[A]tari [G]ame [T]ools - 2D prototyping engine for STE
GFA, ASM, STOS, ...
dml
Postby dml » Tue Apr 25, 2017 9:45 am
I haven't posted for a while but between persistent bursts of real-life have been quietly preparing usable release of this project -
AGT game prototyping engine for STE
If you're someone with a bit of programming experience, interested in designing games, wanted to make something for the Atari STE, were disappointed with the limits of STOS for making games and just don't have the time to code everything up from scratch just to get something worthwhile off the ground, this *may* be for you...
Note: This continues work which began in an earlier thread, here: viewtopic.php?f=16&t=29615
Here's an outline of what you can expect from AGT, straight away:
- Produce and test 2D game ideas in minimum time
- Develop in C or a mixture of C and 68k (or can use 68k for everything except the entrypoint/mainloop, if preferred)
- High performance - can match or exceed almost any commercial game, even if using only C. All examples are 50hz.
- Any type of scrolling - vertical, horizontal, 4- or 8-way, fixedpoint vector, direction & speed changes.
- Work with 16x16 or 8x8 tilemaps, of any size
- Single or dual-layer tilemaps (both layers editiable in TILED, with second, transparent layer masked on top of first)
- Live-editable map layers ('mapmod' function) with optimised refresh of edited tiles for animation, doors or limited parallax
- 4 different sprite formats optimised for different scenarios (drawing speed vs. size vs. memory overhead vs. extraction time)
- All sprite methods provide clipping & automatic background clearing/restore
- Flexible entity/AI system supports:
-- spawn chaining (entities can spawn or kill entities)
-- vistrigger mode (spawned into map at level load, dormant/no-overhead until entering viewport)
-- plenty of example code for different kinds of behaviour
-- object parent linkage & tracking
- Object Interaction system provides mechanism for collisions, triggers
- Input layer provides direct and debounced key & joystick state.
- Comprehensive tools for converting, extracting assets including maps, tiles, sprites (& related), palettes
- Edit maps in TILED editor and export to AGT in seconds
- Collision tilemaps can be created and imported separately from the main visual tilemaps
- Edit object/entity placements in TILED and export with map for direct parsing by game
- Built-in debugging features including:
-- message console for errors, warnings & user info
-- asserts to catch unexpected values etc.
-- game object safety checks & diagnostics (bad animation frames etc.)
-- debugdraw object rectangles
-- memory tracing
-- Hatari and STEEM message logging
- Top/bottom overscan & optional colour boosting via interlaced playfields
- Lots of demos and examples including playable game levels - all with source code
- Wiki tutorials cover the fundamentals with more obscure features illustrated via samples
This is a shortlist of features *currently* supported. None of it is 100% complete but all items listed are now fully usable. Some other features are still WIP. If the system gains use, more features are planned. I may return to maintain this post as things change.
The system is primarily based around Cygwin & m68k GCC toolchain (either BrownELF GCC 6.2 or Vincent's MiNT GCC 4.6 compiler) with a choice of either RMAC or VASM assembler. All tools (except the compiler) are delivered in the bin/ directory as Windows executables. However the system has been successfully used on Linux and OSX either by compiling the tools for those systems or by wrapping the Windows bin/ tools with the WINE emulator (probably the least hassle if you just want to get moving - especially since I have little time to maintain multiple ports/builds of the tools).
While the upper layers (mainloop etc.) are defined in C, the game content can be written in C, C++ or 68k as required. However all of the examples were coded in C to demonstrate whats possible without having to use assembly. They are all 50hz and have plenty going on. There is no baked/prepared data being used - all AI is 'thinking' realtime for every object to provide meaningful examples (it is assumed that you can bake whatever data you like, but it doesn't provide good learning material so I don't use it).
While the demos are aimed at 50hz, the engine will support lower framerates for games which require it.
If you're interested in finding out more or giving it a try, you can find the project, Wiki docs and tutorials here:
https://bitbucket.org/d_m_l/agtools
The Wiki & tutorials are WIP and still growing. If there is interest, I'll keep adding to both the engine and the tutorials/examples.
That's all for now. Updates and news on AGT will be posted here from now on - the older thread will be left as it is.
Re: [A]tari [G]ame [T]ools - 2D prototyping engine for STE
Postby troed » Tue Apr 25, 2017 10:21 am
Big shoutout. Incredible effort you've put into this.
dml
Postby dml » Tue Apr 25, 2017 10:38 am
Thanks Troed :)
It's been fun working on it. Hopefully others can have fun building stuff with it - or at least learn something useful from it.
AtariCrypt
Postby AtariCrypt » Tue Apr 25, 2017 10:55 am
This is one of the most amazing projects I've ever seen. A huge thank you from me also, amazing work. I hope many find a use for this.
AdamK
Postby AdamK » Tue Apr 25, 2017 10:58 am
dml, this is fantastic :D
dml
Postby dml » Tue Apr 25, 2017 12:15 pm
For those of you who followed the older thread you've probably seen the Gradius, BossCore & Alien Breed coding examples as screenshots or YT links... (e.g. https://www.youtube.com/watch?v=Ul_9PRt9cpo) I will be posting a *new* example soon which will be even more familiar and uses more features, including the import of maps, collision contours and game object instances from a PC based editor (Tiled: http://www.mapeditor.org).
The new example is only about half-way done (and my time is split between engine, examples and wiki docs!) but I'll drop a preview soon. It's probably the best indicator of what sort of stuff you can now do with AGT.
Postby Anima » Tue Apr 25, 2017 12:53 pm
Welcome back Doug. Looking forward to the new example.
dml
Postby dml » Tue Apr 25, 2017 1:56 pm
Anima wrote::cheers:
Thanks Sascha, good to see you've also been busy with new secret projects. ;)
spiny
Disk Imager Supreme
Disk Imager Supreme
Postby spiny » Tue Apr 25, 2017 3:50 pm
brilliant stuff :)
Postby simonsunnyboy » Tue Apr 25, 2017 4:16 pm
This is a great effort. If it brings more games to the ST, it is more than welcome.
Sometimes, as a coder, the fun is still in reinventing the techniques ;)
TheNameOfTheGame
Postby TheNameOfTheGame » Tue Apr 25, 2017 4:23 pm
Wonderful news! Was wondering if this was still alive!
Maybe we can have a yearly AGT coding competition.
dml
Postby dml » Tue Apr 25, 2017 5:43 pm
Here's a preview of a future tutorial - yet to be broken down into steps.
https://www.dropbox.com/s/26mqinbi51qlm ... o.zip?dl=0
keys: WSAD, SHIFT, SPACE
It's still rough around the edges but getting fairly close. There is framedrop in places - this has more to do with scheduling object updates than the number of objects involved so it should improve when I get time to sort that out.
This sample uses collision maps (affecting player + entities) and map animation, which the earlier demos didn't have.
The tutorial code will not be submitted with the original source gfx but will use 'degraded' versions to avoid any grief - just enough to support the tutorials. The built preview uses the originals though so you can see how a polished version might look...
npomarede
Postby npomarede » Tue Apr 25, 2017 6:15 pm
Huge ! (although Xenon without music is not really Xenon :) )
dml
Postby dml » Tue Apr 25, 2017 6:18 pm
npomarede wrote:Huge ! (although Xenon without music is not really Xenon :) )
Agreed :)
Postby shoggoth » Tue Apr 25, 2017 8:52 pm
Stop this madness! Where's a proctologist when you need one!
viking272
Postby viking272 » Tue Apr 25, 2017 9:07 pm
This sounds amazing Doug, I knew there was a reason to buy an STE recently :)
CiH
Postby CiH » Tue Apr 25, 2017 10:49 pm
Well there's the Outline party coming up at the end of May if anyone wants to thrash something together quickly.
Alternatively, for those people with a bit more time on hand, the prospect of a new Sillyventure party is being floated for December :-)
Oh, and, awesome work Doug!
chlu600
Postby chlu600 » Wed Apr 26, 2017 6:38 am
Brilliant!
Ragstaff
Postby Ragstaff » Wed Apr 26, 2017 1:44 pm
This is such a fantastic tool. I seriously intend to have my first go at making an ST game using it.
An AGT comp category would be cool at Outline or Sillyventure? You might get some entries from new people - those of us who aren't hardcore sceners but who program on the PC or other platforms and never learnt how to bash the ST hardware in assembler. I would definitely aspire to a December deadline.... well, I'm going to play with the tool regardless, but perhaps a thought to encourage others?
dml
Postby dml » Wed Apr 26, 2017 2:08 pm
It would definitely be good news if some new projects got kicked off for compos etc. or even just as experiments.
I should also have said in the original post - all the source for the engine, demos/samples/tutorials and agt-specific tools are provided. There are no 'secret libraries', black-box .bin files or other magic sauce. I will share/comment the code for all the projects I make with it to help document it if nothing else. It can also be hacked around to extend features where needed (although as it improves the need for engine hacks/edits should diminish a bit).
The more complex demos are partly a form of documentation but also a way for me to determine what is still missing/incorrect/inconvenient and it helps guide improvements and effort spent in the right areas. It is also a useful way to find the bounary between generic engine features and things which are better coded inside the game itself. Some aspects of collision detection, game data import etc. falls in this area. All entity behaviour will be game-specific also. Still the demos provide some reference code for common cases which can be reused or adapted to suit.
Anyway I'll soon get this new demo tidied up and break it up into the next set of tutorials for the Wiki.
LaceySnr
Postby LaceySnr » Thu Apr 27, 2017 1:23 am
I've been meaning to post about this for ages, but I've started working on a platformer using AGT. Stalled a little recently but will try and get back into it over the next couple of weeks. It's going to be called Dave the Dragon :) Here's an out of date screenshot, might post a quick test build at some point (there's not much to do right now apart from jump around and shoot ineffective fireballs :roll: )
TheNameOfTheGame
Postby TheNameOfTheGame » Thu Apr 27, 2017 2:40 am
LaceySnr wrote:I've been meaning to post about this for ages, but I've started working on a platformer using AGT. Stalled a little recently but will try and get back into it over the next couple of weeks. It's going to be called Dave the Dragon :) Here's an out of date screenshot, might post a quick test build at some point (there's not much to do right now apart from jump around and shoot ineffective fireballs :roll: )
Sweet! Hope you continue to develop your game!
Ragstaff
Postby Ragstaff » Thu Apr 27, 2017 2:55 am
And here is the real reason I'm so bullish about having a play with the tool - I've got Matt to help sort out any issues I might have in person :-p
Can't wait to see Dave the Dragon continue to progress!
AtariCrypt
Postby AtariCrypt » Thu Apr 27, 2017 7:47 pm
Been following you for a while, this is looking superb!!
Return to “Coding”
