PCEngine core issues with roms?
DanyPPC
Re: PCEngine core issues with roms?
Postby DanyPPC » Mon Dec 03, 2018 4:48 pm
I forgot to say that I use only old core
https://github.com/mist-devel/mist-bina ... engine/old
Excuse me.
Remember with new only problems...
slingshot
Postby slingshot » Mon Dec 03, 2018 5:20 pm
DanyPPC wrote:I forgot to say that I use only old core
Excuse me.
Ah, ok, the SDRAM clock increase was a "recent" change. Changing it back 2x sysclock (~85 MHz) solves the stability problems. Just need to optimize the SDRAM controller to reduce the visual glitches.
Higgy
Postby Higgy » Mon Dec 03, 2018 7:04 pm
The standard menu would also be great, as you can't navigate the current one with a controller.
CRT TV (15kHz) users - do you find this Core is shifted over to the left too much compared to other Cores?
This is good for testing - http://junkerhq.net/xrgb/index.php?title=240p_test_suite
slingshot
Postby slingshot » Tue Dec 04, 2018 12:50 pm
Higgy wrote:The standard menu would also be great, as you can't navigate the current one with a controller.
That's good, just controls doesn't work in the test suite :)
Btw, I've mostly finished my cleanup work on the core:
https://github.com/gyurco/FPGAPCE/releases
I didn't fix anything in CPU or VDP, so don't expect a Gensis level compatibility, just ported the Huc6260 from MiSTer, since it gave a good centering for me.
Game compatibility should be the same as before (e.g. Afterburner doesn't work), but it's now stable for me at least, no more freezes.
desUBIKado
Postby desUBIKado » Tue Dec 04, 2018 1:04 pm
Higgy wrote:CRT TV (15kHz) users - do you find this Core is shifted over to the left too much compared to other Cores?
Yes. viewtopic.php?f=115&t=28506&start=25#p356501
DanyPPC
Postby DanyPPC » Tue Dec 04, 2018 7:44 pm
Thanks Slingshot, I tested some roms and there are ones which first did work with previuos core, for example R-Type.
Or I have to download a different version of some roms.
Anyway good work as first beta release. The street is the right one and I hope to see a SuperGraphix compatibility one day :)
slingshot
Postby slingshot » Tue Dec 04, 2018 8:19 pm
DanyPPC wrote:Thanks Slingshot, I tested some roms and there are ones which first did work with previuos core, for example R-Type.
R-Type works for me, both Japanese and US.
DanyPPC
Postby DanyPPC » Tue Dec 04, 2018 8:21 pm
So, I have to test other version of roms.
slingshot
Postby slingshot » Tue Dec 04, 2018 8:25 pm
DanyPPC wrote:So, I have to test other version of roms.
512-byte ROM headers were supported by the original core, now I see your ROM version has it. I didn't found it important, so skipped supporting it. I'll add that.
If a 256k ROM size is 262656 bytes, then it has the header, if 262144, then it hasn't. The later will work now.
DanyPPC
Postby DanyPPC » Tue Dec 04, 2018 8:32 pm
Perfect !
slingshot
Postby slingshot » Tue Dec 04, 2018 8:53 pm
DanyPPC wrote:Perfect !
Re-upped with ROM header support as 181204c-beta:
https://github.com/gyurco/FPGAPCE/releases/tag/181204c
Higgy
Postby Higgy » Tue Dec 04, 2018 9:30 pm
Yeah! No more text file for TV / VGA :)
Picture looks only slight off to the left on 15Khz TV, so pretty good. Much better centering than the last Core :wink:
Useful test ROMS for checking screen modes, sound etc - https://www.chrismcovell.com/creations.html
TheSaint123
Postby TheSaint123 » Tue Dec 04, 2018 11:05 pm
Thank you very much for this new improved Core !
Soldierblade 768kb has Blackscreen ,and R-Type has Grafik Glitches !
and the Scanlines is ON have slowdown Games !
Regards
DanyPPC
Postby DanyPPC » Wed Dec 05, 2018 8:30 am
Good job !
Now most of my selected rom work :cheers:
I play R-Type (Japan) version which is divided in 2 parts as originally designed for this console.
USA one-part version is bugged.
slingshot
Postby slingshot » Wed Dec 05, 2018 9:01 am
TheSaint123 wrote:and the Scanlines is ON have slowdown Games !
Regards
That one is funny :) It's impossible for the scanlines to slow down anything. Only if your monitor lags more with scanlines enabled.
slingshot
Postby slingshot » Wed Dec 05, 2018 9:02 am
DanyPPC wrote:USA one-part version is bugged.
It starts for me. But I die too fast in this game.
seastalker
Postby seastalker » Wed Dec 05, 2018 3:25 pm
MAJOR THANKS SLINGSHOT!!! I look forward to testing this update!! In theory, is there enough room on the Mist to support SuperGrafx in this core?
Higgy
Postby Higgy » Wed Dec 05, 2018 4:03 pm
Image showing improvements to CRT 15kHz image centering:
slingshot
Postby slingshot » Wed Dec 05, 2018 4:30 pm
seastalker wrote:MAJOR THANKS SLINGSHOT!!! I look forward to testing this update!! In theory, is there enough room on the Mist to support SuperGrafx in this core?
FPGA space is enough, the question is the SDRAM bandwidth is adequate for the 128k VRAM and the dual VDP.
DanyPPC
Postby DanyPPC » Wed Dec 05, 2018 4:39 pm
Yes, I confirm the screen is a litte out of center, expecially on PAL monitor.
There are some roms which don't work, for example: Batman, Break-In, Cadash, Puzznic, Magical Chase, Ninja Gaiden, Racing Spirits, SF 2, Star Soldier, TV Sports series, World Beach Volleyball.
R-Type USA has wrong colors, Japan one is perfect.
Other like Darius Alpha, Darius Plus the image screen is cut on the edges.
Tatsujin (Truxton on MegaDrive) shows slowdown at start, like in the old core.
But most of games just work well. Thanks Slingshot.
DanyPPC
Postby DanyPPC » Wed Dec 05, 2018 4:41 pm
slingshot wrote:FPGA space is enough, the question is the SDRAM bandwidth is adequate for the 128k VRAM and the dual VDP.
Is it possible to create a SuperGrafix core only ?
slingshot
Postby slingshot » Wed Dec 05, 2018 4:56 pm
Why would it better? The SuperGrafix itself has 128k VRAM and two Huc6270 VDPs (that was the cheap way to double the PC-Engine graphics capabilities without planning a new video chip).
DanyPPC
Postby DanyPPC » Wed Dec 05, 2018 5:36 pm
I see. thanks.
desUBIKado
Postby desUBIKado » Thu Dec 06, 2018 8:22 am
Old core PC_Engine_20170221
New core FPGAPCE_20181204c-beta
It's much better than old core, only a little slight off to the left . Thanks slingshot.
vebxenon
Postby vebxenon » Fri Dec 07, 2018 12:56 am
Thanks Slingshot! :D
- Atari Jr 2600 clone
- Atari 7800 Peritel
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
