I/O Board
digitron
Re: I/O Board
Postby digitron » Tue May 07, 2019 4:38 pm
When will an IO rev 5.6 component list be updated on Github?
Re: I/O Board
Postby Sorgelig » Tue May 07, 2019 10:31 pm
As soon as someone will do it.
digitron
Re: I/O Board
Postby digitron » Wed May 08, 2019 1:34 am
Do I still need to remove pin 3 on P7 if there is a jumper for vga power on rev. 5.6?
digitron
Re: I/O Board
Postby digitron » Wed May 08, 2019 2:16 am
delete
digitron
Re: I/O Board
Postby digitron » Wed May 08, 2019 6:09 pm
Can a 20% tolerance cap be in used in place of this 10% cap? https://www.digikey.com/products/en?key ... -1058-1-ND
Re: I/O Board
Postby Sorgelig » Wed May 08, 2019 6:40 pm
digitron wrote:Can a 20% tolerance cap be in used in place of this 10% cap? https://www.digikey.com/products/en?key ... -1058-1-ND
can
damopinn
Re: I/O Board
Postby damopinn » Sat May 25, 2019 1:21 pm
I just want to share this fan I bought from aliexpress.
https://www.aliexpress.com/item/1000001291434.html
For me it runs silent on the 5v from the de10nano.
if you put your ear very close you can hear it.
and has the correct connector already.
Re: I/O Board
Postby Newsdee » Sat Jun 08, 2019 4:57 am
What would be the best way to wire a mini laptop speaker to the MiSTer without an I/O board? I have one that uses a 2 pin molex connector (so is mono sound only)
I could extract audio from HDMI for better quality but the box for that is rather bulky. This is to put inside a case with screen and speaker.
Re: I/O Board
Postby Sorgelig » Sat Jun 08, 2019 5:36 am
instead of hdmi audio extractor you ca use toslink to analog converter. they are small. You need only resistor and red LED to make a transmitter
sawf01
Re: I/O Board
Postby sawf01 » Wed Jun 19, 2019 6:52 am
Would it be ok to use a 4.7 kohms resistor at r4, 10 and 16 instead of a 4.3 kohms?
Re: I/O Board
Postby Sorgelig » Wed Jun 19, 2019 7:21 am
sawf01 wrote:Would it be ok to use a 4.7 kohms resistor at r4, 10 and 16 instead of a 4.3 kohms?
Hard to tell. You can try and then use some high color core (for example Menu core with vga_scaler=1) and check the color ramp screen to see a linearity.
sawf01
Re: I/O Board
Postby sawf01 » Wed Jun 19, 2019 11:08 am
Will do, thank you.
digitron
Re: I/O Board
Postby digitron » Mon Aug 05, 2019 10:03 pm
Catching up on all the good MiSTer updates, regarding the IO Board rev. 6, what specifically does the "R-2R DAC for VGA" provide?
eskwadrat
Re: I/O Board
Postby eskwadrat » Tue Sep 03, 2019 6:07 pm
Just plugged in the IO board and bit surprised about these:
* slowly rotating fan
* slow blinking RED and GREEN Leds
Is that normal, shouldn't fan spin full speed? Or is it PWM fan and will speed up when FPGA temp gets higher?
Also,
* what are those 3 buttons for?
* I read about SOG switch - "enable Sync-On-Green (or Sync-On-Y)" - what is that syncing for ?
Wiki say nothing about the above, have I missed the manual somewhere else? Thanks for the tips in advance.
____________
MISTer Patreon
Poobah
Re: I/O Board
Postby Poobah » Wed Sep 04, 2019 1:44 am
Hi eskwadrat,
Some IO board info-
Slow fan: Might be a new fan that needs to run a bit. Also some board builders (myself included) offer the option of a 12 volt fan, which will run slower on the IO board (should still be somewhat fast tho). Some V6 boards have a jumper for 3.3v or 5v fan power, make sure that is set appropriately (silk-screened on the back of the board). 12v fans will need the 5v position, 5v fans should work in either.
Slow blinking lights... the power led (closest to the sd card slot) should be solid red, the other two will blink slowly back and forth at the menu screen. The digital audio led (by audio jack) should appear solid 'on' to the naked eye.
SOG: exact switch function depends on your board version, but generally, it selects whether the board adds the video synchronization signals to the green video signal (hence 'sync on green'), this was a common method on older CRT monitors "back in the day"
zerohimself
Re: I/O Board
Postby zerohimself » Sat Sep 07, 2019 8:32 am
what package size are the resistor networks on the 6.0 boards?
Re: I/O Board
Postby Sorgelig » Sat Sep 07, 2019 8:55 am
zerohimself wrote:what package size are the resistor networks on the 6.0 boards?
1206
like this one:
https://www.mouser.tw/ProductDetail/652-CAT16-561J4LF
glaucon1984
Re: I/O Board
Postby glaucon1984 » Sat Sep 07, 2019 9:56 am
From the user's point of view, what's the difference between the v6.0 board and the 5.6 XL? Any new feature?
I had a visual inspection of the board and it seems to have the same ports, buttons, LEDs, etc. so just wondering if this new revision is something worth the upgrade or the changes only affect the manufacturing process.
Re: I/O Board
Postby Sorgelig » Sat Sep 07, 2019 10:56 am
glaucon1984 wrote:Hi,
it's not worth to upgrade from v5.6 to v6.0. It's mostly for easier assembling.
djsquare
Re: I/O Board
Postby djsquare » Sat Oct 05, 2019 11:55 pm
Anyone know how I could go about adding external LEDs/Buttons to the I/O board using the female white connectors near the corner? I don't really have a reason but it might be a neat little baby project
Re: I/O Board
Postby Sorgelig » Sun Oct 06, 2019 6:57 am
djsquare wrote:Anyone know how I could go about adding external LEDs/Buttons to the I/O board using the female white connectors near the corner? I don't really have a reason but it might be a neat little baby project
Schematics is available in PDF, so check it out.
gsargent70
Re: I/O Board
Postby gsargent70 » Wed Oct 09, 2019 1:23 am
Poobah wrote:Hi eskwadrat,
Some IO board info-
Poobah -
I just got done building my V6 board and on mine at the main menu the red and green leds strobe back and forth. Is this correct?
Also the digital audio led is not on. Does it only light when a digital audio source is plugged in to the jack?
Thanks - gsargent
sajattack
Re: I/O Board
Postby sajattack » Wed Oct 09, 2019 1:47 am
Do you have a full list of parts for v6.0 like v5.5 in the wiki? If not, what size are the 100uF caps?
sajattack
Re: I/O Board
Postby sajattack » Wed Oct 09, 2019 2:22 am
How high can the resistor network R/2R go? is 470/1k or 1k/2k acceptable?
Re: I/O Board
Postby Sorgelig » Wed Oct 09, 2019 2:22 pm
I've tried 240/475 and 300/604. The second pair gives darker video. First one is ideal from my point of view.
Users browsing this forum: seastalker and 7 guests
