Amstrad CPC 6128/664 (NEW)
desUBIKado
Re: Amstrad CPC 6128/664 (NEW)
Postby desUBIKado » Fri Aug 10, 2018 10:19 pm
I've tried a series of games that are hard to emulate for a number of issues. The list is this:
  1. Sorcery
  2. Killer Cobra
  3. Tornado Low Level
  4. Mission Genocide
  5. Agent X II
  6. California Games
  7. Stryker
  8. Enlightenment - Druid II
  9. Usagy YoJimbo
  10. Prehistorik 2
  11. Booty
All work perfectly with the latest version of the core
I leave a document in Spanish with the list of games, the reason for its difficulty to be emulated and a download link for each of them.
Juegos.docx.zip
These games were discussed in a program on the YouTube channel Amiga Wave, where they were talking, in spanish of course, about emulators running inside a Commodore Amiga.
https://www.youtube.com/watch?v=VB6QsEY ... t=1h48m46s
desUBIKado
Postby desUBIKado » Sat Aug 11, 2018 12:37 am
I rename ParaDOS V1.2 rom to BOOT.E07 and I move it to root directory of SD card. This rom don't load at start of core, but works if I load it manually from OSD menu. Where I must put this file to load at start of core? Thanks in advance
Postby Sorgelig » Sat Aug 11, 2018 4:57 am
desUBIKado wrote:I rename ParaDOS V1.2 rom to BOOT.E07 and I move it to root directory of SD card. This rom don't load at start of core, but works if I load it manually from OSD menu. Where I must put this file to load at start of core? Thanks in advance
This part is marked as "MiSTer specific" and boot.* files should be in Amstrad folder.
desUBIKado
Postby desUBIKado » Sat Aug 11, 2018 7:24 am
Sorgelig wrote:This part is marked as "MiSTer specific" and boot.* files should be in Amstrad folder.
Thanks. I am so excited with this core I didn't read all instructions "despacito" :D
Postby Sorgelig » Sat Aug 11, 2018 10:46 am
Druid II issue (Usagi has similar problem) will be fixed in next release.
vebxenon
Postby vebxenon » Sat Aug 11, 2018 12:09 pm
How about USB joystick/pad? With last core it doesn't work well :(
- Atari Jr 2600 clone
- Atari 7800 Peritel
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
Postby Sorgelig » Sat Aug 11, 2018 1:39 pm
Core doesn't deal with USB or DB9 directly as i've wrote before. It's up to MiST Firmware.
vebxenon
Postby vebxenon » Sat Aug 11, 2018 11:35 pm
Sorgelig wrote:Core doesn't deal with USB or DB9 directly as i've wrote before. It's up to MiST Firmware.
Ok, I've put two pads and joystick 2 is recognized as joystick 1. So I can play the games.
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
vebxenon
Postby vebxenon » Sat Aug 11, 2018 11:37 pm
DanyPPC wrote:So maybe useful an option to exchange the joystick ports as on C64 core.
I use only one usb gamepad for MiST.
That can be done? :-)
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
Postby Sorgelig » Sun Aug 12, 2018 3:13 am
I will add joystick swap option
DrOG
Postby DrOG » Sun Aug 12, 2018 4:13 am
THX!!!
Postby Sorgelig » Sun Aug 12, 2018 7:35 am
Release 20180812:
- Tweaks and fixes in CRTC and GA.
- Hide MF2 ROM when MF2 is disabled.
- Option to disable FDC
- Option to swap the Joysticks.
Druid II and Usagi should display correctly now.
DanyPPC
Postby DanyPPC » Sun Aug 12, 2018 8:39 am
Sorgelig wrote:Release 20180812:
Yeah !!!
Many thanks Sorgelig for add this useful option ! You are great :cheers:
DrOG
Postby DrOG » Sun Aug 12, 2018 10:05 am
:cheers: Thanks for all the improvements!
RobeInie
Postby RobeInie » Sun Aug 12, 2018 10:29 am
Thanks for the option for swapping joysticks , I had the same problem and this will solve !!
One question Sorgelig,
Will be CDT support on MIST ? (I see it is only on Mister)
Thanks !
Postby Sorgelig » Sun Aug 12, 2018 10:56 am
RobeInie wrote:Will be CDT support on MIST ? (I see it is only on Mister)
Current CDT/TZX implementation on MiSTer cannot fit into MiST.
christianlucio
Thanks and....
Postby christianlucio » Sun Aug 12, 2018 2:01 pm
Many thanks to Sorgelig for again doing a fantastic job. Some of the most important cores for me have improved much due to your great work ! Now only the Atari ST core and the Amiga core are left........:)
vebxenon
Postby vebxenon » Sun Aug 12, 2018 4:23 pm
Thanks very very much! :cheers: :cheers: :cheers:
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
arty
Postby arty » Sun Aug 12, 2018 8:37 pm
Well done! Thank you.
…………ıllıllı just a friend ıllıllı…………
seastalker
Postby seastalker » Thu Aug 23, 2018 3:07 am
THANK YOU!!! Really looking forward to diving into this one AND the resolution now plays nice with my IBM PS1 monitor!! Loaded up a few titles and so far so... wonderful!!
Higgy
Postby Higgy » Tue Aug 28, 2018 7:21 am
- Tape input through UART_RX pin (same as in ZX core)
Just to say I tried the tape demo 'Breaking Baud' on my MiST (with added tape input soldered on) and it worked well. 8)
DanyPPC
Postby DanyPPC » Mon Nov 26, 2018 4:26 pm
Hello Sorgelig, could you upgrade this fantastic Amstrad core for YPbPr support ?
Many thanks from the community.
Postby Sorgelig » Mon Nov 26, 2018 4:41 pm
I've released the new version.
YPbPr has been added by slingshot. I didn't test it.
DanyPPC
Postby DanyPPC » Mon Nov 26, 2018 7:38 pm
and yes, it works !!!
Many, many thanks Sorgelig :cheers:
SchneiderCPC664
Postby SchneiderCPC664 » Sat Dec 01, 2018 9:40 am
This is a little bit picky, but the Amstrad startup screen is to fast displayed compared to the original CPC and the older core. Is it possible to change this?
