kolla
Postby kolla » Mon Apr 16, 2018 8:21 pm
-- kolla
sonic74
Postby sonic74 » Thu Apr 19, 2018 1:23 am
Thanks for the link, but I already bought https://www.waveshare.com/product/modul ... h-case.htm
A bit bulky and lower resolution, but similar power consumption (3 W) and a headphone jack.
BlockABoots
Postby BlockABoots » Sat Nov 03, 2018 7:41 pm
toromand wrote:I just made a replacement top acrylic plate for my board with a holder for 12v 40mm fan.
How did you manage to get a 12v fan to work on this board?
witchmaster
Postby witchmaster » Sat Nov 03, 2018 8:10 pm
I also use a 12V fan from an old graphics accelerator with the MISTer, I have it running on 5V. Some 12V fans will work at 5V, they will spin slower and be quieter, but with a reduced airflow of course.
EDIT: The board has also got a 9V output (Arduino header).
BlockABoots
Postby BlockABoots » Sat Nov 03, 2018 8:15 pm
Hmm yeah the fan i have sort of jolts when i connect it up but doesn't spin :(
THaase
Postby THaase » Sun Nov 04, 2018 9:59 am
Not every 12V fan will spin up with 5V.
Try another one or go for a 5V fan.
Unrealcpu
Postby Unrealcpu » Sun Nov 04, 2018 4:53 pm
Can the Roland MT-32 work with the Mister FPGA? if so how do you get it to work and which IO board would i need ?
BBond007
Postby BBond007 » Sun Nov 04, 2018 11:25 pm
Unrealcpu wrote:Can the Roland MT-32 work with the Mister FPGA? if so how do you get it to work and which IO board would i need ?
You would need a MIDI adapter. MIDI for MiSTer is currently in development.
Information about the upcomming MIDI IO board --> viewtopic.php?f=117&t=34579
Information on using a USB MIDI adapter Amiga and ao486 cores (with MT-32) --> viewtopic.php?f=117&t=34599
huh123
Postby huh123 » Fri Nov 09, 2018 6:12 am
This is the only place I can think of to ask. So if I'm not getting a usb hub board, what is a good retail usb hub (micro or mini? Whatever is better) that can support more than 2-3 usb devices? Is this possible on this? Been googling for the answer, but I see a few things that lead to nothing. Is there a guide that shows compatibility of certain retail usb hubs for this?
hyperterminal
Postby hyperterminal » Fri Nov 09, 2018 9:37 am
huh123 wrote:This is the only place I can think of to ask. So if I'm not getting a usb hub board, what is a good retail usb hub (micro or mini? Whatever is better) that can support more than 2-3 usb devices? Is this possible on this? Been googling for the answer, but I see a few things that lead to nothing. Is there a guide that shows compatibility of certain retail usb hubs for this?
I bought this one: https://www.digikey.com/catalog/en/partgroup/2991/60736
huh123
Postby huh123 » Fri Nov 09, 2018 5:58 pm
Hey. Thanks for the recommendation. Saw this this morning but I ended up putting a purchase for this one before I saw this reply. Do you or anyone think this would work with a micro to usb adapter?
The hub:
https://www.amazon.com/gp/product/B0192LPK5M/
The adapter:
https://www.amazon.com/gp/product/B00BFYH11Q
Edit: Just wanted to confirm this works when looking for a hub and a dongle converter.
pedranic
Postby pedranic » Thu Jul 25, 2019 7:01 pm
I have just received the De10 and i am waiting for addons. I would like to know, what is the best material for attach the heatsink to the chip. I am looking at internet, and maybe the best option is the thermal adhesive (it is not thermal paste).
My addons is not the official one, so the only way to attach the fan to the heatsink is by screws directly to the fan.
Thanks for the help.
warham
Postby warham » Fri Jul 26, 2019 7:04 am
looks like there is a new similar spec board
http://mail.terasic.com.tw/epaper/2019/newsroom/tsom.html
Postby Sorgelig » Fri Jul 26, 2019 2:32 pm
warham wrote:looks like there is a new similar spec board
It has not enough GPIOs for SDRAM.
Although it has separate DDR3 chips for sole FPGA use. But i doubt it will be possible to use it anyway due to DDR3 latency. Well, it needs experiments to see if it's still possible to use for retro DRAM emulation and at which degree.
Btw, this SOM absolutely requires its dock board to be able to use for MiSTer. So, price is not attractive any more.
olsenn
Postby olsenn » Thu Nov 28, 2019 7:57 pm
Or this neat looking Cyclone 10 GX add-on module (220k LE's) and Single-Board Computer:
https://up-shop.org/up-ai-edge/231-up-core-plus.html
https://up-shop.org/up-ai-edge/232-up-a ... s-220_kles
For this price though perhaps it would be better going for the ugly but functional:
https://www.terasic.com.tw/cgi-bin/page ... 6&PartNo=1
Or the <$200 Future Avalanche board with Microsemi 300k LE FPGA:
https://www.microsemi.com/existing-parts/parts/139680
Postby Sorgelig » Sat Nov 30, 2019 6:43 am
olsenn wrote:Or this neat looking Cyclone 10 GX add-on module (220k LE's) and Single-Board Computer:
Expensive combo and no way to connect SDRAM, no other expansions are possible. FPGA has no video output. Very expensive.
olsenn wrote:For this price though perhaps it would be better going for the ugly but functional:
Ugly, bulky and too expensive.
olsenn wrote:Or the <$200 Future Avalanche board with Microsemi 300k LE FPGA:
Pretty much useless. No video output, not enough gpio for SDRAM connection.
There are many FPGA boards around. It doesn't mean all of them should be listed here. For MiSTer porting it must have some specific features.
At least MyIR Z7020 board is more suitable than any listed above.
http://www.myirtech.com/list.asp?id=502
Postby Newsdee » Sat Nov 30, 2019 11:08 am
Yikes, if anybody is willing to fork out $700 for a board, then they might as well design a custom pcb with a non-subsidized Cyclone V.
Frederir
Postby Frederir » Mon Dec 02, 2019 10:36 pm
There is also the Baidu board with ultrascale :
https://item.taobao.com/item.htm?spm=a2 ... t=9#detail
Users browsing this forum: dshadoff, pahnda and 7 guests
