
Btw, I'm using Steem 3.8.0 win32. Not sure if newer versions have changed anything.
TheNameOfTheGame
Postby TheNameOfTheGame » Sun Jan 13, 2019 1:20 am
Eh, 3 posts in a row...sorry. Here is the blank drive image I used to install hddriver and magic under steem.
hdd-1gb_blank.zip
Postby Cyprian » Sun Jan 13, 2019 3:53 pm
thanks,
It seems something is wrong with my Hatari setup, due to I'm not able to install the latest HDDriver Demo on your Partition.
I have to check on a clean setup.
mpattonm
Postby mpattonm » Fri Mar 15, 2019 8:41 pm
Apparently, there are no more commits since January, I sincerely hope you have not given up! Please keep on :)
Postby Eero Tamminen » Sat Mar 16, 2019 12:02 am
It means that
The linked image showed similar error for me with Aranym, but worked fine with Hatari.
Then I happened to start sysinfo.app, and changed some NVRAM settings with it. Then I tried looking rest of the info sysinfo provides and magic crashed.
On reboot, I got the same error as on Aranym. Also when restarting Hatari. Removing ~/.config/hatari/hatari.nvram got image working again with Hatari.
(I haven't tried which particular NVRAM option caused the boot failure with Hatari, but I changed following: OS preference, date format, boot delay, keyboard/language.)
Removing Aranym NVRAM file (~/.aranym/nvram) didn't help in getting Otto's Magic image working with the included Aranym config & images, when using distro version of Aranym. But compiling latest Git version of Aranym from Github repo and using that got it working too.
TheNameOfTheGame
Postby TheNameOfTheGame » Sun Sep 15, 2019 5:30 pm
I was reading the Magnum ST Alt-RAM card readme.txt and it mentions a bug with MagiC >5.04 which caused 64KB of ST-RAM to be lost. Was the bug still carried over as of MagiC 6.20?
Due to a bug in the operating system function Maddalt() in Magic!>5.04 (probably from 5.10 or 5.13) causes the system to loose 64K ST-RAM.
The function of the card and registered memory is not affected by this error.
ThorstenOtto
Postby ThorstenOtto » Sun Sep 15, 2019 5:59 pm
I don't know, i would first have to know how that bug can be reproduced, or what causes it. Do you have any details?
TheNameOfTheGame
Postby TheNameOfTheGame » Sun Sep 15, 2019 6:13 pm
Unfortunately, I don't know anything other than what it says. I assume Maddalt() was to add in the Alt-RAM from the Magnum card, so probably happens when the auto folder program runs to set up the memory space.
Here is the Magnum package that has the readme.txt file:
mst_117.zip
ThorstenOtto
Postby ThorstenOtto » Sun Sep 15, 2019 10:47 pm
Maybe you can just try and see if that bug still exists? I don't have any hardware which adds memory via Maddalt. If the bug still exists i can try to have a look what the reason might be, but if it doesn't then looking for it would be quite pointless ;) Unfortunately we just got the source "as is", without much history about changes done.
TheNameOfTheGame
Postby TheNameOfTheGame » Sun Sep 15, 2019 11:57 pm
Ok, that makes sense, but I don't have a populated magnum board, just a pcb. If the issue is untestable atm, that's understandable. If I ever get this board together I can try it out.
Users browsing this forum: musashi5150 and 0 guests
