SNES core
crocky
Re: SNES core
Postby crocky » Fri Dec 07, 2018 3:03 pm
Ok thanks then I will try some other files :(
ghogan42
Re: SNES core
Postby ghogan42 » Fri Dec 07, 2018 4:27 pm
crocky wrote:Ok thanks then I will try some other files :(
The US version of Super Street Fighter II should also work.
crocky
Re: SNES core
Postby crocky » Fri Dec 07, 2018 4:31 pm
Finally the card was unable to boot and I did an error check on windows and now both SSF2 and S Bomberman 2 are working. I shall keep in mind to do this next time before posting.
markun
Re: SNES core
Postby markun » Fri Dec 07, 2018 5:34 pm
The game "Super Mario All-Stars + Super Mario World (USA)" has a regression since release 20181206. In the main menu the cursor keeps scrolling to the right and does not land (exactly) on a game poster. Pressing the START button results in a menu that is almost completely out of the screen.
In 20181201 it worked fine. I just tested 20181207 and it's unfortunately still broken.
olin
Re: SNES core
Postby olin » Fri Dec 07, 2018 9:03 pm
Does MiSTer SNES core support VGA output? I can't manage to make it work on my de0ns. I've also recompiled MiSTer main arm binary just to be sure.
Re: SNES core
Postby Sorgelig » Fri Dec 07, 2018 10:10 pm
Yes, it supports VGA.
Jeebs
Re: SNES core
Postby Jeebs » Fri Dec 07, 2018 10:34 pm
markun wrote:The game "Super Mario All-Stars + Super Mario World (USA)" has a regression since release 20181206. In the main menu the cursor keeps scrolling to the right and does not land (exactly) on a game poster. Pressing the START button results in a menu that is almost completely out of the screen.
I saw this same issue as well. Mario All Stars without Mario World works just fine too.
olin
Re: SNES core
Postby olin » Fri Dec 07, 2018 11:10 pm
Thanks for the confirmation. On other cores I can see this (or similar) line printed on the console when the core starts:
INFO: Video resolution: 641 x 568, fHorz = 31.3KHz, fVert = 50.1Hz, fPix = 27.99MHz
INFO: Frame time (100MHz counter): VGA = 1996799, HDMI = 0
But on my build of SNES core I can't see that. I guess MiSTer main did not detect the video mode for some reason - most likely because of my mods. The core runs, because I can enter the OSD menu (not displayed) and load another core (blindly, pressing right arrow, enter, up arrow, enter). I must have missed something then.
314ter
Re: SNES core
Postby 314ter » Sat Dec 08, 2018 8:29 am
In Final Fantasy V, the english translation (GBA port patch, but also other patch versions) I can’t get past the title screen.
When you press start button, the title logo flies toward you and the music fades, but the the screen stays black while the music keeps playing softly. The previous core versions also show this behaviour.
Can anyone confirm this? Or does anyone know a fix for this?
widge
Re: SNES core
Postby widge » Sat Dec 08, 2018 9:18 am
I have VGA signal on other console cores but not on SNES.
Updated MiSTer to MiSTer_20181208.
Updated SNES to SNES_20181207.rbf
Am I missing something?
SegaMan
Re: SNES core
Postby SegaMan » Sat Dec 08, 2018 9:37 am
Whats your settings in Mister.ini?
Re: SNES core
Postby Sorgelig » Sat Dec 08, 2018 9:55 am
widge wrote:Hello,
you need to use any game ROM as a boot.rom, so SNES will start with preloaded game and will provide the video.
albconde
Re: SNES core
Postby albconde » Sat Dec 08, 2018 2:08 pm
tested a lot of games , compatiblity is great .
Some issues :
snow white in happy ever after : black screen
metal marines ( u) \milita (j) : problems with image when you start to play after history .
seiken densetsu 3 (j) : some flickers in the image in first fight ( resolution changes?) ( works in 20181201)
derby stallion 96 (j) : black screen
bart's nightmare :strange color in background when move (works in release 20181201)
onita atsushi FMW (j) :freeze when you start game, no sound
pachiokun special (j):freeze when you enter in any building in game , no sound
sound novel Tsukuru (j) : black screen
chou aniki - bakuretsu rantouden (j) : black screen
olin
Re: SNES core
Postby olin » Sat Dec 08, 2018 6:10 pm
Sorgelig wrote:you need to use any game ROM as a boot.rom, so SNES will start with preloaded game and will provide the video.
Thanks. that was it. Furthermore the carts I downloaded were SMC format, therefore containing 512 byte copier header. This needs to be skipped in order to read the raw cart data. I've made a fix to MiSTer main to skip the smc/sfc header. You can test it by using the unofficial release bellow:
https://github.com/ole00/Main_MiSTer/tr ... r/releases
olin
Re: SNES core
Postby olin » Sat Dec 08, 2018 6:12 pm
albconde wrote:tested a lot of games , compatiblity is great .
Some issues :
... black screen
Try my unofficial release of MiSTer main (see above) which detects the copier header in the carts and skips it. It may help to fix some of the 'black screen' issues.
widge
Re: SNES core
Postby widge » Sat Dec 08, 2018 6:14 pm
Thanks, I am not familiar with boot.rom, is it just a SFC file renamed to to boot.rom?
I have tried:
injector SNES_20181207.rbf game.sfc new.rbf
and (game.sfc renamed to boot.rom):
injector SNES_20181207.rbf boot.rom new2.rbf
new.rbf and new2.rbf do no produce VGA.
widge
Re: SNES core
Postby widge » Sat Dec 08, 2018 6:16 pm
SegaMan wrote:Whats your settings in Mister.ini?
I have just set forced_scandoubler to 1.
I have not touched the rest of the file.
albconde
Re: SNES core
Postby albconde » Sat Dec 08, 2018 6:40 pm
widge wrote:Thanks, I am not familiar with boot.rom, is it just a SFC file renamed to to boot.rom?
don't need to inject the room rename a game as boot.rom and put in a folder named snes
olin wrote:Try my unofficial release of MiSTer main (see above) which detects the copier header in the carts and skips it. It may help to fix some of the 'black screen' issues.
No luck , black screen with your unoficial mister file
yarko
Re: SNES core
Postby yarko » Sat Dec 08, 2018 7:19 pm
I confirm - only black screen on VGA output
PhantombrainM
Re: SNES core
Postby PhantombrainM » Sat Dec 08, 2018 7:43 pm
yarko wrote:I confirm - only black screen on VGA output
Just put a renamed game into the SNES folder. Rename it to boot.rom. Then you will get a picture on VGA output.
I used the SNES Test Suite und now every time I start the core I get the test suite (even on VGA)
widge
Re: SNES core
Postby widge » Sat Dec 08, 2018 9:23 pm
PhantombrainM wrote:Just put a renamed game into the SNES folder. Rename it to boot.rom. Then you will get a picture on VGA output.
Ok the boot.rom mechanism works on my side but I only have video on HDMI, nothing on VGA.
olin
Re: SNES core
Postby olin » Sun Dec 09, 2018 12:16 am
widge wrote:Ok the boot.rom mechanism works on my side but I only have video on HDMI, nothing on VGA.
Similar for me: 15.7 kHz fine via SCART, but when scandoubler is enabled then my VGA monitor does not pick up the signal. I wonder whether it is the non standard vertical frequency of 60.1 Hz
INFO: Video resolution: 512 x 448, fHorz = 31.5KHz, fVert = 60.1Hz, fPix = 21.48MHz
INFO: Frame time (100MHz counter): VGA = 1663917, HDMI = 0
Shamus
Re: SNES core
Postby Shamus » Sun Dec 09, 2018 11:53 am
... black screen ...
I have the black screen issue in another context: many roms run just fine, whereas others mentioned to be working in this thread consistently give a black screen and no sound in DVI (DVI mode = 4; NTSC and PAL tried):
Donkey Kong Country
F-Zero
Super Bomberman 1+2, whereas Super Bomberman 3 works!
all Super Mario games; Mario is missing and Mario's Time Machine work
etc.
Is this connected to DVI (I cannot try VGA or HDMI with my setup), could it be the rom files, or am I doing something wrong?
Shamus
Re: SNES core
Postby Shamus » Sun Dec 09, 2018 12:56 pm
I just downloaded different rom files for Super Mario World and eventually one worked indeed. Then it is the rom, or header or ...?
Shamus
Re: SNES core
Postby Shamus » Sun Dec 09, 2018 4:30 pm
From my experience with working and non-working roms: what would be a good source for an SNES ROM pack that works well with the MISTer core?
