What is this graphics card?
Kroll
Postby Kroll » Thu May 25, 2017 9:33 pm
please find a photos of graphics card on VME bus. My friend will be try to repair this card, but I dont know what is this card, and I am looking for a driver for this card on Atari TT
Thank you in advance for any help
Regards
Kroll
rian_ata
Re: What is this graphics card?
Postby rian_ata » Thu May 25, 2017 9:40 pm
http://wiki.newtosworld.de/index.php?title=Nova_(VME)
It is a Tseng Labs ET4000 version, can't see what specific version, but as a driver I would try MVDI v5 first and select ET4000 as graphics adapter during installation.
Postby wongck » Thu May 25, 2017 11:17 pm
Nice find.
emcclariion
Postby emcclariion » Fri May 26, 2017 7:37 am
Great Card
Atari TT Nova card Mach64, Lightning VME, 64MB of RAM, Mega STE 4MB, Nova mach 32 and Atari STE 4MB TOS 2.06 Netusb Ultrasatan 2, Atari Falcon CT60 512MB Netusb
mfro
Postby mfro » Fri May 26, 2017 8:01 am
nice find. What makes you think it needs repair?
Kroll
Postby Kroll » Fri May 26, 2017 8:32 am
Yes, because my friend find this card a few years ago test with NVDI drivers and he is sure this card does not work :( and send it to our friend, who is a good electronic man, He will be test on TT but we need drivers. On the beginning he will be try using NVDI drivers.
lp
Postby lp » Fri May 26, 2017 12:24 pm
Someone keen with chips should be able to determine how much ram is on the board by the chip numbers. As its not densely populated I'd guess it might be monochrome or 16 color card. There is some writing on the back as well but the image resolution is to low to read it. Readers here might have trouble helping due to image quality.
Gaiyan
Postby Gaiyan » Fri May 26, 2017 12:28 pm
lp wrote:Someone keen with chips should be able to determine how much ram is on the board by the chip numbers. As its not densely populated I'd guess it might be monochrome or 16 color card. There is some writing on the back as well but the image resolution is to low to read it. Readers here might have trouble helping due to image quality.
I think it says "TT-SVGA Main Electronics" on the bottom.
Postby joska » Fri May 26, 2017 1:37 pm
There are eight RAM-chips, V53C104AP70. So this is a 1Mb card. That means 1024x768 in 256 colours or 800x600 in 16 bit.
frank.lukas
Postby frank.lukas » Fri May 26, 2017 3:06 pm
To use NVDI ET4000 or NVDI5 with this card to find the right memory Address space and the I/O Address is the Ticky bit ...
Is there a Adressdecoder GAL/PAL on the Card ?
Kroll
Postby Kroll » Fri May 26, 2017 6:24 pm
Frank: Additional better photo, Is that what you asked?
Ektus
Postby Ektus » Fri May 26, 2017 7:33 pm
To view the first image in full size: download/file.php?id=31895&mode=view
There's a GAL 20V8 in the middle and a PAL 16V8 to the right of the GAL.
Kroll
Postby Kroll » Thu Sep 07, 2017 12:26 pm
frank.lukas wrote:To use NVDI ET4000 or NVDI5 with this card to find the right memory Address space and the I/O Address is the Ticky bit ...
I have just test it this card on my TT, I tried with all dirvers (T0 and etc) from Idek web site, but not working, The last thing maybe NVDI ET4000 will be help. Can you send me this version of NVDI
frank.lukas
Postby frank.lukas » Thu Sep 07, 2017 1:04 pm
There is NVDI 5 -> http://www.s212939144.websitehome.co.uk/awarez/
In the VMG Program you must set the right address ...
Kroll
Postby Kroll » Thu Sep 07, 2017 1:36 pm
Thanks, I run VMG-4000 and I found:
Screenbaseaddress : $ FEC00000
Registerbaseaddress: $ FED003B0
I do not know what to type:
frank.lukas
Postby frank.lukas » Thu Sep 07, 2017 2:27 pm
Set for example a CrazyDots or a Mega4000 Graphic Adapter and play with the different address areas ...
artik-wroc
Postby artik-wroc » Sat Sep 09, 2017 6:30 am
frank.lukas
Postby frank.lukas » Sat Sep 09, 2017 10:16 am
Hello artik-wroc, can you ask for Driver Software or Details with NVDI in the Poland Forum ?
artik-wroc
Postby artik-wroc » Sat Sep 09, 2017 10:49 am
Hello Frank
Imagine/NOVA driver for ET4000
http://www.atari.org.pl/forum/viewtopic.php?id=13692
frank.lukas
Postby frank.lukas » Sat Sep 09, 2017 10:59 am
Thanks ...
Who was the Maker? And it is possible to have the Gerber/PCB Layout and the JED Files from the two GALs?
Hello Kroll, try the Nova Driver from T0 until T8 and find the right one. I think a T8 is fine -> https://silicon-heaven.org/atari/nova/
Kroll
Postby Kroll » Sun Sep 10, 2017 11:01 am
Yes I tried with all drivers from this website additionally VMG-4000 from NVDI.
For drivers for Atari TT from T0 until T8 give some effects. If you run emulator.prg or vmg.prg from these archive, the monitor connected to this card gets some signal (can sync) on the screen in each case gets the so-called "color snow" and that's all.
What do you think, but I'm afraid that the card is damaged?
frank.lukas
Postby frank.lukas » Sun Sep 10, 2017 11:40 am
Maybe you need the Atari TT Nova T6 ET4000 Driver ?
I upload it when I back home ...
lp
Postby lp » Sun Sep 10, 2017 11:58 am
Only thing I can find with google: is http://atariki.krap.pl/index.php/Magic_Screen
Hints at 2 versions of the card and uses the Imagine driver. Where to find this driver I have no clue.
Postby czietz » Sun Sep 10, 2017 1:09 pm
Imagine is just an older name for the Nova graphic cards.
lp
Postby lp » Sun Sep 10, 2017 1:20 pm
Ah, learn something new everyday. Cheers.
