Questions about trackers
Sturm
Postby Sturm » Fri May 12, 2017 10:49 pm
Hi all,
i'd really like to learn how to use trackers, I use Cubase PC quite often, but would like to get that "old school" feeling with a tracker on my Falcon.
I tried Maxymiser, and Ace 2.
Both seem interesting, but Maxymiser looks less attractive, especially the UI.
I like Ace 2 so far, but I tried to use my midi keyboard (Arturia Keystep) with it with no success (i prefer using a real keyboard). I then downloaded Ace midi demo, and my keyboard works, but it's not a tracker, rather a synth vst (a good one it seems).
Am I doing something wrong ? Does the registered version of Ace Midi has patterns? Or can you just generate and save sounds with it ?
Is Ace 2 supposed to work with midi keyboards ?
Thank you
Atari74user
Re: Questions about trackers
Postby Atari74user » Sat May 13, 2017 10:52 am
Well you are correct, as you allude Ace Tracker and Ace MIDI do exactly as they say, it is Ace MIDI that has the MIDI capabilities only as I imagine you know spec'd here:
http://newbeat.atari.org/main.php?page=ace_specifications
So as you say, Ace Tracker is the Tracker, and Ace MIDI is the soft synth, turning your Falcon into a synthesiser to be controlled over MIDI.
Sturm
Postby Sturm » Sat May 13, 2017 11:21 am
but the description misled me :
Tracker version
256 positions and 256 patterns.
Dynamic pattern size, from 1 track with 1 line to 16 tracks with 64 lines.
MIDI input.
4 pattern columns: note, sound, effect, and volume or filter.
Midi input ? how to activate it ?
Atari74user
Postby Atari74user » Sun May 14, 2017 9:04 am
I do see your point, and I can't say I have tried, and cannot at the moment as I have just moved house.
It doesn't say anything specific in the manual, but I have always been under the impression that there were no MIDI capabilities within Ace Tracker, but neglected to see what you have noted in the spec's.
As I cannot check, forum member Dhedberg may be able to help, he is Daniel Hedberg from New Beat.
Sturm
Postby Sturm » Sun May 14, 2017 10:06 am
Yup i checked the manual too, and nothing about midi. This would be a really cool feature to add, even for a small fee.
