Devpac from hard drive
YQN
Postby YQN » Wed Sep 13, 2017 7:21 am
I tried to run Perihelion's code for loading Degas pictures but I can't do it from the HD, Devpac looks for the file on A:. How do I set it up to look for the file on C:? I tried adding C: in the bottom two lines in the environment window (don't know what they're for), but it didn't change anything. Or is it best to keep everything on floppy disk?
Thanks for any help!
spiny
Disk Imager Supreme
Disk Imager Supreme
Re: Devpac from hard drive
Postby spiny » Wed Sep 13, 2017 7:31 am
it's the incbin staement at the bottom of the code, edit that to point to where the pic is on your C: drive
something like this:
picture incbin c:\code\tut07\font2.pi1
YQN
Postby YQN » Wed Sep 13, 2017 7:53 am
spiny wrote:it's the incbin staement at the bottom of the code, edit that to point to where the pic is on your C: drive
Feel stupid for not trying that :oops: Thanks!
spiny
Disk Imager Supreme
Disk Imager Supreme
Postby spiny » Wed Sep 13, 2017 8:03 am
don't worry, I'm still trying to get to grips with scrollers :)
YQN
Postby YQN » Wed Sep 13, 2017 9:56 am
Also, I'll post that if someone else searches the forum and gets to this post because that's where I should've actually searched: http://dev-docs.atariforge.org/
YQN
Postby YQN » Wed Sep 13, 2017 11:29 am
spiny wrote:don't worry, I'm still trying to get to grips with scrollers :)
That 7th tutorial is not the easiest! Did you try to run the first program, the one only getting the "C"? It gives me two bombs... :scratches head:
Sturm
Postby Sturm » Sun Oct 01, 2017 4:43 pm
Tried to install devpac 3.1 (found here : http://dhs.nu/files.php?t=single&ID=5) but it keeps asking for disk A. Any idea ?
FedePede04
Postby FedePede04 » Sun Oct 01, 2017 7:21 pm
try this one :)
devpac31.zip
FedePede04
Postby FedePede04 » Sun Oct 01, 2017 7:22 pm
just try and run the devpac.prg file i don't think you need to do anything else ...
FedePede04
Postby FedePede04 » Sun Oct 01, 2017 7:24 pm
hi up under files, there is on called "change directory" just use that and you don't need the path in the incbin.
YQN
Postby YQN » Sun Oct 01, 2017 9:24 pm
Sturm wrote:Tried to install devpac 3.1 (found here : http://dhs.nu/files.php?t=single&ID=5) but it keeps asking for disk A. Any idea ?
I had the same problem, you need to check the "Environment" options:
Then change the paths to where your files are. Looks like this on my system:
Return to “680x0”
