MISTer (Main Core)
Re: MISTer (Main Core)
Postby Sorgelig » Mon Apr 22, 2019 10:19 am
PhantombrainM wrote:Bug report for input mapping / directions not working:
I am referring to SMS Core (maybe other are broken, but haven't tried yet).
Left, Up and Down is not working anymore. (Dpad, XBOX 360 controller). Right direction works.
OSD reset or deleting configs did not help.
So i tried the following:
MiSTer_20190408 -> OK
MiSTer_20190421 -> Not working
MiSTer_20190422 -> Not working
After configuring in 20190408 it's also working in 20190422! But reconfiguring in 20190422 will break it again, so you have to go back to 20190408.
I don't have wired X360 controller (i have wireless which is obviously cannot be used). And i cannot reproduce your issue. I use 8bitdo M30/SF30Pro controllers and DualShock4. All of them mapped successfully.
Give me log (USB console) of pressing DPAD directions in Menu core.
PhantombrainM
Postby PhantombrainM » Mon Apr 22, 2019 11:01 am
I don't have that cable. I can buy one if you want.
I can login via network by SSH. Can I get console log from there?
I made a Video :
https://youtu.be/QbV7TUr0THY
Postby Sorgelig » Mon Apr 22, 2019 11:34 am
PhantombrainM wrote:I can login via network by SSH. Can I get console log from there?
Nope. only through USB direct connection.
PhantombrainM wrote:I made a Video :
still have no clue what's the problem. Do you have other gamepads to compare?
May be it's X360 gamepad specific.
Postby Sorgelig » Mon Apr 22, 2019 11:39 am
in 0422 release you can press Menu(OSD) button to clear all buttons definition while defining the buttons. Press it and then assign the buttons. Does it fix the problem?
PhantombrainM
Postby PhantombrainM » Mon Apr 22, 2019 12:50 pm
Sorgelig wrote:in 0422 release you can press Menu(OSD) button to clear all buttons definition while defining the buttons. Press it and then assign the buttons. Does it fix the problem?
- OSD Clear does not help either.
- I've got an Competition Pro. All directions are working when configuring! So its just the X360 Controller. But there is a user on FB who has the same problem with another Atari controller (Also Left Up Down not working).
- I'm getting an cable tomorrow from a co-worker
- I've attached the two map configs 20190408 which is working (also on 20190422) and a new configured 20190422 which is not working anymore. Maybe you can use this files for debugging? They have different MD5 hashes.
Postby Sorgelig » Mon Apr 22, 2019 2:20 pm
I see the non-working file has other key codes. Still have no idea why they are different.
I remember someone told me some time ago that X360/XBOne gamepads send a lot of events making MiSTer very busy when these gamepads are used. Similar to DS3/DS4. But in recent builds i've managed to remove unwanted messages from DS3/DS4, so they are good now.
Probably something similar required for X360/XBone.
P.S.: Non-working map has codes with 0xC0 either added or OR'ed. It may be some bug but i can't find it.
jpxdude
Postby jpxdude » Mon Apr 22, 2019 3:05 pm
PhantombrainM wrote:I don't have that cable. I can buy one if you want.
I made a Video :
I have the same problem here with XBOX 360 controller. I have only tested with SNES, but on newest build, after mapping, only the 'right' direction works on dpad, not left, up or down.
Postby Sorgelig » Mon Apr 22, 2019 3:08 pm
I made a Video :
"Me too" won't work. I need some info like USB console debug info.
LarsDragon
Postby LarsDragon » Mon Apr 22, 2019 4:05 pm
Hi Sorgelig, I connect throw USB console debug and get this log with SMS core.
Open up to 10 input devices.
opened 0: /dev/input/event8 (1d79:0301)
opened 1: /dev/input/event7 (1d79:0301)
opened 2: /dev/input/event6 (04d9:2519)
opened 3: /dev/input/event5 (04d9:2519)
opened 4: /dev/input/event4 (04d9:2519)
has LEDs.
opened 5: /dev/input/event3 (04d9:2519)
opened 6: /dev/input/event2 (054c:0cda)
opened 7: /dev/input/event1 (054c:0cda)
opened 8: /dev/input/event0 (054c:0cda)
OSD is now invisible
INFO: Video resolution: 256 x 192, fHorz = 15.7KHz, fVert = 59.9Hz, fPix = 5.37MHz
INFO: Frame time (100MHz counter): VGA = 1668814, HDMI = 1668791
adjust_video_mode(1668814): vsync_adjust=2, using NTSC mode.
Calculate PLL for 148.3089 MHz:
Fvco=444.926756, C=3, M=8, K=0.898535(3859178986) -> Fpix=148.308919
FileLoad(open) File:/media/fat/config/SMS_scaler.cfg, error: -1.
Read scaler coefficients
Send HDMI parameters:
video: 1920, 88, 44, 148, 1080, 4, 5, 36,
PLL: 0x4, 0x404, 0x3, 0x10000, 0x5, 0x20201, 0x9, 0x2, 0x8, 0x7, 0x7, 0xE60665EA, Fpix=148.308919
sending keymap: 0
INFO: Frame time (100MHz counter): VGA = 1668815, HDMI = 1668813
FileLoad(open) File:/media/fat/config/SMS_input_04d9_2519_v2.map, error: -1.
FileLoad(open) File:/media/fat/config/input_04d9_2519_v2.map, error: -1.
FileLoad(open) File:/media/fat/config/kbd_04d9_2519.map, error: -1.
OSD is now visible
FileLoad(open) File:/media/fat/config/kbd_1d79_0301.map, error: -1.
The controller that I try to configure is '1d79_0301', the written file is 'SMS_input_1d79_0301_v2'.
If I can do something else to help tell me.
Postby Sorgelig » Mon Apr 22, 2019 5:25 pm
LarsDragon wrote:If I can do something else to help tell me.
load the Menu core and then press DPAD buttons - you should see massages after each press/release
Postby Sorgelig » Mon Apr 22, 2019 6:36 pm
Found on eBay X360 wireless gamepad with receiver - very cheap. Ordered.
If i won't be able to fix this issue, then i hope i will get it in 2 weeks and will try myself.
Meista80
Postby Meista80 » Mon Apr 22, 2019 7:06 pm
I'm having the same issues using an original Super Famicom Controller via an SFC<->USB adapter.
Working on 20190408, not working on 20190421/22.
Locutus73
Postby Locutus73 » Mon Apr 22, 2019 9:02 pm
Sorgelig wrote:Found on eBay X360 wireless gamepad with receiver - very cheap. Ordered.
IIRC X360 wireless shouldn’t work with MiSTer, the dongle isn’t like an 8bitdo one which pairs and exposes itself as a wired controller. On Windows the Xbox receiver is a specific device which can connect up to 4 controllers.
But, as always, I might be wrong.
Regards.
Locutus73
PhantombrainM
Postby PhantombrainM » Mon Apr 22, 2019 9:22 pm
Regards.
Locutus73
You are wrong. Just plug the PC USB receiver into the Mister, pair a Controller and there you go. The best thing is, you can use up to 4 Controllers with just this one receiver. And the controller uses standard AA (rechargable) batteries. Not soldered propertary li-ion / polymere stuff like in the 8bitdo stuff. You will like it!
LarsDragon
Postby LarsDragon » Mon Apr 22, 2019 10:50 pm
Ok. The log is in order UP, RIGHT, DOWN and LEFT:
Input event: type=EV_ABS, Axis=17, Offset=-1, jnum=1, ID:1d79:0301. ABS_INFO: min = -1 max = 1
Input event: type=EV_KEY, code=300(0x12c), value=1, jnum=1, ID:1d79:0301
PS2 code(make)(ext) for core: 117(0x75)
Input event: type=EV_ABS, Axis=17, Offset=0, jnum=1, ID:1d79:0301. ABS_INFO: min = -1 max = 1
Input event: type=EV_KEY, code=300(0x12c), value=0, jnum=1, ID:1d79:0301
PS2 code(break)(ext) for core: 117(0x75)
Input event: type=EV_ABS, Axis=16, Offset=1, jnum=1, ID:1d79:0301. ABS_INFO: min = -1 max = 1
Input event: type=EV_KEY, code=301(0x12d), value=1, jnum=1, ID:1d79:0301
PS2 code(make)(ext) for core: 116(0x74)
Input event: type=EV_ABS, Axis=16, Offset=0, jnum=1, ID:1d79:0301. ABS_INFO: min = -1 max = 1
Input event: type=EV_KEY, code=301(0x12d), value=0, jnum=1, ID:1d79:0301
PS2 code(break)(ext) for core: 116(0x74)
Input event: type=EV_ABS, Axis=17, Offset=1, jnum=1, ID:1d79:0301. ABS_INFO: min = -1 max = 1
Input event: type=EV_KEY, code=302(0x12e), value=1, jnum=1, ID:1d79:0301
PS2 code(make)(ext) for core: 114(0x72)
Input event: type=EV_KEY, code=302(0x12e), value=0, jnum=1, ID:1d79:0301
PS2 code(break)(ext) for core: 114(0x72)
Input event: type=EV_ABS, Axis=16, Offset=-1, jnum=1, ID:1d79:0301. ABS_INFO: min = -1 max = 1
Input event: type=EV_KEY, code=303(0x12f), value=1, jnum=1, ID:1d79:0301
PS2 code(make)(ext) for core: 107(0x6B)
Input event: type=EV_KEY, code=303(0x12f), value=0, jnum=1, ID:1d79:0301
PS2 code(break)(ext) for core: 107(0x6B)
Postby Sorgelig » Tue Apr 23, 2019 5:53 am
according to VID:PID your controller is not X360 gamepad. So, it's not what i've originally wanted to debug.
Your controller generates 2 key codes from single key press. This is not how normal controller should work. While it may work, it still confuses the MiSTer. Check if this controller has different modes, so may be some mode generates only single code from key press.
LarsDragon
Postby LarsDragon » Tue Apr 23, 2019 6:24 am
Sorgelig wrote:
LarsDragon wrote:
Sorgelig wrote:load the Menu core and then press DPAD buttons - you should see massages after each press/release
My controller is the Mayflash Wii Classic Adapter, this adapter don't have a diferent mode. With Mister_20190408 version it work well.
I can send you the same information with X360 gamepad.
Locutus73
Postby Locutus73 » Tue Apr 23, 2019 7:09 am
PhantombrainM wrote:You are wrong. Just plug the PC USB receiver into the Mister, pair a Controller and there you go. The best thing is, you can use up to 4 Controllers with just this one receiver. And the controller uses standard AA (rechargable) batteries. Not soldered propertary li-ion / polymere stuff like in the 8bitdo stuff. You will like it!
Oh great, so after pairing it exposes the controller as an usb controller just plugged. Very good. I thought it was something different since under Windows you always see the receiver as a special connected device and then you see the controllers only when paired (and maybe I tested it with no success on MiSTer back then, when I tested many controllers and adapters, but I’m not sure, time has passed, I don’t remember). BTW I know it uses AA, I have two of them, but I never use them because I don’t like the controller: horrible dpad and I’m one of the few people who prefers Sony symmetrical analog stick layout.
Regards.
Locutus73
Postby Sorgelig » Tue Apr 23, 2019 12:36 pm
Just bought XBOne S controller which has BT. And it seems it has pairing problem. Microsoft wouldn't be a Microsoft if it wouldn't cripple the standard.
Generally speaking XBOne gamepad is inferior to Dualshock. DPAD is tiny and much worse in tactile feeling.
warham
Postby warham » Tue Apr 23, 2019 12:40 pm
I tested a couple wireless 360 controllers in the past.
Everything worked except the right stick was not recognized.
That was several mister and Linux versions back.
I will try it again after work in a few hours and see if I get the same results.
PhantombrainM
Postby PhantombrainM » Tue Apr 23, 2019 4:42 pm
Sorgelig wrote: I need some info like USB console debug info.
As promised I got the cable from my co-worker.
Here are the console log files.
PhantombrainM
Postby PhantombrainM » Tue Apr 23, 2019 4:44 pm
Sorgelig wrote:Just bought XBOne S controller which has BT. And it seems it has pairing problem. Microsoft wouldn't be a Microsoft if it wouldn't cripple the standard.
You can do a firmware update on windows 10 with usb cable. After that it connects to everything, even a macbook.
LarsDragon
Postby LarsDragon » Tue Apr 23, 2019 5:06 pm
Hi Sorgelig, this is also my log information from XB360 controller.
Input event: type=EV_KEY, code=706(0x2c2), value=1, jnum=1, ID:045e:02a1
Input event: type=EV_ABS, Axis=17, Offset=-1, jnum=1, ID:045e:02a1. ABS_INFO: min = -1 max = 1
Input event: type=EV_KEY, code=706(0x2c2), value=0, jnum=1, ID:045e:02a1
Input event: type=EV_ABS, Axis=17, Offset=0, jnum=1, ID:045e:02a1. ABS_INFO: min = -1 max = 1
Input event: type=EV_KEY, code=705(0x2c1), value=1, jnum=1, ID:045e:02a1
Input event: type=EV_ABS, Axis=16, Offset=1, jnum=1, ID:045e:02a1. ABS_INFO: min = -1 max = 1
Input event: type=EV_KEY, code=705(0x2c1), value=0, jnum=1, ID:045e:02a1
Input event: type=EV_ABS, Axis=16, Offset=0, jnum=1, ID:045e:02a1. ABS_INFO: min = -1 max = 1
Input event: type=EV_KEY, code=707(0x2c3), value=1, jnum=1, ID:045e:02a1
Input event: type=EV_ABS, Axis=17, Offset=1, jnum=1, ID:045e:02a1. ABS_INFO: min = -1 max = 1
Input event: type=EV_KEY, code=707(0x2c3), value=0, jnum=1, ID:045e:02a1
Input event: type=EV_KEY, code=704(0x2c0), value=1, jnum=1, ID:045e:02a1
Input event: type=EV_ABS, Axis=16, Offset=-1, jnum=1, ID:045e:02a1. ABS_INFO: min = -1 max = 1
Input event: type=EV_KEY, code=704(0x2c0), value=0, jnum=1, ID:045e:02a1
Locutus73
Postby Locutus73 » Tue Apr 23, 2019 5:21 pm
I don't want to say something stupid, but I think that if someone connects through SSH and then performs
killall MiSTer
/media/fat/MiSTer
then he/she should get debug messages as long as he/she remain connected through SSH.
Obviously as soon the SSH connection is closed, MiSTer process will be killed and the DE10-Nano must be restarted.
Regards.
Locutus73
Postby Sorgelig » Tue Apr 23, 2019 5:57 pm
PhantombrainM wrote:You can do a firmware update on windows 10 with usb cable. After that it connects to everything, even a macbook.
problem is not in firmware. It's already latest in my controller.
you need to issue command:
echo 1 > /sys/module/bluetooth/parameters/disable_ertm
or simply unzip and replace the file:
S35bluetooth.zip
to /etc/init.d/S35bluetooth (chmod 755)
i will include it in the next linux release.
XBOne S gamepad works fine over BT with this fix.
