BBC Micro
hoglet
Re: BBC Micro
Postby hoglet » Tue Jul 24, 2018 4:15 pm
To run Tube Elite from the SD Card on a real Beeb with the 6502 Co Pro running, the following is used:
*DIN 45
*TUBEELT
Give that a try?
You can list all the disk images with:
*DCAT
NML32
Re: BBC Micro
Postby NML32 » Tue Jul 24, 2018 8:42 pm
hoglet wrote:To run Tube Elite from the SD Card on a real Beeb with the 6502 Co Pro running, the following is used:
*DIN 45
*TUBEELT
Give that a try?
*DCAT
olin
Re: BBC Micro
Postby olin » Fri Nov 09, 2018 11:32 pm
I just ported BBCMicro core to my de0ns version of MiSTer. One thing I noticed was strong screen flicker caused by the default interlaced mode. I remember that interlaced mode is how the original computer works, so in this respect the core reproduces it perfectly. However my eyes suffer watching the interlaced screen on my TV. Not only that, one of my VGA LCD monitor could not even display such video mode when using scan doubler option and the other VGA flat panel displayed strong simulated flicker as well. I was able to disable it and thought you might find it useful. The mod is very simple, just disable the interlace in the code: mc6845.vhd, line 357, like this
      --if r08_interlace(0) = '1' then
      --   odd_field <= not odd_field;
      --else
         odd_field <= '1';
      --end if;
basically this mod enables only the odd fields. That's it. Recompile the core and you are done.
Please note I haven't tested this mod extensively, just played a few games, but it seems to work fine so far. It's quite possible some video effects may be lost in certain games, therefore keep your original core if you want to preserve full software compatibility.
Edit: Just thinking about it a bit more, maybe I should have added another option into the menu to disable and enable the interlace...
Re: BBC Micro
Postby Sorgelig » Sat Nov 10, 2018 12:32 am
With VIP Scaler there is deinterlacer included. So, on HDMI(main MiSTer video output) there is no flicker.
alanswx
Re: BBC Micro
Postby alanswx » Sun Nov 11, 2018 4:43 am
I saw this posted:
Code for a classic BBC game:
https://github.com/KevEdwards/CrazeeRiderBBC
diggie
Re: BBC Micro
Postby diggie » Tue Nov 13, 2018 4:07 am
Sorgelig wrote:I never had and even never saw this computer in real life.
Thanks for porting this core! The BBC micro was extremely common in UK schools and many kids in the 80s and 90s probably used one to learn programming in BASIC. Certainly these were still doing duty in high schools in Scotland through the 90s.
Dirtbag
Re: BBC Micro
Postby Dirtbag » Sun Dec 09, 2018 3:57 pm
VGA out on the BBC Micro core has a jiggling effect for me I've captured it here bit can't upload it because of the 500KB limit, but I can share if needed. I don't have this with any other core and it's the same no matter what software I load on the BBC.
olin
Re: BBC Micro
Postby olin » Sun Dec 09, 2018 6:57 pm
Dirtbag wrote:VGA out on the BBC Micro core has a jiggling effect for me I've captured it here bit can't upload it because of the 500KB limit, but I can share if needed. I don't have this with any other core and it's the same no matter what software I load on the BBC.
See my post about 5 items above for a partial solution.
nico24
Re: BBC Micro
Postby nico24 » Mon Dec 31, 2018 5:57 am
Is it possible to save anything in this core? Ideally it would be possible to save listings typed in basic back to some sort of storage. For me these cores are about more than just playing old games, but also learning about original programming
Re: BBC Micro
Postby Sorgelig » Mon Dec 31, 2018 8:00 am
Probably, yes.
You need to understand how virtual disk system works in this core. It's done through BBC BIOS extension, so most likely it supports write. In either B or Master mode.
nico24
Re: BBC Micro
Postby nico24 » Tue Jan 01, 2019 4:23 am
Great thanks Sorg-meister! I'll start investigation.
nico24
Re: BBC Micro
Postby nico24 » Wed Jan 02, 2019 12:20 am
Ok - after faffing around with it all day, I can confirm that you CAN write to a disk in this core. But it needs to be an MMB file located on a second sd card in the expansion board. The Beeb.mmb file contains 4 virtual disks - below is a short description of some commands to type for navigation:
*. or *CAT - show files on the virtual drive
there are about 512 disks on each drive
*DRIVE X - with the number being 0 to 3 selects one of the 4 disks
*DIN XXX - with number being 0 to 510 selects a disk
You can then use typical commands to save load etc.
If you want to play around with the beeb.mmb file there is a windows executable called MMB Imager that can create and edit them - so you can inject your own SSD disk images into them.
A good day's sleuthing. Thanks to Dave Hoglet for helping out on the Stardot forum.
Re: BBC Micro
Postby Sorgelig » Wed Jan 02, 2019 12:32 am
I think write should work with VHD as well. But since write operation never tested, it might have problems.
Good it works at least with second SD card.
Re: BBC Micro
Postby Sorgelig » Wed Jan 02, 2019 12:39 am
By the way, you don't need FAT wrapper for BEEB.MMB. You can use MMB directly. Just rename MMB to VHD and it will work from the primary SD card.
May be this way write will work?
nico24
Re: BBC Micro
Postby nico24 » Wed Jan 02, 2019 11:12 pm
Just for info I did try it. First you are right the mmb file works if just renamed to vhd, and NO it won't write back to it if it's the primary SD card - it has to be the secondary. Same with the MiST, except the MiST doesn't give the option for a second sd slot.
Xtro
Re: BBC Micro
Postby Xtro » Sun Feb 24, 2019 9:22 am
I have the same jiggling/vibration on screen through VGA output in 15khz and 31khz, tried with several monitors and the same vertical vibration. BBC core on MiST doesn't have this effect, maybe could be easily fixed.
Vwbug2010
Re: BBC Micro
Postby Vwbug2010 » Fri Apr 19, 2019 1:12 pm
Hi there very impressed with this core. Only problem is with HDMI wide screen or 4:3 it chops the top and bottom off the display, any ideas?
Also can you just boot straight into BBC basic rather than loading the complication?
Simon
Re: BBC Micro
Postby Sorgelig » Fri Apr 19, 2019 7:25 pm
Vwbug2010 wrote:Hi there very impressed with this core. Only problem is with HDMI wide screen or 4:3 it chops the top and bottom off the display, any ideas?
Simon
it's your TV cuts the video. Check TV settings - probably it has option like PC or Game.
Vwbug2010
Re: BBC Micro
Postby Vwbug2010 » Tue Apr 23, 2019 7:51 pm
Great yes your right it was the TV thanks :-)
Also how do you get the core to boot straight to BBC basic rather than having the card message?
Simon
Vwbug2010
Re: BBC Micro
Postby Vwbug2010 » Sat May 04, 2019 7:24 pm
Does any one know on Citadel why when you move rooms the screen goes a bit funny? It should be black but on my mister core it takes the room name and enlarges it? The game plays fine except for the room transition I should add
straddle
Re: BBC Micro
Postby straddle » Thu May 09, 2019 2:05 pm
Oh the BBC Micro - it was the first computer I ever used. We had one in our classroom at school. I remember playing Repton and Citadel for hours!!! They were both great games in their day, and Repton's gameplay would still hold up today - the ability to create your own levels, made it endlessly replayable. Well worth checking out if you have never played it.
Gameplay video: https://www.youtube.com/watch?v=bNRlnNIOXwk
There were lots of versions of Repton over its lifespan: https://en.wikipedia.org/wiki/Repton_(video_game)
Here's Citadel:
https://www.youtube.com/watch?v=yCzbo8j77B0
https://en.wikipedia.org/wiki/Citadel_(video_game)
Users browsing this forum: Frobozzz and 5 guests
