FX CAST Atari ST core
attle
Re: FX CAST Atari ST core
Postby attle » Fri Feb 08, 2019 7:40 am
Tested this core a bit yesterday, and it looks very promising. I would *love* to see 15Khz support for ST-low screen mode.
jamesfmackenzie
Postby jamesfmackenzie » Fri Feb 08, 2019 5:45 pm
Congrats on the wonderful ST core!
On my real ST I use null modem and also Ethernet (NetUSBee) to talk to the outside world
Any plans to add comms support in the FX CAST core? I see that MiSTer supports serial (UART) connection from FPGA to Linux at 115200 baud. Any possibility to use this channel?
tatouine
Postby tatouine » Tue Feb 19, 2019 7:12 pm
I have a loud hiss in the main menu of the demo life's a bitch (Lost Boys).
Anyone else to this problem?
VID_20190219_195501.mp4
Sorry for the poor recording quality but I do not have a video capture card nor a good phone.
520 STf |Amiga 500 (1M) |Philips CM8832 | Atari SC 1425 | Atari SC 1435
MIST | MISTER | Analogue Super Nt
DVDO Edge *2 | neoya x2vga 2 | Simple Video Scalar
XRGB-3 | XRGB-mini Framemeister |GBS-8220*2 | SLG3000 | Sync Strike |SLG Scart
HD video Converter | SCART+HDMI to HDMI+HDMI |Open Source Scan Converter (OSSC)
pomegran
Postby pomegran » Sun Mar 03, 2019 4:00 am
Can somebody advise on how I can get FX Cast to run in 4:3 please?
Paradroyd
Postby Paradroyd » Sun Mar 03, 2019 6:50 am
pomegran wrote:Can somebody advise on how I can get FX Cast to run in 4:3 please?
For some reason, some TVs / monitors want to run this core in 16:9 regardless of the menu settings. The Vizio TV I used to have my MiSTer hooked up to always rendered it in 16:9. I moved it to a different Vizio monitor and on that monitor it heeds the menu 4:3/16:9 setting.
- Paradroyd
pomegran
Postby pomegran » Sun Mar 03, 2019 8:00 am
I couldn't see a menu setting for 4:3, is there one? However I can always switch to 4:3 on the TV. Thanks for responding!
Paradroyd
Postby Paradroyd » Sun Mar 03, 2019 10:21 am
pomegran wrote:I couldn't see a menu setting for 4:3, is there one? However I can always switch to 4:3 on the TV. Thanks for responding!
I just took another look, and you're right. there's no setting in FXCast for that. If you can set it on your TV, that's the only option for now. (most other cores have an explicit setting..this one does not).
- Paradroyd
ericgus
Postby ericgus » Thu Mar 07, 2019 4:30 am
Just curious if work on this core has halted? seems it had a great start but the core still has some real issues (like the 4:3 aspect ratio problem Paradroyd mentioned, its particularly noticeable when using a typical 16x9 HDMI display) .. accelerated STe support , floppy writes and lack of hard drive support and some of the other features found in its Mist counterpart.. Would really love to see some updates to this fantastic core (I know people get busy with life and such) (just a simple inquiry)..
alexh
Postby alexh » Thu Mar 07, 2019 8:29 am
ericgus wrote:the core still has some real issues (like the 4:3 aspect ratio problem Paradroyd mentioned, its particularly noticeable when using a typical 16x9 HDMI display)
Is that really an issue? I just correct the aspect ratio using an option in the HDMI display's built in menu.
ericgus
Postby ericgus » Thu Mar 07, 2019 5:06 pm
Tried that, doesnt work for mine ..
matt
Postby matt » Sat Mar 09, 2019 12:04 am
Arguably it's your TV problem not the core. Debatable.
ericgus
Postby ericgus » Sat Mar 09, 2019 7:45 am
matt wrote:
ericgus wrote:
alexh wrote:Is that really an issue? I just correct the aspect ratio using an option in the HDMI display's built in menu.
Works fine for every other core.. except this one.. so yea, debatable .. its a standard old VIZIO HDTV not "smart" just a dumb HDTV with dual HDMI inputs.. nothing special, common TV. Its also obvious this core is still very much a work in progress as well . I think everyone clearly understands that. Also others have commented on the exact same problem so its not just "my tv" ..
SegaMan
Postby SegaMan » Sat Mar 09, 2019 10:37 am
Will there come a official release of FX Cast for MiSTer?
Scaler support and 4:3 Option would be great :)
Shamus
Postby Shamus » Sat Mar 09, 2019 1:25 pm
... and DVI support please! As mentioned before I still haven't been able to run FX CAST with my setup (MiSTer quite permanently fused with a TFT monitor; I call it my "iMiSTer") - but I'd really love to! :D
flain
Postby flain » Sun Mar 10, 2019 11:05 pm
if the core gets opensource then maybe even someone else will do the scaler support for it :)
I have the same issue, I've got 4 different 4K TVs and none of them have an option to set to 4:3 anymore (1 samsung, 3 sonys), seems this option is more common on older TVs :(
Paradroyd
Postby Paradroyd » Fri Mar 15, 2019 8:43 pm
I posted a pretty good example of what's going on with this here...
- Paradroyd
NML32
Postby NML32 » Sat Mar 16, 2019 4:52 pm
Could someone be kind enough to put PlatoTerm on an Atari ST .st floppy image for me?
https://github.com/tschak909/platotermst/releases
plato-0_1_1-pre-alpha.zip
Thank you in advance.
bitfan2011
Postby bitfan2011 » Sat Mar 16, 2019 7:40 pm
this core causes "out of range" messages on my displays, where it didn't used to. if i press the menu button when the screen is dead, the white core background flashes for a second and then then back to "out of range". i had actually played games on this core previously...
darwinmac
Postby darwinmac » Sat Mar 16, 2019 9:24 pm
NML32 wrote:Could someone be kind enough to put PlatoTerm on an Atari ST .st floppy image for me?
Here is the ST image file. You can use MSA Converter (Windows program) to convert ZIP files into ST image files. I could only check that PlatoTerm started. I have no idea how to use it. I saw a demo on the 8-bit about a year ago, but I have not had any time to explore Plato any further.
Bob C
NML32
Postby NML32 » Sat Mar 16, 2019 9:36 pm
Bob C
Thank you very much. :cheers:
I'll definitely be checking out MSA. :)
Update: PlatoTerm doesn't fully load. It only partially loads (green window) then stops with the middle led fast blinking. :(
Postby Eero Tamminen » Sat Mar 16, 2019 11:33 pm
NML32 wrote:Update: PlatoTerm doesn't fully load. It only partially loads (green window) then stops with the middle led fast blinking. :(
On Linux, you can use zip2st script coming with Hatari to convert ZIP files and directories to .ST disk images files.
darwinmac
Postby darwinmac » Sat Mar 16, 2019 11:47 pm
Bob C
I had something similar, but I do not think I had the proper setup for online access in Hatari. I would contact Platoterm’s author. He appears to be very responsive.
Bob C
NML32
Postby NML32 » Sat Mar 16, 2019 11:59 pm
darwinmac wrote:I had something similar, but I do not think I had the proper setup for online access in Hatari. I would contact Platoterm’s author. He appears to be very responsive.
Bob C
I was trying to use PlatoTerm in FX CAST.
darwinmac
Postby darwinmac » Sun Mar 17, 2019 4:11 am
Bob C
I am aware of that. However, I was simply mentioning that I had similar results in an emulator. I think PlatoTerm’s author might be able to help you by telling you what needs to be set up in order for it to work.
Bob C
Paradroyd
Postby Paradroyd » Mon Mar 18, 2019 2:26 am
darwinmac wrote:
Bob C
Bob C
As far as I can tell, it needs write access to the floppy disk. As long as FXcast doesn't support that, it's probably not going to work.
- Paradroyd
Users browsing this forum: l0max, squidlr and 6 guests
