SuperVidel and SvETHlana problems with CT60e
jvaltane
Re: SuperVidel and SvETHlana problems with CT60e
Postby jvaltane » Fri Jun 08, 2018 7:19 am
Galvez wrote:[You wrote this more than one year ago but if you still need to debug through the Falcon's serial port there is a guide in FreeMiNT's wiki:
https://github.com/freemint/freemint/wi ... erial-port
Thanks. At least I was not using hsmodem.
- jvaltane
stormy
Postby stormy » Fri Jun 08, 2018 12:10 pm
jvaltane wrote:
mzry wrote:I read somewhere on this forum that the clock filter should be disabled when using a ct60e because the ct60e does not have the same hardware issue of the original ct60, this was fixed in the 'e' revision. It might of been in the original ct60e thread.
If this is the case it might be good idea to update SuperVidels installation manual.
I found from original thread that ct60-bus has done better with ct60e. Might be related.
But supervidel is an old product, so the manual will be old. Willy is releasing a new supervidel soon, which probably won't even have a filter jumper.
fidzen
Postby fidzen » Fri Jun 08, 2018 4:12 pm
I use CT60e with Supervidel and Svethlana and have no issues.
Atari 2600 4-switch Woody
jvaltane
Postby jvaltane » Mon Jun 11, 2018 4:53 am
fidzen wrote:I use CT60e with Supervidel and Svethlana and have no issues.
Do you have ct60clock-filter-jumper in place with SuperVidel? What cpu-clockrate you use with CT60e? What core are you using with SV? Anything else about setup what could be worth of mention?
- jvaltane
jvaltane
Postby jvaltane » Mon Jun 11, 2018 5:08 am
Yesterday I used machine whole day without single reboot. Network and SV worked well. Transfer problems are gone after disabling ct60e-clockfilter and lowering cpus clock from 100Mhz to 75Mhz. As said SV works with 100Mhz, but svethlana not very stable.
Keyboard clicking problem was still there, but sv+svethlana combination worked very well. As someone before said this might related to shielding or something else. I think next I'll try with ST(e)s keyboard.
Also now when SV works better it might be good idea to test with other SV-cores also.
- jvaltane
Return to “SuperVidel”
