MiSTer - Case Universal v5.2 - 3D printed
NegSol
Re: MiSTer - Case Universal v5.2 - 3D printed
Postby NegSol » Thu Mar 22, 2018 7:41 pm
Looks good! Good work! :)
deadlocked
Postby deadlocked » Fri May 04, 2018 2:55 am
My "xs" case printed on my toy 3D printer.
I had to change the push buttons as they were not tall enough to reach the top of the case. If you get the XS case, you may have to do the same. I added a (plastic) spacer the same height of the metal spacers to the I/O board (you can see it right next to the memory board) to prevent the board from sagging down on the end that does not reach the edge screws. I also put a plastic separator on top of the RJ45 jack to keep the bottom of the I/O board from short-circuiting against the metal. The fan will be flush against the top of the case, as there is no clearance left, but the case does close…. Oh and I used the metal spacers that came with the DE-10 board, as they were just about the right height for about 1mm off the top of the button caps to peek through the top of the case.
Since the I/O board does not reach the spacers on the LED/button side of the board, the whle board will sag on that end when you press a button. The extra plastic spacer that I added and the 1mm plastic disk that I added on top of the Ethernet jack will keep the board level.
Postby Sorgelig » Fri May 04, 2018 3:35 am
@deadlocked
It seems your photos are missing
You can add a plastic spacer near the SDRAM board - that's why there is a 3mm hole there.
deadlocked
Postby deadlocked » Fri May 04, 2018 3:46 am
@Sorgelig
I tried uploading the photos several times from different browsers. I always get "Error parsing server response", so I cannot upload anything.
and yes, the hole right next to the RAM board is where I put the spacer, you would clearly see it in the pictures... if the forum allowed me to upload.
Tried to zip the files and I got "file is too big" error.
Postby Sorgelig » Fri May 04, 2018 4:16 am
you can upload pics on some other picture sharing site and then link to it.
This forum is very restrictive, unfortunately.
NegSol
Postby NegSol » Fri May 04, 2018 11:01 am
I would be interested in see your photos too :)
I guess it depends on the push buttons you use. I modelled the XS close to the v.5.2. And my v5.2 buttons can be pushed without to much force, so it works without spacer for me. But sure - space are a good solution should you have the need to compensate here. :D
Anyways, thanks for your feedback on the XS!
nightshadowpt
Postby nightshadowpt » Sat Oct 13, 2018 1:22 pm
Hi NegSol,
Just out of curiosity, did you ever figured a solution to use 80mm or 60mm fans in the case?
I am now using my MiSTer quite a bit more and I'm thinking about 3D printing your model, but would like to use the latest version and (if available) one with support for larger fans.
Also, do you recommend any place to order it from?
Cheers,
NegSol
Postby NegSol » Sat Oct 13, 2018 4:06 pm
Larger fans are not really required imho. I use a 40x40x20 fan with halfed voltage. With lower voltage noctua fans run nearly silent. I use this one https://noctua.at/en/nf-a4x20-flx for both my MiSTers.
As for the case, 5.2 universal is still the go to case.
https://www.thingiverse.com/thing:2684660
5.2 should work with most MiSTer configurations.
There is an XS variant available, should you really be interested in a smaller form factor.
https://www.thingiverse.com/thing:2740925
Sellers of cases are around. I have seen them on facebook and also with online stores etc.. I guess most print the cases on privat printers or hire somebody locally to do it. Thingiverse has a build-in print service finding section.
Cases are available on shapeways for thoses who want professional service (see my signature). Prices of shapeways are twice as high though. :megaphone:
nightshadowpt
Postby nightshadowpt » Sat Oct 13, 2018 5:02 pm
NegSol wrote: I use a 40x40x20 fan with halfed voltage.
The problem is that solution requires additional soldering skills (that I don't have) and it's not as plug and play as just swapping the fan.
Just checked the price on shapeways and wow... 104€ for the case...
Does the quality difference justify the price? (honest question)
Cheers,
NegSol
Postby NegSol » Sat Oct 13, 2018 5:21 pm
I do not know what soldering skills you are referring to. I/O-Board of MiSTer hast plenty of connectivity options. You will find 5v and 3,3v pins exposed. The fan has minimal power requirements. Of course a pin connector or something you crimp on has to be attached to the fan, but soldering I don't see.
Cheers,
For some it apparently does - I do not blame them - I also personally like shapeways services. :D
nightshadowpt
Postby nightshadowpt » Sat Oct 13, 2018 6:27 pm
NegSol wrote:I do not know what soldering skills you are referring to. I/O-Board of MiSTer hast plenty of connectivity options. You will find 12v, 5v and 3,3v pins exposed. The fan has minimal power requirements. Of course a pin connector or something you crimp on has to be attached to the fan, but soldering I don't see.
Admittedly, it could be my ignorance about the board, but when I look at the picture where you have connected the Noctua, my board does not have those pins... (I rechecked). I can solder some, but right now, there's only the traces there...
Anyway, I'll find a solution.
Thanks for the case design!
NegSol
Postby NegSol » Sat Oct 13, 2018 6:46 pm
I guess you have a v5.5 I/O board. Correct? Yes, those are a bit more streamlined. v3.1 and 5.2 (the ones I own) had more pins ...
Anyways, for the v5.5 (which I do not have) my best bet would be to use the existing 5v fan pins. Just attach a 12v fan. Use a noctua fan and it should spin up just fine. Cheap 12v fan might refuse to spin up :mrgreen:
THaase
Postby THaase » Sun Oct 14, 2018 7:07 am
Or you use the 5V version (NF-A4x10-5v) as I do and add a 68R resistor (1/8W us fine) to the powerline.
The 5V version needs about 3.1V to start and consumes about 0.28mA (if I remember it right).
So using 68R reduces the rotation speed to the maximum (with the next one of E12 the fan will not start up anymore).
DanFromMa
Postby DanFromMa » Fri Oct 26, 2018 8:26 pm
I am considering purchasing a 3D printer, has anyone any idea on how much PLA is needed to print the 5.2 universal case?
NegSol
Postby NegSol » Sat Oct 27, 2018 8:00 am
Using 20% infill and 3 Top/Bottom layers and 2 outer shells you will need around 103 grams or 35 meters of material. Of course this will vary slightly from printer to printer. 8)
DanFromMa
Postby DanFromMa » Sat Oct 27, 2018 9:32 am
NegSol wrote:Using 20% infill and 3 Top/Bottom layers and 2 outer shells you will need around 103 grams or 35 meters of material. Of course this will very slightly from printer to printer. 8)
Thanks, that really helps!
Sefirosu
Postby Sefirosu » Sat Oct 27, 2018 1:00 pm
That’s pretty much spot on, I took a look at my settings when I printed mine and I’m at 110 grams (PETG). But anyway, you can print many things with a 1kg spool.
Postby Newsdee » Sat Jan 05, 2019 2:03 am
Just wanted to report here that I printed the 5.2 and 2.0 tops with buttons successfully with a Monoprice Select Mini V2.
I used the "high tolerance" version of the 5.2 and the regular 2.0. For both, the buttons work great.
For materials I went with PLA and 22% infill, 0.175 mm layer thickess.
For the build to fit the printer, I had to disable all supports (default is Brim and it won't fit the 12x12x12cm build volume). Printed both cases with the top down with painter's tape for easy removal from the bed.
vanfanel
Postby vanfanel » Thu Feb 07, 2019 2:32 pm
Do you guys know if it's possible to order a 3D printed versoin of this case with better plastic? I orderem nime from Shapeways but it looks... weak, cartoon-like. I'd really like to get a harder version of the case.
bitfan2011
Postby bitfan2011 » Thu Feb 07, 2019 4:40 pm
vanfanel wrote:Do you guys know if it's possible to order a 3D printed versoin of this case with better plastic? I orderem nime from Shapeways but it looks... weak, cartoon-like. I'd really like to get a harder version of the case.
same question here, the prices get high quickly for better materials
NegSol
Postby NegSol » Thu Feb 07, 2019 7:41 pm
I have seen someone who printed in ABS. A bit tricky to print for such a big part imho - he used a really large brim - also maybe would require closed printing chamber. PETG is your best bet, should you need something tough from an ordinary 3d printer.
But honestly I am quite happy with my PLA version of the case. I am not planning on throwing it around or anything anytime soon. But of course use cases may vary :) :mrgreen: :mrgreen:
vanfanel
Postby vanfanel » Fri Feb 08, 2019 9:57 am
Hi, NegSol! Your case desing is fantastic. The desing is NOT the problem at all, it's just awesome and very good-looking! I deeply thank you for your work on this.
Problem is the material. I don't know about plastics, but I understand that what I have is a PLA version, the default version sent by shapeways. Am I right?
Then we have that "PETG", and ABS. But where could I find those versions?
Also, do you think putting some varnish on PLA would be a good idea or am I talking nonsense here?
NegSol
Postby NegSol » Fri Feb 08, 2019 5:19 pm
So let me explain:
With shapeways you got Versatile Plastic which is a durable nylon plastic. It is as good as you can get it when it comes to 3D printing plastics. It is stable to 160 degrees celsisus! Also tough stuff and laser sintered so you will not get any delamination issues or anything. For the looks you could go with some spray-painting but nylon is hard to paint.
Short excursion on printing plastics. PLA is the corn/milk bio degradable plastic that is easiest to print and smells like popcorn hour when printing. Not very durable at all and shares properties with wood. I like it for cases because everybody and his son can print it on a bare minimum setup. My cases are optimized for it (which means not much really). PLA is quite easy to spray-paint.
ABS is standard for most plastics we use everyday. Harder to print as it tends to warp when cooled to fast. So a heated room to print in and a heated print-plate is a must. Smells awful while printing. Also the print shrinks about 1-2 %. I guess tolerance of the case would allow for printing in ABS. Painting ABS will be difficult.
PETG is similar to the stuff plastic drinking bottles are made of. It is easy to print compared to ABS. Printing times are longer though. It is tough and hard to paint. I use it for hinges and brackets a lot as it is more flexible then ABS but equally strong. Imho PETG is overkill for the case. But I do not judge.
Nylon can be printed also, but only smal prints are usually made due to the high temps required will damage most home printers. Shapways uses laser sintering which is not affordable otherwise.
Hope this helps a bit. Some people like to sand and paint their PLA prints. For me a nice material colour suffices most of the time. Using different colours for the panels and shells will give you an individual look.
For PLA, ABS and PETG there are tons of different colours, translucencies, glitter, glow in the dark variants. All should work with the same stl files of the case :). :angel:
warham
Postby warham » Mon Feb 11, 2019 11:04 am
vanfanel wrote:Also, do you think putting some varnish on PLA would be a good idea or am I talking nonsense here?
You can stain and possibly varnish wood infused PLA.
vanfanel
Postby vanfanel » Mon Feb 11, 2019 3:25 pm
NegSol wrote:So let me explain:
Thanks for your detailed explanation, really! Never had seen these matters well explained in a place. Thanks!! :)
