Get images from pc to DEGAS+?
Postby 607 » Tue May 09, 2017 8:12 am
Hello!
On my Atari ST, I use DEGAS Elite to create graphics. Now, I was wondering if it'd be possible to 'insert' a picture from elsewhere, there.
Like how when working in Paint.NET, I might want to copy and paste an image from the internet... that isn't possible on Atari ST, however.
But can I somehow make an image that I can open in DEGAS Elite from my pc?
I've got diskettes, a Windows 10 pc, and an Atari STE. If you've got any clue, please share! I'd love to be able to insert some graphics from elsewhere, as replicating them pixel by pixel would be a huge undertaking.
I get that I'll also have to stay to a specific colour palette, but that's fine, as long as I can get it to work. :)
Re: Get images from pc to DEGAS+?
Postby troed » Tue May 09, 2017 2:08 pm
https://github.com/troed/PNGconv
java -jar PNGconv.jar input.png output.pi1 low
(Writing from memory - plz check against readme)
/Troed
Orion_
Postby Orion_ » Tue May 09, 2017 2:28 pm
In the "tools" section of my Atari page (bottom of the page) http://onorisoft.free.fr/atari/atari.htm
you can find a set of plugin for Photoshop (or compatible, like XNview, paint shop pro) that can export to different Atari image format (PI1, PC1, PI9, NEO)
607
Postby 607 » Tue May 09, 2017 4:09 pm
troed wrote:https://github.com/troed/PNGconv
/Troed
I'll try that, although I haven't got too much experience with running stuff like that, but it should be fairly straight-forward.
Orion_ wrote:In the "tools" section of my Atari page (bottom of the page) http://onorisoft.free.fr/atari/atari.htm
I thought I could write that off right away, as I haven't got Photoshop, but by Googling it seems like it is possible to use some Photoshop plugins in GIMP, through another plugin. I might try that as well. :)
607
Postby 607 » Sun May 21, 2017 3:44 pm
/Troed
What you say is what the readme says, however, I can't find 'PNGconv.jar' in the downloaded folder. Would you know what I should do?
dma
Postby dma » Sun May 21, 2017 4:10 pm
You can get the .jar from the releases page: https://github.com/troed/PNGconv/releases
607
Postby 607 » Sun May 21, 2017 4:12 pm
dma wrote:You can get the .jar from the releases page: https://github.com/troed/PNGconv/releases
Ah, thanks. I'm not very familiar with GitHub.
607
Postby 607 » Sun May 21, 2017 4:18 pm
I can't download it, Windows Defender blocks it. :/ I've looked online, and there seems to be an option to make an exception for files, but then you need to select a file, but I can't select it as I haven't downloaded it yet.
Postby troed » Sun May 21, 2017 5:04 pm
Also I was wrong, you need the add "-header" (without quotation marks) at the end of the command line as well for it to be Degas compatible.
Regarding Windows Defender, sorry I can't help. Currently on a road trip, otherwise I would've zipped a copy for you.
/Troed
MM41
Postby MM41 » Sun May 21, 2017 5:23 pm
Try Degas Elite XL http://www.ataritools.fr.gd/
Postby troed » Mon May 22, 2017 6:14 am
Here's a link to a zipped copy of the jar, if that helps with Windows Defender: https://troed.ddns.net/f/680d587c83/?dl=1
/Troed
607
Postby 607 » Fri May 26, 2017 5:16 pm
It worked!
Thanks, guys!
As I had expected, I was having some problems at first, but my troubleshooting went flawlessly! How delightful! :D
Postby simonsunnyboy » Sat May 27, 2017 9:34 am
Grafx2 can import and export most basic ST file formats such as PI1, PC1 and NEO.
spiny
Disk Imager Supreme
Disk Imager Supreme
Postby spiny » Sat May 27, 2017 10:16 am
xnview can save in Degas PI1 format
1: create a pic in your preferred art package on PC
2: save as GIF, 16 colours, 320x200
3: open in xnview, 'save as' PI1
4: copy to ST using floppy, PARCP, network, etc
5: open in Degas, or Neochrome :)
607
Postby 607 » Sat Oct 13, 2018 11:58 am
spiny wrote:3: open in xnview, 'save as' PI1
I can't find PI1. :( It goes from PGF to PIC.
xc8
Postby xc8 » Sat Oct 13, 2018 2:49 pm
This will solve it:
Options-> General -> Display All Image Filetypes
607
Postby 607 » Sat Oct 13, 2018 3:20 pm
xc8 wrote:This will solve it:
This isn't an option for me. I only see a list of filetypes to save as, and all are selected. I've got XNViewMP, is that the right program?
Otherwise I'll simply try to use the commandline program again, as that worked out last time. :)
BoNuS
Postby BoNuS » Sat Oct 13, 2018 4:56 pm
Take a look at
https://en.wikipedia.org/wiki/GrafX2
http://grafx2.chez.com/index.php?static3/downloads
(choose windows stable version)
I use it as an interface between my ST and PC. Also works great if you are used to the old skool drawing programs...
http://bonus.home.xs4all.nl/
xc8
Postby xc8 » Sat Oct 13, 2018 5:03 pm
Well that was the option of Xnview / windoze version (tested under WINE).
On my XnViewMP (linux) the option is :
Settings >> General >> Show All Graphic formats
Then you can open PC*/PI* and Save as PI1 too..
607
Postby 607 » Sun Oct 14, 2018 8:58 am
607 wrote:This isn't an option for me. I only see a list of filetypes to save as, and all are selected. I've got XNViewMP, is that the right program?
Huh, I found it now. It wasn't there when I checked on my laptop... maybe because my laptop's system language is set to Dutch? :confused: Anyway, the option's there now. :P
Return to “Discussion”
