Amstrad CPC 6128/664 (NEW)
desUBIKado
Re: Amstrad CPC 6128/664 (NEW)
Postby desUBIKado » Mon Aug 06, 2018 7:46 pm
I have noticed that if I connect two usb gamepads, the second acts correctly as the main joystick.
I reiterate a previous question, will there be support for the load from audio? The spectrum core has it and it is a great addition
Thank you for you great job
DanyPPC
Postby DanyPPC » Tue Aug 07, 2018 5:36 am
So maybe useful an option to exchange the joystick ports as on C64 core.
I use only one usb gamepad for MiST.
Old Amstrad CPC 464 and 6128 have only one port joystick, the second one must be connected to the first joystick which has a through port.
Postby Sorgelig » Tue Aug 07, 2018 12:12 pm
From Scratch issue has been fixed. There was tetris part which wasn't visible and also has been fixed.
vebxenon
Postby vebxenon » Tue Aug 07, 2018 8:32 pm
:cheers: Thanks very much!!
- Atari Jr 2600 clone
- Atari 7800 Peritel
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
Higgy
Postby Higgy » Wed Aug 08, 2018 11:54 am
Great news on the CPC updates.
I wonder if the tape loading feature from the ZX Spectrum Core is easy to add (connects through midi connectors?)
This is a very impressive demo which streams from tape:
https://m.youtube.com/watch?v=Pe8dislZkUQ
Postby Sorgelig » Wed Aug 08, 2018 1:11 pm
Release 20180808:
- Support expansion loading
- Reorganize OSD options.
- CRTC: some fixes (fixes From Scratch demo)
Attention: This release requires firmware update (180808 or later) for proper work!
arty
Postby arty » Wed Aug 08, 2018 1:38 pm
Sorgelig wrote:Release 20180808:
Great update of CPC core! Thank you for extension of quantity of OSD options on firmware level!
For those who lost at MiST Wiki in search of new: latest firmware can be found at https://github.com/mist-devel/mist-bina ... r/firmware , rename *.upg-file to firmware.upg, copy it to root of memory card and use update via system menu of MiST.
…………ıllıllı just a friend ıllıllı…………
DanyPPC
Postby DanyPPC » Wed Aug 08, 2018 4:07 pm
Done !
Good update ! :cheers:
Xtro
Postby Xtro » Wed Aug 08, 2018 5:55 pm
Thanks Sorgelig, discovering the Amstrad CPC with this core
vebxenon
Postby vebxenon » Thu Aug 09, 2018 5:49 am
Thanks very much again! I've done a lot of tests and that's outstanding!
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
DrOG
Postby DrOG » Thu Aug 09, 2018 7:09 pm
:cheers: Very nice!!! :D
Postby Sorgelig » Fri Aug 10, 2018 4:41 am
Release 20180810:
- Support for 2 disk drives
- Tape input through UART_RX pin (same as in ZX core)
Attention: This release requires firmware update (180810 or later) for proper work!
Higgy
Postby Higgy » Fri Aug 10, 2018 7:22 am
Thanks for tape input, I look forward to getting home and trying this feature. 8)
Postby Sorgelig » Fri Aug 10, 2018 7:46 am
Actually i didn't try tape input myself. So testers are needed.
breiztiger
Postby breiztiger » Fri Aug 10, 2018 12:51 pm
hi
breaking baud work very vell in 6128 mode !!! good work :cheers:
can you please make a real 464 model ? without any fdc physicaly connected as some game test that before launch
bug in druid II
http://www.cpc-power.com/index.php?page=detail&num=818
screen mode not correctly display
Postby Sorgelig » Fri Aug 10, 2018 1:04 pm
Create eZ0 extension with 464 ROMs and FF in ROM page 7 and load it in 664 mode.
You will get 464 mode.
Postby Sorgelig » Fri Aug 10, 2018 1:06 pm
Give me links to games not working in 664 mode.
It's hard to believe there are still such games exist and no one hacked them to work at least on CPC664.
Postby Sorgelig » Fri Aug 10, 2018 1:10 pm
breiztiger wrote:hi
You are MiSTer user, right? It's better to post in MiSTer forum then - so i will not mess between MiST and MiSTer.
MiST doesn't support CDT files.
Postby Sorgelig » Fri Aug 10, 2018 1:30 pm
breiztiger wrote:bug in druid II
It seems CRTC0 game. So, you need to switch CRTC to Type 0 and it will be displayed correctly.
breiztiger
Postby breiztiger » Fri Aug 10, 2018 1:55 pm
I’m on vacation and i can’t test but as i remember druid2 work well on my CRTC 1 6128
If someone can test before i go back...
And cpc-power say that it work on cpc+
Postby Sorgelig » Fri Aug 10, 2018 2:29 pm
Ok. I will check. Something is really strange with this game.
ManuFerHi
Postby ManuFerHi » Fri Aug 10, 2018 2:45 pm
Sorgelig wrote:Release 20180810:
Thanks for your contribution, tape input is great improvement.
Postby Sorgelig » Fri Aug 10, 2018 3:47 pm
Actually, WinAPE also shows flickering video in Druid II game if i choose CRTC1. CRTC0 works fine.
JavaCPC shows ok on both CRTC0 and CRTC1, but it's hard to trust JavaCPC as it detects some specific demos/games and change the parameters.
ManuFerHi
Postby ManuFerHi » Fri Aug 10, 2018 8:30 pm
Sorgelig wrote:Actually i didn't try tape input myself. So testers are needed.
Works fine on Mistica!
https://youtu.be/FRKSN8nSB9w
But I do not hear sound, is strange without sound. I think Amstrad CPC tape sound is not in schematic, possible cassette speaker?
desUBIKado
Postby desUBIKado » Fri Aug 10, 2018 9:19 pm
Hi Manu:
I also tried it this afternoon on Mistica with the game Booty, which plays music during loading, so in this case, I did not care that the sound of the tape does not come out.
Users browsing this forum: jamesrc and 2 guests
