Arcade cores
BitsNStuff
Re: Arcade cores
Postby BitsNStuff » Sun Sep 22, 2019 6:56 pm
Wonderful work, MrX8B.
Thank you so much for the work that you're doing. :)
djmartins
Re: Arcade cores
Postby djmartins » Sun Sep 22, 2019 9:07 pm
BlockABoots wrote:Trying to compile the RallyX core but seem to be getting loads of red text error messages in the dos window....
any ideas, what type of Mame romset is supposed to be used? (Merged, Non-Merged or Split)
Sure, look for the link to the archive.org romset posted here.
That is what I used and it worked fine.
djmartins
Re: Arcade cores
Postby djmartins » Tue Sep 24, 2019 12:56 am
Jin had a garbled screen on HDMI in vertical mode and in horizontal had glitches.
Just updated and it works fine in vertical mode!
BlockABoots
Re: Arcade cores
Postby BlockABoots » Sat Sep 28, 2019 11:33 am
What about River Patrol, as there required rom doesnt appear to be in the Archive.org list?
gaz68
Re: Arcade cores
Postby gaz68 » Sat Oct 05, 2019 12:35 pm
I just released a couple of new arcade cores - Super Cobra and Tazz-Mania. You can get them from here:
https://github.com/gaz68
If you find any issues then let me know on here.
Enjoy!
NML32
Re: Arcade cores
Postby NML32 » Sat Oct 05, 2019 1:15 pm
gaz68 wrote:I just released a couple of new arcade cores - Super Cobra and Tazz-Mania. You can get them from here:
Enjoy!
Thank you!!
hyperterminal
Re: Arcade cores
Postby hyperterminal » Sat Oct 05, 2019 2:07 pm
I want to report a bug in the Donkey Kong core.
The screenshot was edited by me to better illustrate the bug. On the top left corner you can see the life indicator. The first row of Marios is the one shown initially by the core. The colour of Marios feet is wrong. They are supposed to always be blue, the same colour as Mario's hair and Mario's shirt (compare the last row of Marios I copied over from Mame to show how Mario is supposed to look like).
When you move to the "How high can you get?" screen, Mario's feet change to another wrong colour, this time beige, the colour of Donkey Kong's skin (see the second row of Marios I copied over from another MiSTer screenshot).
My guess is that that the core has a problem with the colour palette initialisation. Mario's feet colour changes when a new screen is loaded. Each time one of the colours that is loaded for the screen is also taken for Mario's feet colour. In the first screen it is the colour of the ladders and in the next screen it is Donkey Kong's skin colour.
NML32
Re: Arcade cores
Postby NML32 » Sat Oct 05, 2019 4:01 pm
Enjoy!
Thank you for porting Super Cobra and Tazz-Mania to the MiSTer. :cheers:
I'm having an issue with Tazz-Mania and it may be the ROM I'm creating since it doesn't have the same MD5 value that is listed in the ini file.
Every ROM I've created so far has a MD5 value of 93599bbdb47df01c5a0c386e2077d740 and your build_rom.ini MD5 says it should be cb06e6325e7c707fb979fd1b9996338e
With the ROMs I've used the core starts up and everything looks good but when the game starts you instantly win each level. :shrug:
Could you give me any suggestions maybe the MAME version of the ROM?
gaz68
Re: Arcade cores
Postby gaz68 » Sat Oct 05, 2019 4:25 pm
hyperterminal wrote:I want to report a bug in the Donkey Kong core...
I came across this issue while working on my Donkey Kong Junior core (coming soon). The problem was much more evident in that core. I can provide a quick fix for this issue. Keep an eye on my GitHub repo. I'll try to get the fix added to the main repo too.
gaz68
Re: Arcade cores
Postby gaz68 » Sat Oct 05, 2019 5:23 pm
NML32 wrote:Thank you for porting Super Cobra and Tazz-Mania to the MiSTer. :cheers:
I'm having an issue with Tazz-Mania...
...Could you give me any suggestions maybe the MAME version of the ROM?
You're welcome. I believe the ROM I'm using is from MAME version 0.20. I've rechecked the MD5. Which version are you using?
NML32
Re: Arcade cores
Postby NML32 » Sat Oct 05, 2019 5:56 pm
I sent you a PM.
gaz68
Re: Arcade cores
Postby gaz68 » Sat Oct 05, 2019 6:25 pm
NML32 wrote:I sent you a PM.
Replied.
NML32
Re: Arcade cores
Postby NML32 » Sat Oct 05, 2019 6:48 pm
Replied.
Still not working. :(
Update: The keyboard controls seem to work but not the joystick except for the bonus rounds.
https://youtu.be/wNwZ5D6BNXg
NegSol
Re: Arcade cores
Postby NegSol » Sat Oct 05, 2019 8:12 pm
I have the same issue with Tazmania as NML32. Whenever I move the joystick in any direction the level is an instant win. Joystick buttons can be pressed and work without winning :)
Thanks for the great cores though! :mrgreen:
gaz68
Re: Arcade cores
Postby gaz68 » Sat Oct 05, 2019 8:55 pm
NegSol wrote:I have the same issue with Tazmania as NML32. Whenever I move the joystick in any direction the level is an instant win. Joystick buttons can be pressed and work without winning :)
Wow. Weird! I'll look into it.
I've fixed the MD5 values in the build script now. Thanks NML.
gaz68
Re: Arcade cores
Postby gaz68 » Sun Oct 06, 2019 12:53 pm
I found this in the MAME source code:
When "Cabinet" is set to "Upright", press any player 2 joystick direction to end current level
(code at 0x38dd). This trick does NOT work in bonus rooms though.
Joystick 1 and Joystick 2 were wired together, hence the problem. I've released a new binary. This now should be fixed. Only the player 1 joystick is now used in Cabinet mode.
NML32
Re: Arcade cores
Postby NML32 » Sun Oct 06, 2019 12:55 pm
gaz68 wrote:I found this in the MAME source code:
Confirmed working with Arcade-TazzMania_20191006.rbf :cheers:
Thank you.
Marauder66
Re: Arcade cores
Postby Marauder66 » Tue Oct 08, 2019 7:19 pm
Gaz68, what is the internal mister name of your arcade cores. I'm trying to edit mister.ini to change the vsync mode for my LCD TV as they have sync issues, and tried [Arcade-SuperCobra] and [SuperCobra] and it doesn't work. I changed the main vsync to 0 and they work fine, but not when 1 or 2.
brunosilva
Re: Arcade cores
Postby brunosilva » Tue Oct 08, 2019 9:03 pm
Marauder66
run core and press f12 to open osd
check the core name in the left (vertical text)
Marauder66
Re: Arcade cores
Postby Marauder66 » Wed Oct 09, 2019 8:18 am
Thanks, those 2 are working now.
Zeosstud
Re: Arcade cores
Postby Zeosstud » Thu Oct 10, 2019 6:40 pm
Can not wait to check out the DK Jr. Core, along with Tempest and Tron, for sure one of my favorites that have not made it into Mister just yet
SmokeMonster
Re: Arcade cores
Postby SmokeMonster » Fri Oct 11, 2019 3:52 am
Truly great work, everyone.
If anyone is looking for a fun project, Alan spent a lot of time porting a big chunk of Lisper's Food Fight arcade core. It just needs someone to swoop in and finish it up.
https://github.com/alanswx/arcade-foodfight
alanswx
Re: Arcade cores
Postby alanswx » Sat Oct 12, 2019 12:50 pm
SmokeMonster wrote:Truly great work, everyone.
I didn’t do too much other than fixing a bug in the joystick control.
Zeosstud
Core Specific Default Controller
Postby Zeosstud » Sat Oct 12, 2019 3:00 pm
I have searched until I can no longer keep things straight so I will just ask here..
The default button mappings for Joust are very different from most other cores,
a=left
s=right
f=flap
I have had zero luck mapping buttons for this game and having it remember anything, I assume I just do not get it, I am using an
IPAC2 for my controls and at this point only Joust is giving me an issue, I did find that if I change the mode to Joystick1 game plays like I would expect it to.
My question is - Is there a setting in the mister.ini I could use so that when I play Joust I do not have to hit scroll lock to cycle into Joystick mode
or
any other suggestion that might help this newbie out,
elvisa
Re: Arcade cores
Postby elvisa » Sun Oct 13, 2019 7:45 am
Hi all,
I've knocked together a DAT file that can help you use tools like ClrMAMEPro or RomVault to pre-audit and/or repair/rebuild your MAME ROM sets so that they can be used cleanly with either the build_rom .bat/.sh files included with the MiSTer arcade cores, or self_slaughter's build scripts.
https://github.com/danmons/datfiles
Requires knowing how DAT files and ROM managers work, however it might help some folks figure out why their MiSTer arcade ROM sets aren't building properly.
There's 4 ROM sets that result in incorrect builds, however the final checksums match those documented independently by Smokemonster.
I'll try to keep these up to date as new arcade cores appear.
Users browsing this forum: catenaccio, elvisa and 7 guests
