Programmers Palettes
paulwratt
Postby paulwratt » Thu Sep 14, 2017 11:47 am
preview: http://paulwratt.github.io/programmers-palettes/ (HW-MSX only atm)
palettes for programmers, developers, and designers.
https://github.com/paulwratt/programmer ... aster/docs
an extensive suppliment to gimp-palettes by @denilsonsa
https://github.com/denilsonsa/gimp-palettes
Is anyone interest in this sort of thing?
I thought it might be of interest, because after the shell scripts are developed (using HW-CGA), the next palette I was going to do is the DawnBringer16 mentioned here then the DawnBringer32
https://github.com/paulwratt/programmer ... master/bin
is there any other useful conversion outputs people might use, or palette files, or code output:
https://github.com/paulwratt/programmer ... FORMATS.md
I am planning on add palette files as I need them, but atm I am leaving (Atari) 256 color palettes till later (default.pal nvdi.pal common.pal), and I am not 100% sure what format one might use on 8bit hardware (or even if they can be used), except for MSX2+ VDP palettes
Paul
Re: Programmers Palettes
Postby shoggoth » Thu Sep 14, 2017 6:31 pm
Dawnbringer 16-color palette sorted to fit the standard NVDI/TOS4 palette layout would make sense.
mrbombermillzy
Postby mrbombermillzy » Thu Sep 14, 2017 8:08 pm
Im going to be looking into optimising 8-bit palettes for some Falcon/TT stuff at a later date so would be very interested in an Atari 256 colour version.
paulwratt
Postby paulwratt » Mon Sep 25, 2017 3:58 am
can someone remind me of the format of the (NVDI) .pal file, I know its binary, but what are the RGB orders, and there bit depth. I dont have anything to compare it to, so I cant tell atm.
you can reference the colors, but I cant remember the order, here:
http://afros-update.sourceforge.net/aes-skinning.html
BTW I just uploaded a tagged release 170925-HW-CGA, because I finished the html output utilities. So what used to take 3 days now takes 5 minutes, including upload of about 30 files per color set. I also added a Photoshop palette generator as well, which should be very similar to a Atari ST/Falcon/Aranym 256 color palette file.
unfortunately although I can generate and upload any 16 color palette, I wanted to track which color sets were available on what date, so I used the tags to do it, ie one tag per day, unless I modify the tag name convention.
if people are willing to supply either a GiMP palette file (.gpl) with names, or HTML colors (and color names), I would be willing to create a gamers-palettes that contains palettes used in games, from ANY platform.
Paul
paulwratt
Postby paulwratt » Tue Sep 26, 2017 12:58 am
re: .PAL I worked it out - 256 VDI colors: RGB, 0-1000 as 2 bytes per channel
I will probably have to create new sets, to re-order the color index of Dawnbringer16 palette inline with the Default/NVDI one, so they are visually compatible.
I may be able to produce a .PAL VDI palette file by the end of the day
I want to do a palette file that is hardware ordered 9bit, 12bit and 15bit "strobe" (2x12bit with "fixed" fine control values) for programmers, what format do people use these palettes at the file or include level?
paulwratt
Postby paulwratt » Tue Sep 26, 2017 2:57 am
the algorithm I worked up (integer based):
if DecNum=0 then VDIval=0
if DecNum>0 then VDIval=(DecNum*4)-(DecNum/12)
if VDIval>800 VDIval++
produces:
no# |    .gpl     |    algorithm   |     actual
  0 : 255 255 255 : 1000 1000 1000 : 1000 1000 1000
  1 :   0   0   0 :    0    0    0 :    0    0    0
  2 : 242   0   0 :  949    0    0 :  949    0    0
  3 :   0 230   0 :    0  902    0 :    0  902    0
  4 :   0   0 242 :    0    0  949 :    0    0  949
  5 :  26 203 187 :  102  796  733 :  102  796  733
  6 : 255 255   0 : 1000 1000    0 : 1000 1000    0
  7 : 230  51 153 :  902  200  600 :  902  200  600
  8 : 217 217 217 :  851  851  851 :  851  851  851
  9 : 128 128 128 :  502  502  502 :  502  502  502
 10 : 128   0   0 :  502    0    0 :  502    0    0
 11 :   0 128   0 :    0  502    0 :    0  502    0
 12 :   0   0 128 :    0    0  502 :    0    0  502
 13 :   0 128 128 :    0  502  502 :    0  502  502
 14 : 182 162  57 :  713  635  224 :  714  635  224
 15 : 128   0 128 :  502    0  502 :  502    0  502
Note the one flaw in color #14, 713=>714.
I will verify that 800 threshold when I first do a 256 color palette, the NVDI.PAL as I have a GiMP palette for it.
as far as 16 colors palette go, I think for the VDI palettes, I'll have two (2) downloads, with new re-mapped 1st 16 colors with A) darker default 240 maths generated colors appended, and B) the lighter common alternate (NVDI/Jinnee) 240 hand/eye picked color ranges appended.
if someone has a standard Atari ST 16 color palette save from a GEM desktop control panel, I can whip up those as well.
Paul
paulwratt
Postby paulwratt » Fri Sep 29, 2017 2:15 am
OK, for anyone interested ..
here is a modified version of a shell script (incl CygWin) that will output the Dawnbringer16 as VDI color palette. NOTE that it only generates the number of colors found in the GiMP palette file (.gpl), not the full 256, and it does not remap them to the AtariST color order either.
#!/bin/sh
BN=`pwd`
BN=`basename "$BN"`
if [ "$1" = "" -o "$1" = "--help" ]; then
  echo "palette-gpl2vdi.pal"
  echo "GiMP palette (.gpl) to Atari ST, Falcon, ARAnyM VDI color palette  (.pal)"
  echo "usage: palette-gpl2vdi.pal.sh [--help]|[palette.gpl]"
  echo "notes: the following will be over written."
  echo "       './$BN-dec-24-space.txt' "
  echo "       './$BN.vdi.colors.txt' "
  echo "       './$BN.vdi.hex.pal' "
  echo "       './$BN.vdi.color.pal' "
  echo "naming convention: "
  echo "       '\$BN uses the basename of the current directory'"
  exit 0
fi
if [ ! -f "./$1" ]; then
  echo "Error: not found: './$1'"
  exit 1
fi
if [ ! "`head -n 1 "$1"`" = "GIMP Palette" ]; then
  echo "Error: not a GiMP Palette: './$1'"
  exit 2
fi
grep -E "^[\ 0-9]" "$1" | cut --output-delimiter=, --characters=1-3,5-7,9-11 | tr -d \  | tr , \  > "${BN}-dec-24-space.txt"
RD=`dirname $0`
CN=`grep -c -E "^[0-9]" "./${BN}-dec-24-space.txt"`
printf "" > "./${BN}.vdi.${CN}colors.txt"
printf "" > "./${BN}.vdi.hex.${CN}colors.txt"
printf "" > "./${BN}.vdi.${CN}colors.pal"
printf '#!/bin/sh\nPF=`which printf`\n$PF "' > "./${BN}.vdi.printf.${CN}colors.sh"
for I in `seq 1 $CN`; do
  "$RD/as-channel-2-VDI.sh" `cat "./${BN}-dec-24-space.txt" | head -n $I | tail -n 1` >> "./${BN}.vdi.${CN}colors.txt"
  "$RD/as-VDI-dec-2-hex.sh" `cat "./${BN}.vdi.${CN}colors.txt" | head -n $I | tail -n 1` >> "./${BN}.vdi.hex.${CN}colors.txt"
  for J in `cat ./${BN}.vdi.hex.${CN}colors.txt | head -n $I | tail -n 1`; do
    M="\x`echo "$J" | cut -c 1-2`"
    N="\x`echo "$J" | cut -c 3-4`"
    printf "$M$N" >> "./${BN}.vdi.printf.${CN}colors.sh"
  done
done
printf "\" > \"./${BN}.vdi.${CN}colors.pal\"\n" >> "./${BN}.vdi.printf.${CN}colors.sh"
chmod 0777 "./${BN}.vdi.printf.${CN}colors.sh"
echo "$CN colors written to '${BN}.vdi.${CN}colors.pal'"
unset CN
unset RD
unset BN
exit 0
I did it this this way, because people might be interested in what the VDI values (0-1000 dec & hex) are, as well as the actual binary output. NOTE place 'palette-gpl2vdi.pal.sh' in the same directory as 'as-channel-2-VDI.sh' and 'as-VDI-dec-2-hex.sh' (from here) and make them executable (chmod a+x ...).
FYI: Using Grafx2
load the 'palette-common.gif' (reference on the page in the above post), then loading in the Dawnbringer16 JASC-PAL file from programmers-palettes, here is what you get:
Image Image
At least now Arne16v20 (AndroidArts.com) and Dawnbringer16 can be visually remapped to the alternate/common NVDI color palette, and a proper .PAL file produced
BTW: I added Arne16v20 (AndroidArts.com) to the programmers-palettes yesterday, using it to develop the VDI assist scripts, later today after I have created a remapped VDI color palette, and various palette-as-image, I will upload the Dawnbringer16 set.
Paul
paulwratt
Postby paulwratt » Fri Nov 17, 2017 4:41 am
I added the Dawnbringer16 palette no long after that post, but I ran across a (temporary) issue while constructing scripts to create a VDI palette file.
a) I dont have a default.vdi.pal to play with (I can construct one from the GPL I made years ago, but it wont be accurate VDI values, yet)
b) Arnie16v20 (and Dawnbringer16) have light and dark "sides", which when remapped may or may not be "palette-able to the eye"
if someone wants to check out the light Arnie16v20 remap, you can get it here.
https://paulwratt.github.io/programmers-palettes/x/AtariST/VDI-common/Arne16v20/Arne16v20.pal
I also added a section to the programmers-palettes for (mainly) retro computers, that contain platform specific palettes in various formats. The same above remapped palette is available (atm only) as a PI1, NEO and GIF
I still dont have a usable Atari setup atm, but I do have access to Grafx2, and I can patch it with palette loaders as well (if need be). I know a few of those reading this thread are Amiga users too, so if there is any format that Grafx2 can produce that Amiga users would find useful as a download (eg .IFF) please let me know so I can expand the retro "extras" section of programmers palettes. Same goes for MSX, Amdstrad, etc
I just updated the index redirect to cope with non-JS and low-CSS (retro) browsers. If it is useful I will add html (not CSS) color tables.
As far as I know GitHub does not support non-HTTPS urls (it redirects them), so if there is call, I will "patch" an HTTP server into the links. It entirely depends on demand and usefulness, so again, let me know.
Paul
joefish
Postby joefish » Fri Feb 16, 2018 12:18 pm
Ooh - always wondered how that palette came about, as it's a brilliant piece of work. But I wanted something smaller for bitplane playfields.
Then I just happened to come across this - a DawnBringer 8-colour palette!
http://lospec.com/palette-list/dawnbringers-8-color
http://pixeljoint.com/forum/forum_posts.asp?TID=26050
Actually, there's a whole load of palettes here, selectable by number of entries.
All the 4-colour ones seem to be tinted GameBoy palettes though. I'm sure more could be done there as well, although they'd be game-specific.
Return to “Discussion”
