Postby Sorgelig » Wed Oct 11, 2017 9:53 pm
If joystick is not defined for specific core, then definition from Menu core will be used.
TorsteinP
Postby TorsteinP » Sun Oct 15, 2017 8:54 am
My setup using Zero4U USB hub. Got PCB for I/O board 5.2. Just waiting for components from DigiKey. Also found a micro USB to mini USB cable adapter on eBay I'm waiting for.
jcw
Postby jcw » Mon Oct 16, 2017 8:23 pm
Even though the latency will be "bursty", I'd like to explore the DDR3 bridging to HPS. Is there an example of how this is done? I can see the signals in the "emu" verilog module, so all the good stuff seems to be in place already - but I haven't found examples of its use on GitHub. Does this map straight to all the HPS's 1 GB memory? Do I need to reserve a range on the Linux side to be allowed to use it on the FPGA side? Is it 64-bit wide, even though the DE10-NANO h/w has 32-bit wide memory?
I'm still reading up quite a bit on all this... (and with apologies if this is the wrong thread to post in)
Postby Sorgelig » Tue Oct 17, 2017 12:11 am
Check the FPGAGen core. It uses simple DDR3 access. More complex usage of DDR3 you can see in ao486 core.
DDR3 data is transferred on both edges of clock, so with 32bit bus it provides 64bit data on every clock cycle. Actually, bit-ness on MPFE bus has no relation to physical bit-ness of memory. Memory works on 800MHz while SDRAM bridge (MPFE) runs at around 100MHz, thus it may provide up to 256bit without slowing down the memory access.
jcw
Postby jcw » Tue Oct 17, 2017 1:34 am
jcw
Postby jcw » Fri Nov 10, 2017 12:02 pm
I've started collecting some info about MiSTer cores, for lack of an easy reference as to what resources each one needs:
See https://gist.github.com/jcw/e5f08c7f249689b30afc8fbf5220cb02 for the latest version of this table. If you post a comment with proper values for other entries, I'll add it in.
Postby Sorgelig » Fri Nov 10, 2017 12:23 pm
jcw wrote:I've started collecting some info about MiSTer cores, for lack of an easy reference as to what resources each one needs:
For end-user, the only important things are SDRAM and Secondary SD card requirements as it depends on extension boards they need - this information is available on Wiki.
How many on-board resources occupied by the core - it doesn't matter as long as it fits.
May be what FPGA resources occupied by non-ported core could be useful for plans on porting. Otherwise i don't see a reason of this table.
Slade
Postby Slade » Tue Nov 14, 2017 8:07 am
I didn't see the point of starting a new thread to see if this might be possible.
I was wondering, if there are other cores @sorgelig would be willing to port ? I realise some of these may not be possible, or interesting, but I thought if you don't ask, you may never know.
CoCo3 (or TRS-80 III) in VHDL. Who doesn't want to see the trash80 available ?!: https://github.com/richard42/CoCo3FPGA
Gameboy. Seems to be a combination of C++ and VHDL: https://code.google.com/archive/p/gbfpg ... ult/source
Temlib. Which allows simulation of a Sun Sparc Workstation, amongst other things: http://temlib.org/site/
Vic20. Hey, we have other Commodore cores, why not the Vic 20 as well ?
http://svn.fpgaarcade.com/viewvc/Replay ... 20/source/
User: SVNguest
Pass: s1fUXdnc3a
I'm not expecting anything, just hoping if source is available that porting may well be possible. Thanks for reading.
Postby Sorgelig » Tue Nov 14, 2017 9:57 am
Slade wrote:I didn't see the point of starting a new thread to see if this might be possible.
User: SVNguest
Pass: s1fUXdnc3a
I've saw all these cores.
I don't remember why i didn't port VIC20. Actually it's not so attractive to me comparing to C64 which is actually covers all VIC20 features. I don't know any VIC20 specific game which will force me to port the VIC20.
But in general, i agree, it's better to port it. May be later.
CoCo3 core is hypertrophic fantasy computer. It's no more CoCo3. It runs on very high speed and requires a lot of high-speed memory (SSRAM - used on high-end Stratix boards if i remember correct). I'm VERY VERY against any fantasy computers as they bring no any meaning in present days. While running on 25MHz is looks pretty fast CoCo3, it's nothing comparing to Intel Core i9. So there is no reason to make such strange cores.
Give me the source of core implementing CoCo3 with its real specifications - and i promise to port it.
Of course it's only my opinion. Anyone else can try to port any fantasy computer to MiSTer. More cores - is better.
Gameboy sources i've saw claimed to be a very early prototype which almost doesn't work. May be readme is old..
Temlib - if i remember right, it's very limited and close to proof-of-concept than something really useful. They didn't implement graphics accelerator and other HW which is crucial for normal work. Core is pretty large, and i don't want to spend a lot of time for something which is close to POC. But again, anyone else is welcome to port it.
Gehstock
Postby Gehstock » Tue Nov 14, 2017 11:22 am
We have a Gameboy on Mist https://github.com/mist-devel/mist-boar ... es/gameboy and i send you the Sources for Gameboy Color
Postby Sorgelig » Tue Nov 14, 2017 12:51 pm
Gehstock wrote:We have a Gameboy on Mist https://github.com/mist-devel/mist-boar ... es/gameboy and i send you the Sources for Gameboy Color
That's good!
I will port it then.
Slade
Postby Slade » Wed Nov 15, 2017 8:23 am
I "found" the source for the Acorn Atom on the zxuno forum. Code on Github: https://github.com/hoglet67/AtomFpga
Original thread: http://www.zxuno.com/forum/viewtopic.php?f=16&t=1238
alfishe
Postby alfishe » Sun Nov 19, 2017 2:39 am
Woo hoo - an article about MiSTer on Hackaday =) https://hackaday.com/2017/11/18/mister- ... creations/
Postby Sorgelig » Sun Nov 19, 2017 4:42 pm
and about 5K bits of block RAM
lol.. should be 5.5Mbits of block RAM.
Postby Newsdee » Mon Nov 20, 2017 11:48 pm
Not worth a new thread, but I find that the ability to use subfolders for core selection is really nice! Great addition, Sorgelig!
JimDrew
Postby JimDrew » Sat Nov 25, 2017 3:39 pm
Is it possible to have a way to disable the frame buffer that rotates the display 90 degrees so we can have a full height display? There are a lot of people with swivel monitors (monitors that will rotate 90 degrees). The FPGA Arcade Replay (which is where Pacman and other MiST cores came from) gives you the narrow/tall display if you rotate the monitor. It would be nice to have a function key option that would enable/disable the rotation.
I am the flux ninja
Postby Newsdee » Sat Nov 25, 2017 4:03 pm
JimDrew wrote:Is it possible to have a way to disable the frame buffer that rotates the display 90 degrees so we can have a full height display? There are a lot of people with swivel monitors (monitors that will rotate 90 degrees). The FPGA Arcade Replay (which is where Pacman and other MiST cores came from) gives you the narrow/tall display if you rotate the monitor. It would be nice to have a function key option that would enable/disable the rotation.
Isn't that an option on the OSD menu of the arcade cores?
JimDrew
Postby JimDrew » Sat Nov 25, 2017 6:02 pm
Maybe? If so, it's not something I have seen on the screen or noted in the docs or wiki.
I am the flux ninja
NML32
Postby NML32 » Sat Nov 25, 2017 6:16 pm
JimDrew wrote:Maybe? If so, it's not something I have seen on the screen or noted in the docs or wiki.
It's in the Github readme for each arcade core.
https://github.com/MiSTer-devel/Arcade-Xevious_MiSTer
-- Support screen and controls rotation on HDMI output.
-- Only controls are rotated on VGA output.
https://www.youtube.com/watch?v=WEu_uVG ... nnel=NML32
JimDrew
Postby JimDrew » Sat Nov 25, 2017 7:33 pm
Thanks, I was looking at Pacman in particular. I see that several of the games have the ability to change the resolution/orientation in the OSD. Nice!
I am the flux ninja
capnbleigh
Postby capnbleigh » Sat Nov 25, 2017 9:01 pm
I got the sdram daughterboard soldered up this week, and it worked! I fired up NES and notice some weird sound artifacts in Megaman2 but a lot of things run well, I'm currently debugging the audio issue but this is my first rodeo with FPGA so no promises.
Some other items I'm looking into and hoping are low hanging fruit:
-Adding SD support to the Atari800/5200 emulator so it doesn't require the additional card.
-SRAM save support in cores where it makes sense.
If there's any other low hanging fruit please let me know because I'd love to contribute and learn more about FPGA. I definitely have more of a software background but hardware design has always interested me.
Postby Sorgelig » Sat Nov 25, 2017 9:14 pm
JimDrew wrote:Thanks, I was looking at Pacman in particular. I see that several of the games have the ability to change the resolution/orientation in the OSD. Nice!
All arcades ported by me have rotation option (if original arcade uses vertical layout).
Questions about arcades ported by someone else should be addressed to their respective developer.
NML32
Postby NML32 » Sat Nov 25, 2017 9:27 pm
capnbleigh wrote:I got the sdram daughterboard soldered up this week, and it worked! I fired up NES and notice some weird sound artifacts in Megaman2 but a lot of things run well, I'm currently debugging the audio issue but this is my first rodeo with FPGA so no promises.
Sounds good :cheers:
One thing I'd love to see is High Score tables saved for the arcade cores. I'm not sure how difficult that would be or if it's even possible.
Postby Sorgelig » Sat Nov 25, 2017 9:32 pm
that should be already very much for start :) When you will finish it, you will see another target.
capnbleigh
Postby capnbleigh » Sat Nov 25, 2017 9:37 pm
the amount you've gotten ported over is crazy! well done! i love tinkering with this board, watching old amiga demos thru hdmi is incredible.
