[SOLVED] What IPL is a TRAP exception?
GFA, ASM, STOS, ...
Postby mikro » Fri Sep 15, 2017 4:37 am
I feel rather dumb but can't help myself. I have a loop with calling Setexc(0x4ba, -1). For instance I want to wait four 200 Hz ticks. However sometimes (not always but definitely very often, like in 80% of cases) whole loop just locks down. So instead of having one quick call where I wait for one tick I get a zillion of trap calls until the tick counter moves to +1 (taking easily one minute!).
Since the code is trivial and debugged, the only explanation left is that traps actually enjoy higher priority than MFP interrupts (in this case Timer C) but it feels wrong -- MFP is IPL 6 (basically the same as 7, i.e. the highest possible IPL) so I find it hard to believe. But maybe I'm wrong? Timer C is rather low on MFP interrupt priority list but still, it is an IPL 6, right?
Re: What IPL is a TRAP exception?
Postby mikro » Fri Sep 15, 2017 5:00 am
Btw 'A Hitchhiker's guide to the BIOS' lists _hz_200 as $4bc. First I though "Heureka, this is it!" but obviously, it is not. It's really $4ba.
Re: [SOLVED] What IPL is a TRAP exception?
Postby mikro » Fri Sep 15, 2017 5:06 am
OK, I'm an idiot. $4ba = 1210. 1210 / 4 = 302.5, i.e. I can't use Setexc! In reality I'm reading content of 302*4 = $4b8, i.e. unused/undocumented variable.
I should have known better, right? Sigh.
Postby AtariZoll » Fri Sep 15, 2017 6:36 am
Nice monolog :mrgreen:
Postby shoggoth » Fri Sep 15, 2017 7:53 am
mikro wrote:OK, I'm an idiot. $4ba = 1210. 1210 / 4 = 302.5, i.e. I can't use Setexc! In reality I'm reading content of 302*4 = $4b8, i.e. unused/undocumented variable.
Brainfart. Ssystem() does the trick, but then again you're stuck in the FreeMiNT domain in such case.
ThorstenOtto
Postby ThorstenOtto » Fri Sep 15, 2017 3:00 pm
Note that if you don't want to use Super() or Supexec() for some reason, you can still use Setexc() to fetch the value: just call it twice, and shift the two halfwords together. Or, in this case might be even enough to call it once for the 2nd halfword, if you are only waiting for a change in it.
Postby mikro » Fri Sep 15, 2017 11:56 pm
Thorsten: I was pretty close to what you have described but then I realised how pointless it is and went with classic clock() instead (which internally uses get_sysvar(0x4ba) which in turn uses Super() or Ssytem(), depending on the OS).
(the original idea was to save as many trap calls as possible)
Return to “Coding”
