PCEngine core issues with roms?
DrOG
Re: PCEngine core issues with roms?
Postby DrOG » Sun Dec 16, 2018 4:56 am
desUBIKado wrote:Finally on this 181207-beta core 15 KHz output is well centered. slingshot thank you, thank you, thank you.
I can confirm this: both component progressive and RGB interlaced pictures are well-centered! Unfortunately no picture if component is set to interlaced or via direct VGA out, perhaps the fault of my TV... Anyway, nice improvements in terms of compatibility!
Thank you slingshot! :cheers:
slingshot
Postby slingshot » Sun Dec 16, 2018 11:49 am
Finished the SuperGrafix port from MiSTer. For the increased demand on memory bandwidth, the SDRAM clock was increased to 126 MHz, hopefully it won't be unstable (it's still in spec, MiSTs should have 133 MHz SDRAM).
The FPGA's internal BRAM usage:
M9Ks 66 / 66 ( 100 % )
So don't expect many more improvements from now :)
https://github.com/gyurco/FPGAPCE/releases/tag/181216
PS: rename SuperGrafix ROMs to have an .sgx extension, and load them via the 2nd menu option.
DrOG
Postby DrOG » Sun Dec 16, 2018 12:09 pm
:megaphone: WOW!!! Big thanks!!! :cheers:
DanyPPC
Postby DanyPPC » Sun Dec 16, 2018 1:30 pm
:cheers: Good work !!!
The SuperGrafix games are only 5, am I wrong ?
I tested the last Madou_King_Granzort_(J)_(SGX) and desn't work on my system. Could someone test it ? Thanks.
slingshot
Postby slingshot » Sun Dec 16, 2018 1:35 pm
DanyPPC wrote::cheers: Good work !!!
It starts for me.
I see 6 games:
1941
Aldynes
Battle Ace
Darius Plus (it works on a regular PCE, too)
Ghouls'n'Ghosts
Granzort
Chris23235
Postby Chris23235 » Sun Dec 16, 2018 1:38 pm
slingshot wrote:Finished the SuperGrafix port from MiSTer. For the increased demand on memory bandwidth, the SDRAM clock was increased to 126 MHz, hopefully it won't be unstable (it's still in spec, MiSTs should have 133 MHz SDRAM).
Many thanks, all Roms now work, finally I can play 1941 - Counter Attack on the Mist. :cheers:
DanyPPC
Postby DanyPPC » Sun Dec 16, 2018 1:39 pm
Ok, thanks Slingshot. I'll check another rom.
Higgy
Postby Higgy » Sun Dec 16, 2018 1:41 pm
Cool work. .sgx seems to work fine on my v1.2 MiST which had issues with (now fixed) Cores which had memory speed issues. So 122mhz should be good for everyone.
Chris23235
Postby Chris23235 » Sun Dec 16, 2018 1:51 pm
There's a seventh Supergrafx Game. Darius Alpha is a Boss Rush version of Darius Plus and also has Supergrafx support, I just tried it and it also works fine like the other six games.
When I loaded 1941 for the first time, I just got a black screen, this didn't happen again (tried all games several times now), so I guess it won't happen again.
hyperterminal
Postby hyperterminal » Sun Dec 16, 2018 6:47 pm
Thanks to all involved for this great update!
On the PC Engine core for MiSTer there were two games that didn't work: "Andre Panza Kick Boxing" (bad graphics) and "Davis Cup Tennis" (crashes when you start to play): viewtopic.php?p=353575#p353575
Since this is a port from the MiSTer core, I assume it is the same on the MiST. Fixing these bugs might be the last step needed to achieve 100% compatibility.
squid4
Postby squid4 » Sun Dec 16, 2018 7:14 pm
Superb work as usual slingshot, thanks. Great to see the MiST having such a great version of the PCEngine. So many great cores on the MiST! 8)
seastalker
Postby seastalker » Wed Dec 19, 2018 5:19 pm
slingshot, you are a king for the PCE updates! Supergrafx support? Tears of joy!! THANK YOU!!!!
fry
Postby fry » Thu Dec 27, 2018 10:46 pm
CD games? I don't see it mentioned, so I'm assuming that's not implemented.
Lroby74
Postby Lroby74 » Fri Jan 11, 2019 11:09 am
I've tried David Cup Tennis on Mist and crashes same way
hyperterminal wrote:Thanks to all involved for this great update!
DanyPPC
Postby DanyPPC » Fri Feb 15, 2019 7:10 pm
Latest core https://github.com/gyurco/FPGAPCE/releases/tag/190214 has graphic problems on 1941 title screen.
Also saving some options in menù do not acts properly.
Previous core is good.
Higgy
Postby Higgy » Fri Feb 15, 2019 7:49 pm
Confirmed with 1941 SGX. However look at the game in Core 181220b - look at the title screen 'Red 1' it has minor glitches.
vebxenon
Postby vebxenon » Fri Feb 15, 2019 8:05 pm
Higgy wrote:Confirmed with 1941 SGX. However look at the game in Core 181220b - look at the title screen 'Red 1' it has minor glitches.
Same here.
- Atari Jr 2600 clone
- Atari 7800 Peritel
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
slingshot
Postby slingshot » Fri Feb 15, 2019 10:49 pm
DanyPPC
Postby DanyPPC » Sat Feb 16, 2019 7:22 am
That works, but when I save the joystick swap option it saves the "6 button enable" bottom option instead.
slingshot
Postby slingshot » Sat Feb 16, 2019 10:26 am
Delete the fpgapce.cfg from your sd-card.
DanyPPC
Postby DanyPPC » Sat Feb 16, 2019 12:50 pm
Done, but in this way I can't save the swap joypad option, and the default joypad isn't active starting the core. So, I have to manually make it everytime I launch the core.
hyperterminal
Postby hyperterminal » Sat Feb 16, 2019 1:30 pm
Thank you for the update to the core. I'm not sure if this is a regression, but in F1 Circus '91 you can't get past the title screen.
Also it would be nice if the option to remove the sprite limit could be ported over from the MiSTer core.
slingshot
Postby slingshot » Sat Feb 16, 2019 1:44 pm
DanyPPC wrote:Done, but in this way I can't save the swap joypad option, and the default joypad isn't active starting the core. So, I have to manually make it everytime I launch the core.
That's weird, do a filesystem check on your sd-card. The settings file is saved by the firmware, the core has nothing to do with that.
slingshot
Postby slingshot » Sat Feb 16, 2019 1:53 pm
hyperterminal wrote:Thank you for the update to the core. I'm not sure if this is a regression, but in F1 Circus '91 you can't get past the title screen.
I think it needs some backup RAM support (to save progress).
DanyPPC
Postby DanyPPC » Sat Feb 16, 2019 2:28 pm
slingshot wrote:That's weird, do a filesystem check on your sd-card. The settings file is saved by the firmware, the core has nothing to do with that.
Ok, now works. Thanks
