MiSTer updates and changelog
alanswx
Re: MiSTer updates and changelog
Postby alanswx » Sun Aug 18, 2019 12:05 am
Uniwar S
Fixed sprite bug that Jesse found. I wasn't good enough to get to the third level. But with a lot of practice, I was able to reproduce and fix the bug.
Postby Sorgelig » Tue Aug 20, 2019 3:09 pm
Genesis:
- Update VDP to latest
- Option to increase sprites limit by iequalshane
- Adjust channel volumes to prevent clipping.
- Experimental option: direct video over HDMI.
SNES:
MiSTer:
Postby Sorgelig » Tue Aug 20, 2019 9:25 pm
Menu:
- Support for direct video over HDMI.
- Other minor fixes and updates.
Postby Sorgelig » Wed Aug 21, 2019 4:04 pm
Genesis:
- Fix HDMI timings broken in previous release.
alanswx
Postby alanswx » Fri Aug 23, 2019 1:46 am
Arcade Birdiy
Fixed the joystick - can start game now
Postby Sorgelig » Fri Aug 23, 2019 3:12 pm
Menu:
- Fix HDMI timings in some resolutions.
SNES:
- Fix interlace mode.
- Fixes in Direct Video.
Genesis:
- Fix floating bus and unused VDP bits reading.
Postby Sorgelig » Sat Aug 24, 2019 3:27 pm
SNES:
- Fixes and improvements in HDMI timings and Direct Video.
Genesis:
- Balance FM/PSG volumes
Menu:
alanswx
Postby alanswx » Mon Sep 02, 2019 3:32 am
River Patrol
Silver Land
new arcade cores - no schematics, so colors are patched and might not be right. Drop me a note if you find schematics for either.
Postby Sorgelig » Fri Sep 06, 2019 12:04 pm
Hardware:
- SDRAM XS v2.2 (for 32MB and 64MB)
- SDRAM XSD v2.4 (for 128MB)
New modules are backward compatible with old SDRAM.
Cores using SDRAM need to be updated to versions from mid-July or later in order to work with new modules!
Postby Sorgelig » Fri Sep 06, 2019 4:52 pm
MiSTer:
- accept hdmi_limited=2 (16-255) option in ini.
- MiSTer.ini: wildcard * for section name.
- Manage SDRAM size.
- minimig: adjust FastRAM size depending on detected SDRAM size.
Menu:
- Detect SDRAM module size.
- Update the framework.
Postby Sorgelig » Fri Sep 06, 2019 5:58 pm
Memtest:
- Support for 64MB and 128MB modules.
- Support for SDRAM v2.
- More traditional SDRAM controller for more adequate results.
Note: you need to update MiSTer binary and Menu core to latest!
Postby Sorgelig » Fri Sep 06, 2019 7:38 pm
NeoGeo:
First official release of long awaited furrtek's core!
Postby Sorgelig » Sat Sep 07, 2019 5:14 pm
Menu:
- Fix graphical glitches.
Postby Sorgelig » Sat Sep 07, 2019 5:43 pm
NeoGeo:
- Fix the graphical glitches
- Fix reboot problem
Postby Sorgelig » Sun Sep 08, 2019 12:43 am
MiSTer:
- NeoGeo: warn if not enough SDRAM memory for loaded ROM.
- NeoGeo: support for zipped ROMs.
Postby Sorgelig » Wed Sep 11, 2019 6:20 am
MSX:
- Port important changes from OCM v3.7.1 by MP2E.
- Clocks refactoring by MP2E.
- Update T80.
- Support for Direct Video.
Postby Sorgelig » Wed Sep 11, 2019 6:32 am
MiSTer:
- neogeo: load prom1.
- neogeo: support for .neo format (not for all games).
- neogeo: support per-folder romsets.xml for children subfolders.
- neogeo: xml: support for relative paths.
Postby Sorgelig » Wed Sep 11, 2019 8:48 am
SNES:
- Support original SNES controllers over USER I/O port by Kitrinx.
- Updates in Direct Video
Postby Sorgelig » Wed Sep 11, 2019 11:03 am
MiSTer: (hotfix)
- neogeo: correct the sfix length.
Postby Sorgelig » Wed Sep 11, 2019 12:16 pm
NeoGeo:
- Adjust vertical position on VGA and shadow bit by paulb-nl
Postby Sorgelig » Wed Sep 11, 2019 2:27 pm
ZX Spectrum:
- Update the Framework
Postby Sorgelig » Wed Sep 11, 2019 2:31 pm
Genesis:
- Update Direct Video
Postby Sorgelig » Thu Sep 12, 2019 1:22 pm
SNES:
- re-compile for better stability.
Postby Sorgelig » Thu Sep 12, 2019 2:18 pm
Minimig:
- Go back to original SDRAM clock as new controller is more stable.
- Tweaks for Direct Video.
Postby Sorgelig » Thu Sep 12, 2019 2:59 pm
Archie:
- 128Bit SDRAM access. Higher performance.
- Special tweak for 64MB and 128MB modules.
Users browsing this forum: LarsDragon, rezb1t and 9 guests
