Space Slide Show...New Version 1.1
Upload your pictures or collections of pictures by famous Atari artists from around the world.
FedePede04
Postby FedePede04 » Thu Apr 13, 2017 8:07 pm
I have made a slide show program, and when i was making it i did a space slide show to test it.
https://demozoo.org/productions/170625/
slide show full version.
MM41
Re: Space Slide Show...
Postby MM41 » Fri Apr 14, 2017 8:22 pm
Nice Slide Show :D , thanks FedePede04 !
the slide run on Hataroid emulator but not on my real STe (with SatanDisk Hard drive),
it freeze after the first earth picture :( , the music and the scroll text are OK :) .
I'll try with a simple floppy to see.
FedePede04
Postby FedePede04 » Fri Apr 14, 2017 8:53 pm
Many thanks, and thanks for reporting, i know Ataricrypt have it running on a STE with a SataDisk,
maybe he can say if he do something special to make it run,
i know there have been some trouble if there are left overs of the long filename.
you could try removing the FONT.GFX or the SCTXT.TXT This should disable the open bottom border.
MM41 wrote:Nice Slide Show :D , thanks FedePede04 !
AtariCrypt
Postby AtariCrypt » Fri Apr 14, 2017 8:58 pm
Yes, it seems to work fine for me and my lovely STe. I did try on Hatari and the current upload Peter made works fine. (TOS 1.62 STe 4mb)
FedePede04
Postby FedePede04 » Fri Apr 14, 2017 9:06 pm
btw can you exit the program or does it hang?
you can try this prg file it is from the Collaboration Two slide show. i have been changing some stuff in the program.
removed attachment new version down the post
from witch hard disk does it run from? try running from C:\SPACE
MM41
Postby MM41 » Fri Apr 14, 2017 10:27 pm
nothing change, no slide show with my hard drive, my STe TOS 1.62 Fr 4mb SatanDisk 512mb
i must reset for exit.
The space slide run on floppy :D with the original file (may be my hd driver is too old :?)
FedePede04
Postby FedePede04 » Fri Apr 14, 2017 11:04 pm
sometimes it is hard to develop things that you don't self have the hardware, i am thinking of buying a ultrasata myself, would make a lot easier to test.
it can also be that i developer it in emulator, that always run optimal...
i will try to compare my new code with some old code to see if i have change much
FedePede04
Postby FedePede04 » Fri Apr 14, 2017 11:33 pm
I was thinking if you could test these 2 prg files on your HardDisk. just put the into your slideshow directory.
removed attachment new prg uploaded
FedePede04
Postby FedePede04 » Sat Apr 15, 2017 4:09 pm
MM41 wrote:nothing change, no slide show with my hard drive, my STe TOS 1.62 Fr 4mb SatanDisk 512mb
i think i know the reason why i did not work, your hard disk driver must use "Timer C"
and i had disabled it to remove flickering.
i think that i have found a very easy way to sync the "Timer C"
if my way work then this file should work ;)
Removed attachment
FedePede04
Postby FedePede04 » Sat Apr 15, 2017 4:37 pm
Hi MM41 i think this will be better if the other one don't work....
MM41
Postby MM41 » Sat Apr 15, 2017 5:00 pm
Very well!! the last SLIDE.PRG run from my hard drive without problem and i can return to desktop by pressing ESC.
Thanks FedePede04 !!
FedePede04
Postby FedePede04 » Sat Apr 15, 2017 5:09 pm
No it is me that say thanks for taking your time test it. Did the screen flicker?
MM41
Postby MM41 » Sat Apr 15, 2017 5:15 pm
No flicker with the last SLIDE.PRG
FedePede04
Postby FedePede04 » Sat Apr 15, 2017 5:21 pm
Many thx, look like my little sync trik is working :)
MM41
Postby MM41 » Sat Apr 15, 2017 5:54 pm
found a bug :
after pressing ESC and returned to desktop, i can't use mouse double clicks ?
I can select but no launching.
(the first timer c modified PRG don't have this problem but the screen flicker)
FedePede04
Postby FedePede04 » Sat Apr 15, 2017 6:03 pm
Ok thanks i will look into that
FedePede04
Postby FedePede04 » Sat Apr 15, 2017 6:08 pm
Ok Try this on
MM41
Postby MM41 » Sat Apr 15, 2017 6:34 pm
The music is more speed?
I run the slide then ESC : return to desktop and mouse key are OK.
I run the slide a new time: the screen flicker and no double clicks again.
FedePede04
Postby FedePede04 » Sat Apr 15, 2017 6:53 pm
MM41 wrote:The music is more speed?
it shall never be easy :cry: :cry: :cry: :cry: :cry: :cry:
FedePede04
Postby FedePede04 » Sat Apr 15, 2017 11:19 pm
Now i think it work "Timer C" is sync with the program.
MM41
Postby MM41 » Sun Apr 16, 2017 9:22 am
At any moment the slide freeze with wrong palette on picture, no scrolltext but music is playing.
When the slide run normally i can exit to desktop and try the demo again without trouble.
FedePede04
Postby FedePede04 » Sun Apr 16, 2017 9:24 am
MM41 wrote:At any moment the slide freeze with wrong palette on picture, no scrolltext but music is playing.
so the new version does not work at all?
FedePede04
Postby FedePede04 » Sun Apr 16, 2017 10:19 am
i think the program is close to work perfectly now, i think that it is just need to be fine tuned.
thanks again for your help.
if you have the time then you can try this one.
MM41
Postby MM41 » Sun Apr 16, 2017 11:48 am
freeze after push spacebar, no picture loaded and sometimes no music (reset to exit)
FedePede04
Postby FedePede04 » Sun Apr 16, 2017 11:51 am
Damn I think that I have to rethink this
Return to “Galleries”
cron
