Postby Sorgelig » Thu Oct 03, 2019 9:37 pm
apolkosnik wrote:exe_opcode is missing in process() args, I guess it will break PACK/UNPACK
no, it won't. Quartus will warn and add it while synthesising.
apolkosnik
Postby apolkosnik » Thu Oct 03, 2019 9:46 pm
bf_loff_dir was also gone, pull request submitted.
xzarian
Postby xzarian » Fri Oct 04, 2019 12:21 am
I'm having the same issue, can't boot with fastram > 8m. (68020,wb3.1) Before I think it was set to 24m, but I guess that that options gone now? I haven't used this core in months.
Postby Sorgelig » Fri Oct 04, 2019 5:44 am
xzarian wrote:I'm having the same issue, can't boot with fastram > 8m. (68020,wb3.1) Before I think it was set to 24m, but I guess that that options gone now? I haven't used this core in months.
currently i have no idea why.
GoingDown
Postby GoingDown » Fri Oct 04, 2019 12:32 pm
Do you use latest "official" core version which is provided by update script? Because I had similar issue with that version, but later test versions provided by Sorgelig via manual download in this thread works perfectly.
xzarian
Postby xzarian » Fri Oct 04, 2019 4:44 pm
Yes, I was using latest official core, but it now works with the test version Sorgelig posted.
Milongero
Postby Milongero » Fri Oct 04, 2019 5:47 pm
i just got back from vacation and did an update. the Minimig core hasn't changed in a week.
So I tested again different settings to get Lotus 2 and III to run.
Nothing worked until I triggered a core reset in the Minimig OSD. After that both games ran.
For me, the core is now running wonderfully well.
Greetings Lutz
apolkosnik
Postby apolkosnik » Sat Oct 05, 2019 2:19 am
Destination fix for BFFFFO, BFEXT*, MULU.L DIVUL.L
In BFFFFO, BFEXT*, MULU.L DIVUL.L according to the documentation, should only allow Dx as the destination.
https://github.com/MiSTer-devel/Minimig ... ik:patch-3
After going through the Toni's cputester output, I've noticed that some instructions were writing to address registers rather than data registers. I'd like to get a second set of eyes on this before I create a pull request. Thanks!
JimDrew
Postby JimDrew » Sat Oct 05, 2019 4:49 am
I have a pretty thorough test suite for the 020+ instructions, and I focused on the all of the bitfield based instructions. I will take a look at the Minimig core.
SOME bitfield instructions do have extended modes that do use address registers, ie:
TEST_BFINS:
   lea   Me(pc),a0
   moveq   #1,d0
   moveq   #0,d1
   moveq   #0,d2
   bfins   d0,(a0){d1:d2}
   nop
   rts
Me   dc.l $55667788
   dc.l 0,0,0,0,0
TEST_BFCHG:
   lea   Me(pc),a0
   moveq   #0,d2
   moveq   #0,d3
   bfchg   (a0){d2:d3}
   nop
   rts
Me   dc.l $55667788
   dc.l 0,0,0,0,0
While other instructions use a data register, ie:
TEST_BFFFO:
      bfffo   OurStatus+1{0:8},d0
      nop
      rts
OurStatus   dc.w   256
I have a slew of these test snippets that I wrote originally for testing FUSION-PC's CPU core, and more recently used to help debug the Vampire and Replay CPU cores.
I am the flux ninja
Futaura
Postby Futaura » Sat Oct 05, 2019 11:24 am
Wasn't sure where best to report this, but @kolla directed me here... Attached is a test case showing that the MULU.L instruction is broken - it can incorrectly give different results when the parameters are transposed, depending on the numbers involved:
FAIL: MULU.L $a26bd7e0,$7667c08f = $37459620 ($37459620)
PASS: MULU.L $7667c08f,$a26bd7e0 = $b7459620 ($b7459620)
Both the above should obviously yield the same result, as they do on a real CPU. Given the difference between the two results above is $80000000, I'm guessing it is probably an issue related to signedness somewhere.
apolkosnik
Postby apolkosnik » Sat Oct 05, 2019 1:40 pm
Jim, Thank you, that sounds great.
The main issue that I'm trying to address here is when the second word of the previously noted instructions starts with MSB set, which was making the result appear in the address register rather than data register. It's a corner case that could only happen with erroneously generated code.
JimDrew wrote:I have a pretty thorough test suite for the 020+ instructions, and I focused on the all of the bitfield based instructions. I will take a look at the Minimig core.
apolkosnik
Postby apolkosnik » Sat Oct 05, 2019 5:20 pm
Futaura wrote:Wasn't sure where best to report this, but @kolla directed me here... Attached is a test case showing that the MULU.L instruction is broken - it can incorrectly give different results when the parameters are transposed, depending on the numbers involved:
It looks like the MSB gets cleared somewhere.
Postby Sorgelig » Sun Oct 06, 2019 12:52 pm
Here is a new test version. It includes all instructions fixes currently available.
The main change is communication protocol between HPS and Minimig.
I've changed it to make it more generic and use common framework for easier maintenance.
ZIP includes both Minimig.rbf and MiSTer binary. You have to replace them both. New MiSTer won't work with old builds of Minimig. Old MiSTer won't work with new Minimig either.
Other cores are unaffected.
If it works well, then it will go to release.
minimig.zip
breiztiger
Postby breiztiger » Sun Oct 06, 2019 3:02 pm
hi
last test core work great with my save configs (A500 stock, A600 stock and A1200 stock or with hdf attach)
i have found a graphics corruption in Pacmania (1988)(Grandslam).adf with aga, it run great in ecs or ocs mode
i think it's not related to last release
apolkosnik
Postby apolkosnik » Sun Oct 06, 2019 3:08 pm
Breiztiger,
Would it be possible to document the corruption as an issue on github?
https://github.com/MiSTer-devel/Minimig-AGA_MiSTer
breiztiger wrote:hi
remowilliams
Postby remowilliams » Sun Oct 06, 2019 4:11 pm
Latest test core is looking good here so far.
Postby Sorgelig » Sun Oct 06, 2019 5:16 pm
New version with i hope more stable build:
minimig_2.zip
MiSTer binary is the same as in previous build, so i've included it just for completeness.
Please test it.
rondc
Postby rondc » Sun Oct 06, 2019 5:50 pm
Sorgelig, doesn't work for me. Get's me on system like menu core.
What is the MiSTer binary attached to Minimig2.zip ?
rondc
Postby rondc » Sun Oct 06, 2019 6:05 pm
When running Fusion with Kick 3.1, this is what happens...
Recognizes 82MHz 020
Just before finishing the finder load, it crashes and reset the Amiga.
This is the crash msg.
The same sequence using a 3.1.4 KickStart
When booting, this is the 1st yellow guru msg:
After crashing the Fusion , these are the msgs:
And finally the latest yellow guru msg before booting Workbench.
ShapeShifter makes an attempt to start but it also reboots the Amiga.
Thanks a lot for your work ! ! !
optiroc
Postby optiroc » Sun Oct 06, 2019 6:05 pm
Sorgelig wrote:New version with i hope more stable build:
minimig_2.zip
Please test it.
Works like a charm here!
fille1976
Postby fille1976 » Sun Oct 06, 2019 6:31 pm
Thx sorg,gods working now,it was broken for a while,keep up the good work.
apolkosnik
Postby apolkosnik » Sun Oct 06, 2019 6:35 pm
Same here, after moving both filkes onto the MicroSD card to replace the existing binaries (scp will not do the trick since: scp: /media/fat//MiSTer: Text file busy ), it works pretty much the same.
Workbench loaded, ran a few demos. No visible difference so far.
minimig_2.zip
Please test it.
Postby Sorgelig » Sun Oct 06, 2019 7:07 pm
rondc wrote:Sorgelig, doesn't work for me. Get's me on system like menu core.
congratulation with not able to read messages.
apolkosnik
Postby apolkosnik » Sun Oct 06, 2019 7:30 pm
I think that might be a side effect of one of the latest fixes. Possibly some stack values get corrupted. Lately, I've experienced a crash when running "cputest all abcd.b continue" somewhere before mulu.l, but if I'd start it from the m-instructions, it goes fine.
rondc wrote:When running Fusion with Kick 3.1, this is what happens...
JimDrew
Postby JimDrew » Mon Oct 07, 2019 7:02 am
Well... other than the Vampire, that's the first time I have seen any FPGA based Amiga emulation even be able to start the Mac with FUSION! I will have to look into see why FUSION is crashing.
I am the flux ninja
Users browsing this forum: yoshi41 and 10 guests
