Wifi
Re: Wifi
Postby Sorgelig » Mon Dec 03, 2018 9:08 am
Work with wlan is a weak part of Linux. It's not really plug-n-play. The whole wlan part on Linux consists on hacks and workarounds.
So, if current config doesn't work for you then i suggest to read more about the subject in internet and try to make a working scripts/configs.
diggie
Re: Wifi
Postby diggie » Mon Dec 03, 2018 9:58 am
@Sorgelig I found a fix (that works for me).
This option of dhcpcd always ensures wlan is set up okay:
https://wiki.archlinux.org/index.php/dh ... supplicant
E.g. create link to tell it to start wpa_supplicant if needed, which works if wlan0 is not ready during boot. You can set env to point at /media/fat/linux/wpa_supplicant.conf, or I just copied that to /etc
Another way I see people doing it is running ifup in rc.local.
Anyway, I am glad to finally have wifi in MiSTer, I am definitely not glad to spend the evening with Linux ;)
warham
Re: Wifi
Postby warham » Fri Dec 28, 2018 9:10 pm
Ordered a mi wifi adapter as mentioned in previous post on ebay and shipped from HK.
Copied in the file as mentioned on previous post and got an IP address.
I also see these for sale on aliexpress and a listing on digikey.
(have not bought this one but it matches the terasic part number).
https://www.digikey.com/products/en?keywords=FXX-3061-MIX
Need mt7601u.bin in \lib\firmware
https://github.com/wkennington/linux-fi ... t7601u.bin
I bought this one: https://www.ebay.com/itm/Original-Xiaomi-150Mbps-USB-Powered-Mini-Portable-Mi-WiFi-Adapter-Router-LOT-BY/362446711645?ssPageName=STRK%3AMEBIDX%3AIT&var=631626848430&_trksid=p2057872.m2749.l2649
warham
Re: Wifi
Postby warham » Fri Dec 28, 2018 10:47 pm
misc wrote:
Jaydg wrote:Hi,
Also working with "Xiaomi Mi Portable WiFi" which you can buy on Terasic homepage.
http://www.terasic.com.tw/cgi-bin/page/ ... 6&PartNo=8
I can confirm that this works flawless. This is one of the cheapes possibilities to enhance MISTer functionality. :mrgreen:
Thank you. Appears to be working for me as well. Spent an hour looking around for driver info before I saw your post :p
JimDrew
Re: Wifi
Postby JimDrew » Sat Dec 29, 2018 9:30 pm
I can confirm that the HOMESPOT Wifi adapter works fine. I just changed the SSID/PWD and that's it. You can purchase these from Amazon:
https://www.amazon.com/HomeSpot-150Mbps ... B01ERHE18S
One problem I do have is that when using the Wifi module it overrides the RTC date/time, using some other country I am guessing. Is there a way to set the country when using the Wifi connection?
I am the flux ninja
TuKo
Re: Wifi
Postby TuKo » Sun Dec 30, 2018 1:05 pm
cvenditti wrote:
NML32 wrote:@Sorgelig, thanks for adding wifi support to MiSTer.
The Wiki states some wifi are supported. What USB wifi dongles are supported or could you recommend a few?
This kinds works for me:
https://www.ebay.com/itm/New-150Mbps-15 ... 25c57ee51e
Ordered same one, doesn't work for me.
425.783153] usb 1-1.3: USB disconnect, device number 97
[  426.023377] usb 1-1.3: new high-speed USB device number 98 using dwc2
[  426.134741] usb 1-1.3: New USB device found, idVendor=148f, idProduct=7601
[  426.134758] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  426.134768] usb 1-1.3: Product: 802.11 n WLAN
[  426.134777] usb 1-1.3: Manufacturer: MediaTek
[  426.134785] usb 1-1.3: SerialNumber: 1.0
[  426.213380] usb 1-1.3: reset high-speed USB device number 98 using dwc2
[  426.316291] mt7601u 1-1.3:1.0: ASIC revision: 76010001 MAC revision: 76010500
[  426.319226] mt7601u 1-1.3:1.0: Firmware Version: 0.1.00 Build: 7640 Build time: 201302052146____
[  426.710454] mt7601u 1-1.3:1.0: EEPROM ver:0c fae:00
[  426.895375] mt7601u 1-1.3:1.0: Error: RX urb failed:-71
[  426.900897] mt7601u 1-1.3:1.0: Error: RX urb failed:-71
[  426.906222] mt7601u 1-1.3:1.0: Error: RX urb failed:-71
[  426.911503] mt7601u 1-1.3:1.0: Error: RX urb failed:-71
[  426.916794] mt7601u 1-1.3:1.0: Error: RX urb failed:-71
[  426.922070] mt7601u 1-1.3:1.0: Error: RX urb failed:-71
[  426.927355] mt7601u 1-1.3:1.0: Error: RX urb failed:-71
[  426.932632] mt7601u 1-1.3:1.0: Error: RX urb failed:-71
[  426.937919] mt7601u 1-1.3:1.0: Error: RX urb failed:-71
[  426.943214] mt7601u 1-1.3:1.0: Error: RX urb failed:-71
[  426.948506] mt7601u 1-1.3:1.0: Error: RX urb failed:-71
[  426.953794] mt7601u 1-1.3:1.0: Error: RX urb failed:-71
[  426.959073] mt7601u 1-1.3:1.0: Error: RX urb failed:-71
[  426.964361] mt7601u 1-1.3:1.0: Error: RX urb failed:-71
[  426.969646] mt7601u 1-1.3:1.0: Error: RX urb failed:-71
[  426.974935] mt7601u 1-1.3:1.0: Error: RX urb failed:-71
[  426.981082] mt7601u 1-1.3:1.0: Error: MCU resp urb failed:-71
[  426.986846] mt7601u 1-1.3:1.0: Error: MCU resp evt:0 seq:5-4!
[  426.992632] mt7601u 1-1.3:1.0: Error: MCU resp urb failed:-71
[  426.998413] mt7601u 1-1.3:1.0: Error: MCU resp evt:0 seq:5-4!
[  427.004175] mt7601u 1-1.3:1.0: Error: MCU resp urb failed:-71
[  427.009920] mt7601u 1-1.3:1.0: Error: MCU resp evt:0 seq:5-4!
[  427.016026] mt7601u 1-1.3:1.0: Error: MCU resp urb failed:-71
[  427.021773] mt7601u 1-1.3:1.0: Error: MCU resp evt:0 seq:5-4!
[  427.027717] mt7601u 1-1.3:1.0: Error: MCU resp urb failed:-71
[  427.033470] mt7601u 1-1.3:1.0: Error: MCU resp evt:0 seq:5-4!
[  427.039222] mt7601u 1-1.3:1.0: Error: mt7601u_mcu_wait_resp timed out
[  427.243372] mt7601u 1-1.3:1.0: Vendor request req:07 off:0080 failed:-71
[  427.443381] mt7601u 1-1.3:1.0: Vendor request req:02 off:0080 failed:-71
[  427.643442] mt7601u 1-1.3:1.0: Vendor request req:02 off:0080 failed:-71
[  427.650203] mt7601u: probe of 1-1.3:1.0 failed with error -110
Also got me a DWA-171 (rev C), this one doesn't work as kernel detects the 8GB storage on it (which includes Windows drivers) as a mass storage device...
Re: Wifi
Postby Sorgelig » Sun Dec 30, 2018 1:41 pm
some WiFi modules need specific firmware file in linux.
SnoopKatt
Re: Wifi
Postby SnoopKatt » Sun Dec 30, 2018 4:48 pm
I found that I needed to try different .bin files to make the wifi work. There's lots of variations/versions of a .bin with the same name.
alp
Re: Wifi
Postby alp » Sun Dec 30, 2018 6:48 pm
Sorgelig wrote:It seems i've just contradicted myself :)
I've succeeded to integrate the driver for D-Link 5Ghz dongle! This is a good thing for me since 2.4GHz in my area is too noisy and hard to use.
The first one if tried was TP-Link on mediatek MT7610u chip and all my attempts to make it work were failed. It also uses weird custom settings for authentication - such a rubbish.
D-Link DWA-171 (HWVer: A1) on RTL8812AU chip works well using standard wpa_supplicant. So, at least this WiFi-ac dongle will work in new Linux release. Probably other dongles on the same chip (and RTL8821AU) will work as well.
I've tested mediatek MT7610u, it's working. But tested only with 2.4
Used this docker to build separate kernel
https://github.com/kowoba/Linux-Kernel_ ... Dockerfile
And this gist to build module
https://gist.github.com/FantomJAC/5afb9 ... 2b490e5640
Sources for module tested also from here
https://github.com/ulli-kroll/mt7610u
But got an error with memory:
raspberrypi kernel: [ 11.825048] <-- ERROR in Alloc Bulk buffer for RxContext!
raspberrypi kernel: [ 11.825112] ERROR mt7610u_sta:
raspberrypi kernel: [ 11.825119] Failed to allocate memory - TxRxRing
Here was a solution:
https://github.com/xtknight/mt7610u-lin ... wifi-fixes
Find the string setenv bootargs and add coherent_pool=4M in the end of the line.
After adding to u-boot dongle attached to Wi-Fi
jpxdude
Re: Wifi
Postby jpxdude » Sun Dec 30, 2018 7:25 pm
Just wanted to add that the small “Digitazz” branded WiFi dongles work well with MiSTer as well. It uses the same RT2870.bin file as mentioned near the start of this thread.
cbo2188
Re: Wifi
Postby cbo2188 » Thu Jan 03, 2019 1:51 am
I can confirm the Edimax EW 7811Un USB WIFI adapter works well for me. No issues with it.
https://www.amazon.com/Edimax-EW-7811Un ... B003MTTJOY
breiztiger
Re: Wifi
Postby breiztiger » Thu Jan 03, 2019 7:04 am
hi
i'm noob in linux
"I had to find and copy rtl8192eu_nic.bin to /lib/firmware/rtlwifi for the dongle to work."
how to do that please ?
thanks in advance
hernan43
Re: Wifi
Postby hernan43 » Fri Jan 04, 2019 4:15 pm
I am using a Panda PAU05 dongle:
https://www.amazon.com/Panda-300Mbps-Wi ... ords=pau05
I had to download rtl2870.bin from:
http://www.lwfinger.com/firmware/
I copied it into /lib/firmware and it works fine as far as I can tell.
gojira54
Re: Wifi
Postby gojira54 » Fri Jan 04, 2019 7:37 pm
breiztiger wrote:hi
i'm noob in linux
thanks in advance
Me too - I have no clue with linux and I am was frustrated...
connect to mister via console with UART-to-USB (USB mini type B) using putty program, configure putty connection as per wiki instructions https://github.com/MiSTer-devel/Main_Mi ... connection
log in to using credentials as per wiki https://github.com/MiSTer-devel/Main_Mi ... ork-access
I put the firmware file in folder 'linux' on root of the sd card using windows, in putty once logged in I typed;
mv /media/fat/linux/rt2870.bin /lib/firmware/rt2870.bin
commands that are useful if you know NOTHING of linux like me!
find . LISTS ALL FILES HERE AND SUB DIRS
ls LISTS DIRS OF FOLDER YOU ARE IN
cd /whereyouwantogo CHANGE DIRECTORY, "cd /" IS TOP LEVEL
exit ENOUGH ALREADY
I found I needed to set up my wpa_supplicant.conf like this;
Don't forget in Notepad++ document formatting "Edit > EOL Conversion > UNIX"
Good luck =]
Please do not take it personal, my lawyer has policies
terminator2k2
Re: Wifi
Postby terminator2k2 » Fri Jan 04, 2019 9:58 pm
gojira54 wrote:
breiztiger wrote:hi
i'm noob in linux
thanks in advance
exit ENOUGH ALREADY
Good luck =]
cheers , just used this to get my samsung wifi dongle working
spidersfrommars
Re: Wifi
Postby spidersfrommars » Fri Jan 04, 2019 11:06 pm
Hello,i am having trouble with my wifi usb, it always comes up as wlan2 rather than wlan0 or wlan1 and it wont connect to my wifi. Maybe someone could give me some help? I have the correct firmware and i put my credentials as per the wiki.
edit: i was able to get running by running this command through the serial monitor:
wpa_supplicant -B -i wlan2 -c /media/fat/linux/wpa_supplicant.conf
Re: Wifi
Postby Sorgelig » Sat Jan 05, 2019 12:32 am
spidersfrommars wrote:Hello,i am having trouble with my wifi usb, it always comes up as wlan2 rather than wlan0 or wlan1 and it wont connect to my wifi. Maybe someone could give me some help? I have the correct firmware and i put my credentials as per the wiki.
you can edit the file: /etc/network/interfaces
and add wlan2 interface there
spidersfrommars
Re: Wifi
Postby spidersfrommars » Sat Jan 05, 2019 5:13 am
Sorgelig wrote:you can edit the file: /etc/network/interfaces
Thank you Sorgelig, i will try that! :D
djmartins
Re: Wifi
Postby djmartins » Wed Jan 09, 2019 4:20 am
Jaydg wrote:Hi,
I bought the Xiaomi device on ebay cheaper than terasic and this procedure worked fine for me.
Connected to console used USB and midnight commander to transfer file over and upon reboot
I had an IP!
Fantastic!
warham
Re: Wifi
Postby warham » Thu Jan 10, 2019 12:47 am
In case anyone is looking at this small DLINK USB hub so far it works with everything EXCEPT WIFI.
I can switch over to another hub and get wifi no problem.
https://www.amazon.com/gp/product/B0000B0DL7/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
Re: Wifi
Postby Sorgelig » Thu Jan 10, 2019 10:49 am
country in wpa_supplicant just shows the allowed WiFi channels(frequencies).
It has nothing to do with time.
As for timezone: learn to use MiSTer Wiki.
Locutus73
Re: Wifi
Postby Locutus73 » Thu Jan 10, 2019 1:01 pm
Sorgelig wrote:As for timezone: learn to use MiSTer Wiki.
I agree with the wiki thing, I'd use a new RTFW acronym...
...anyway I made a little timezone.sh script in https://github.com/MiSTer-devel/Scripts_MiSTer (they are downloaded by the updater in a #Script folder) which automatically sets up the MiSTer timezone for end users.
Regards.
Locutus73
zz99
Re: Wifi
Postby zz99 » Sun Jan 13, 2019 10:57 am
cbo2188 wrote:I can confirm the Edimax EW 7811Un USB WIFI adapter works well for me. No issues with it.
Did you do anything special to get it working ?
zz99
Re: Wifi
Postby zz99 » Sun Jan 13, 2019 4:35 pm
Finally got my Edimax device working by setting the wpa_supplicant.conf to :
country=gb
update_config=1
ctrl_interface=/run/wpa_supplicant
network={
scan_ssid=1
ssid="_______"
psk="_______"
Ldaborc
Re: Wifi
Postby Ldaborc » Mon Jan 14, 2019 4:21 pm
I need help with my wifi TP-Link TL-WN725N_V2. How this use in Mister? Install drivers? How? Please.
Users browsing this forum: Optiuk and 10 guests
