MISTer (Main Core)
BlockABoots
Re: MISTer (Main Core)
Postby BlockABoots » Tue Aug 20, 2019 7:19 pm
Whats the, Direct Video Over HDMI new feature about?
fufenicon
Postby fufenicon » Tue Aug 20, 2019 7:24 pm
BlockABoots wrote:Whats the, Direct Video Over HDMI new feature about?
I belive it's analog video without the need of an I/O board
Postby Sorgelig » Tue Aug 20, 2019 7:51 pm
SegaMan
Postby SegaMan » Wed Aug 21, 2019 12:02 pm
Got black screen from time to time with last core in Main Menu and ini settings (Skript).
Xtro
Postby Xtro » Sat Aug 31, 2019 4:36 pm
I am using MiSTer mostly attached to a 15khz monitor through VGA to BNC. Before framebuffer update when you left menu still for some time screen dimmed to prevent burns of the monitor. Nowadays if I config fb_terminal=1 after 30 seconds OSD disappears and after that screen dims, perfect. The problem is with fb_terminal=1 attached on VGA output I cannot see what the updater script does, and if I config fb_terminal=0 I lose screensaver. Is it possible to dim OSD menu after 30 seconds like it was prior to frambuffer?
Postby Sorgelig » Sat Aug 31, 2019 9:08 pm
You need to enable vga_scaler=1 for Menu core with some adequate custom resolution, so you will be able to see the frame buffer.
Xtro
Postby Xtro » Sat Aug 31, 2019 11:08 pm
If I enable VGA scaler at let's say custom resolution of 640x240 @60hz as I use a 15khz monitor, all the cores would be scaled to this resolution? This is what I want to avoid, and why I use 15khz, to use native resolution of the core bypassing the scaler. Would not be easier to put an option on menu core to enable screen saver?
jemismyname
OSD bug
Postby jemismyname » Sun Sep 01, 2019 4:28 am
i'm experiencing an odd bug with the OSD.
When I load up a core and press the OSD button, the first (center) menu of the core will be off.
The highlighted option won't be the option that is affected when i press a button. instead it will affect an option several rows up on the menu.
This only affects the center menu of the OSD, i've tried it and had the same issue with SNES, genesis, and NES cores.
I'm using a wired XBOX 360 controller (afterglow brand).
meow
Re: OSD bug
Postby Sorgelig » Sun Sep 01, 2019 5:41 am
jemismyname wrote:i'm experiencing an odd bug with the OSD.
meow
Great discovery after several months use of outdated files.
Just update the MiSTer binary and it will be fixed.
Postby Sorgelig » Sun Sep 01, 2019 5:43 am
Xtro wrote:If I enable VGA scaler at let's say custom resolution of 640x240 @60hz as I use a 15khz monitor, all the cores would be scaled to this resolution? This is what I want to avoid, and why I use 15khz, to use native resolution of the core bypassing the scaler. Would not be easier to put an option on menu core to enable screen saver?
You can enable it per-core. So just enable it for Menu core.
jemismyname
Re: OSD bug
Postby jemismyname » Sun Sep 01, 2019 8:54 am
meow
oh, i must have MiST that one when i was updating :P :D
I've been off-grid for a moment.
zomgugoff
Postby zomgugoff » Fri Sep 06, 2019 10:49 pm
I'm having issues with HDMI picture stability after today's (20190907) menu update. The image drops out randomly just sitting in the main menu and the is flickering along the top edge of the screen. Once another core is loaded, the video is stable. I have reverted to the 20190824 menu and the image is stable. Anyone else see this?
djmartins
Postby djmartins » Sat Sep 07, 2019 2:35 am
zomgugoff wrote:I'm having issues with HDMI picture stability after today's (20190907) menu update. The image drops out randomly just sitting in the main menu and the is flickering along the top edge of the screen. Once another core is loaded, the video is stable. I have reverted to the 20190824 menu and the image is stable. Anyone else see this?
Just updated and seeing the same exact issue.
apolkosnik
Postby apolkosnik » Sat Sep 07, 2019 3:36 am
Same here. I've opened a new issue on GitHub to track this. Additionally, the new memtest is buggy.
LarsDragon
Postby LarsDragon » Sat Sep 07, 2019 7:40 am
I'm having issues with this release, NeoGeo logo animation and some sprites in fighting games have glitches. In previous compiled versions of github thats not happen, I have 32mgs. :shrug:
Postby Sorgelig » Sat Sep 07, 2019 9:01 am
LarsDragon wrote:I'm having issues with this release, NeoGeo logo animation and some sprites in fighting games have glitches. In previous compiled versions of github thats not happen, I have 32mgs. :shrug:
it's NeoGeo core related. Will be fixed.
jim150
Postby jim150 » Sun Sep 08, 2019 6:13 pm
Same issue here with v190908
ewok
Postby ewok » Sat Sep 14, 2019 7:59 am
I experience lots of flickering over the whole menu screen as well. When I choose a core the flickering is over.
ewok
Postby ewok » Sat Sep 14, 2019 10:30 am
Solved in the latest update! Thanks!
Xtro
Postby Xtro » Sun Sep 22, 2019 5:15 pm
With the MiSTer update of today I have rolling screen on RGB 15khz (not sync) in menu core. I am using a Sony PVM that had no problems in the past. It doesn't display the backdrop image as set for the scaler via RGB.
EDIT: Found out that I needed to put mister.ini file in the root of SD Card, I used to have it in config folder, this kind of change can cause trouble.
guvner
Postby guvner » Sun Sep 22, 2019 11:17 pm
yes I just noticed this, too. Mister.ini in config folder gets ignored and has to be moved to root. Was this intentional and stays this way?
Postby Sorgelig » Sun Sep 22, 2019 11:25 pm
MiSTer.ini location has been moved to the root like 2 years ago may be... It was used from there for legacy purpose.
config folder is only for files automatically created and managed internally and not requiring manual editing.
guvner
Postby guvner » Sun Sep 22, 2019 11:31 pm
good to know :D
nathanhardie
Postby nathanhardie » Mon Sep 23, 2019 1:08 am
Can somebody explain what "put core into reset state before loading the other core." means in the new update?
Postby Sorgelig » Mon Sep 23, 2019 6:31 am
nathanhardie wrote:Can somebody explain what "put core into reset state before loading the other core." means in the new update?
Less chance for DDR3 bridge to hang.
Users browsing this forum: dshadoff and 8 guests
