[ZX Spectrum Core] New Update
Re: [ZX Spectrum Core] New Update
Postby Sorgelig » Thu Jan 10, 2019 11:52 pm
slingshot wrote:Don't be so excited about GS support on MiST, it's even eats up almost all BRAM on MiSTer :)
Not all. only 64KB :) But it uses DDR3 as main memory.
slingshot
Postby slingshot » Fri Jan 11, 2019 10:37 am
Sorgelig wrote:Not all. only 64KB :) But it uses DDR3 as main memory.
"only" :)
desUBIKado
Postby desUBIKado » Fri Jan 11, 2019 11:11 pm
Hi there.
I notice the Caprize (demo) and Bomb Jack (game) don't work well with the last core of Spectrum (zxspectrum_20180922.rbf), however on a old core (SPECTRUM_EAR.rbf) both of them work fine.
I have included the 3 archives in this .zip file:
Caprize_BJ.zip
Caprize must run on +2A/+3 mode, and Bomb Jack on 48K or 128K mode.
Regards.
DanyPPC
Postby DanyPPC » Sun Feb 03, 2019 7:19 pm
Downloaded Popie from World Of Spectrum and converted from TZX to TAP thanks to Win_TZX2TAP_0.21, but the game doesn't work.
So I tested the tap file on Spectaculator in ZX128 mode and it works properly.
For some time I wanted to report that even the demo Aeon doesn't start, but I tested it successfully on my Just Speccy 128 from Zaxon.
Is there space for un update to the Spectrum core ?
Higgy
Postby Higgy » Sun Feb 03, 2019 7:42 pm
DanyPPC - be careful with TZX conversion, I tried converting the following game and it would not run on a real Speccy!
http://www.indieretronews.com/2019/01/dog-walk-clean-up-dog-poop-48k-zx.html?m=1
slingshot
Postby slingshot » Sun Feb 03, 2019 8:02 pm
DanyPPC wrote:Downloaded Popie from World Of Spectrum and converted from TZX to TAP thanks to Win_TZX2TAP_0.21, but the game doesn't work.
If the game doesn't use the ROM loader, turbo loading from TAP is not possible. You have to use the slow method (e.g. type LOAD "" before you select the .TAP). Also it's possible that you must start/stop the tape manually (F1/F2).
DanyPPC
Postby DanyPPC » Sun Feb 03, 2019 8:30 pm
The problem isn't loading, but the game itself which doesn't work.
I don't know why Aeon demo doesn't work too.
slingshot
Postby slingshot » Sun Feb 03, 2019 8:33 pm
Try the attached build.
DanyPPC
Postby DanyPPC » Mon Feb 04, 2019 8:00 am
slingshot wrote:Try the attached build.
Oh yes ! Now the game Popie works :cheers:
DanyPPC
Postby DanyPPC » Mon Feb 04, 2019 8:29 am
Regarding "Aeon" demo I converted the scl to trd format and loaded it in TR-Dos mode.
Now it works properly.
Many thanks for the help !
desUBIKado
Postby desUBIKado » Mon Feb 04, 2019 7:28 pm
Caprize (demo) and Bomb Jack (game) work well again with the last core. Thank you slingshot, your work is fantastic!
fons
Postby fons » Mon Feb 04, 2019 7:34 pm
:cheers: Fantastico !! Muchas gracias
jamesrc
Postby jamesrc » Thu Feb 07, 2019 8:32 pm
I plan to update to this build tonight, myself.
Will these changes make their way back to the git repo?
slingshot
Postby slingshot » Fri Feb 08, 2019 8:16 am
It's already there for some weeks.
RobeInie
Postby RobeInie » Mon Apr 08, 2019 9:59 pm
Hi !!
Anyone with Fast Tape Load option problems ?
I got an intermitent border (red to blue) when I try to use Fast-Load ... Only when I open Tape Loader, then I select TAP file... And it goes with normal and classic Loading speed... Then, if I change Fast Tape Load to ON, there is no Fast Speed.
I tried old ESXDOS core and it works well with this (change to Fast Tape Load and it continues loading, with higher speed).
THanks!
RobeInie
Postby RobeInie » Wed Apr 10, 2019 10:33 pm
News about the problem:
I have tried a new SD card. With only the Spectrum core. Last core and others... And the problem is the same ... What a mistery !! But no problem on the old version of DivMMC...
If I start the tape at normal speed and I change it to Fast Load option... crashes... (border blue and red, intermittent)
If I start the tape at normal speed and I change speed manually with F5, F6, F7... is working... but no F8 directly...
Perhaps is a problem of my MiST ? Some weeks ago, it worked well as always, without problems.
I have tested another keyboard also, and the problem is the same.
Some goes wrong when I put 56mhz mode.
There is any way for testing my MiST ?
slingshot
Postby slingshot » Thu Apr 11, 2019 8:11 am
Are you changing the fast load option during loading?
RobeInie
Postby RobeInie » Thu Apr 11, 2019 11:56 am
Yes, I switch the option from OFF to ON... during loading (I start loading game at normal speed , and then I change the option to accelerate tape loading). Is it the problem ?
I remember doing this at the past with no problem.
Thanks,
slingshot
Postby slingshot » Thu Apr 11, 2019 12:06 pm
I cannot tell if it should work like that, but I don't think it's designed for this use case :) Using "properly" is mentioned in the core doc.
Just press F8 if you already started the loading.
slingshot
Postby slingshot » Sat May 18, 2019 6:23 pm
If somebody still misses TZX support:
https://github.com/gyurco/ZX_Spectrum-1 ... 190518.rbf
There are some TZXes which contains blocks like loops and calls, they're not supported, but hopefully the majority of them will work.
DanyPPC
Postby DanyPPC » Sun May 19, 2019 12:41 pm
Oh, many thanks !
Now I'll wait z80 support :D
fury23
Postby fury23 » Sun May 19, 2019 3:33 pm
slingshot wrote:If somebody still misses TZX support:
Tkank You so much :cheers:
RobeInie
Postby RobeInie » Sun May 19, 2019 6:37 pm
Good news,
Thanks !
jamesrc
Postby jamesrc » Mon May 20, 2019 1:39 am
slingshot continuing to make all my MiST dreams come true. Good god! Do you ever sleep? :D
DrOG
Postby DrOG » Mon May 20, 2019 4:55 am
Thanks and respect! :cheers:
