Help Compiling TOS 2.06/2.08/3.06 in any language
GFA, ASM, STOS, ...
ThorstenOtto
Re: Help Compiling TOS 2.06/2.08/3.06 in any language
Postby ThorstenOtto » Mon Mar 13, 2017 4:39 pm
troed wrote:Success!
My STE has now built an identical TOS 3.06 DE image from scratch
Nice ;) How long does it run there?
I used COMMAND.TOS as included in the archive.
Thats also an option. It's rather old though, and probably has still lots of bugs that i didn't have the time to fix yet. But you usually only need it to cd to some directory and run make.
Again, many thanks for all your work Thorsten :)
You're welcome :)
Thorsten
Postby troed » Mon Mar 13, 2017 4:57 pm
ThorstenOtto wrote:Nice ;) How long does it run there?
I didn't time it but I estimate around 2 hours. I'll do a make distclean and re-make later and check :) For fun I'll also let the Mega STE do it (both using USB flash memory as harddisk through alanh's Unicorn so it'll only be the pure CPU difference).
I think we have TTs and Milans in the thread as well so it'll be fun to compare ;)
/Troed
ThorstenOtto
Postby ThorstenOtto » Mon Mar 13, 2017 5:18 pm
troed wrote:I didn't time it but I estimate around 2 hours.
*gulp*
I usually use STonX, running on the hosts filesystem. There it takes ~1min.
With the last fixes, it also seems to run under MiNT now. With aranym-jit, it takes ~11 sec.
Postby ijor » Mon Mar 13, 2017 8:15 pm
troed wrote:I didn't time it but I estimate around 2 hours. I'll do a make distclean and re-make later and check :) For fun I'll also let the Mega STE do it (both using USB flash memory as harddisk through alanh's Unicorn so it'll only be the pure CPU difference).
You like to "train" your STs. :) Why not under emulation using native (not hosted) partitions?
Postby troed » Mon Mar 13, 2017 8:49 pm
Hey, they should be used for something besides just being on my desk ;)
Arne
Postby Arne » Wed Mar 15, 2017 4:26 pm
Could someone please upload the whole archive with patched AR68.TTP?
ThorstenOtto
Postby ThorstenOtto » Wed Mar 15, 2017 4:40 pm
Arne wrote:Could someone please upload the whole archive with patched AR68.TTP?
Sure. Same link as before. Did you make any progress?
bocke
Postby bocke » Wed Mar 15, 2017 6:09 pm
Sorry guys. Wrong topic. :)
Arne
Postby Arne » Wed Mar 15, 2017 6:49 pm
With your last archive I get this:
Postby troed » Wed Mar 15, 2017 6:54 pm
Arne wrote:With your last archive I get this:
FWIW, I had file not found issues with Mupfel but it worked fine with the included command.tos shell.
Postby joska » Wed Mar 15, 2017 7:44 pm
ijor wrote:Why not under emulation using native (not hosted) partitions?
Why, when you have the real thing?
Postby ijor » Wed Mar 15, 2017 9:22 pm
Well, in a case like this, just a test that takes hours on real hardware that can take minutes under emulation ...
Postby joska » Wed Mar 15, 2017 9:32 pm
Waiting is a part of the retro experience :)
Postby ijor » Wed Mar 15, 2017 10:27 pm
joska wrote:Waiting is a part of the retro experience :)
That's absolutely true :)
ThorstenOtto
Postby ThorstenOtto » Thu Mar 16, 2017 7:26 am
Looks like the same error you already got. Could you pls try "make -d", that should print the reason why make tries to rebuild mkbininc.ttp. You can also try to apply:
--- a/Makefile.cmn
+++ b/Makefile.cmn
@@ -48,10 +48,10 @@ MKDIR_P = $(MKDIR) -p
 SED   = ${BIN}sed
 BC    = ${BIN}bc
-CMP      = $(top_srcdir)/tools/cmprom$(BUILD_EXEEXT)
-MKGLUE   = $(top_srcdir)/tools/newglue$(BUILD_EXEEXT)
-MKBININC = $(top_srcdir)/tools/mkbininc$(BUILD_EXEEXT)
-MKROM    = $(top_srcdir)/tools/mkrom$(BUILD_EXEEXT)
+CMP      = $(top_srcdir)$(BS)tools$(BS)cmprom$(BUILD_EXEEXT)
+MKGLUE   = $(top_srcdir)$(BS)tools$(BS)newglue$(BUILD_EXEEXT)
+MKBININC = $(top_srcdir)$(BS)tools$(BS)mkbininc$(BUILD_EXEEXT)
+MKROM    = $(top_srcdir)$(BS)tools$(BS)mkrom$(BUILD_EXEEXT)
 # Wether to run the optimizer pass.
 # the default is evaluated by RUN_OPTIMIZE_,
to the toplevel Makefile.cmn.
Arne
Postby Arne » Thu Mar 16, 2017 11:42 am
ThorstenOtto wrote:Looks like the same error you already got. Could you pls try "make -d", that should print the reason why make tries to rebuild mkbininc.ttp.
Will do - in the evening.
ThorstenOtto wrote:You can also try to apply:
--- a/Makefile.cmn
+++ b/Makefile.cmn
 SED   = ${BIN}sed
 BC    = ${BIN}bc
That's some kind of diff syntax? What do I need to apply these TXT patches?
ThorstenOtto
Postby ThorstenOtto » Thu Mar 16, 2017 4:14 pm
Arne wrote:That's some kind of diff syntax? What do I need to apply these TXT patches?
Yes. You need the "patch" utility to apply that automatically. I think i got mine from http://sparemint.org/sparemint/RPMS/m68 ... 8kmint.rpm but thats a rpm package, you might have difficulties to extract that on single-tos ;) You can also just replace "/" by "$(BS)" with a texteditor in those 4 lines.
Arne
Postby Arne » Fri Mar 17, 2017 9:45 am
We've got a winner!
So the problem on my TT was its drained battery i.e. the .C file was always newer than the compiled/linked .TTP.
Thanks Thorsten!
ThorstenOtto
Postby ThorstenOtto » Fri Mar 17, 2017 3:51 pm
Arne wrote:We've got a winner!
nice ;)
Oh yes. Make doesn't work very well without correct timestamps ;)
Postby mikro » Sat Mar 18, 2017 1:53 am
Couldn't resist to try this out. I confirm it works and there's even no need for that mv.ttp and sed.ttp, works literally out of the box.
troed wrote:Replicated with Hatari on my Mac, just now. These are the steps I needed when starting completely from scratch:
1) Download the tos-archive from this thread, unpack as "tos" in your gemdos-root folder. Delete all GNUmakefile-files.
1.5) Open Makefile.common, find the line which redirects to NUL: and remove the redirect.
2) Download mupfel and mupfel-tools. Run the self-extracting mupfel tools archive so you get a bin-folder
3) Copy sed.ttp and mv.ttp from crashman's linked BIN-catalogue into your own mupfel-tools bin.
4) Boot Hatari. I used TOS 1.04. Map your root folder as GEMDOS drive.
5) Run mupfel.ttp
6) Type PATH="\bin;\tos\bin" - important, backslash, not slash
7) Type cd tos
8) Type make
... fast-forward in Hatari, this will take some time. Resulting TOS image tested working in Hatari.
Thanks @ThorstenOtto!!!
/Troed
ThorstenOtto
Postby ThorstenOtto » Sat Mar 18, 2017 9:31 am
mikro wrote:Couldn't resist to try this out. I confirm it works
Thanks for the info :)
mv is not needed because make uses a builtin version if it is the first command, and does not use any options it does not handle, like -b or -i. For any options that are unknown, or not handled, the external command would be invoked. sed is still needed if you want to recompile the compiler.
Arne
Postby Arne » Wed Mar 22, 2017 5:51 pm
I finally found a RAM-Disk that can allocate Alt. RAM and checked the turn-around time: 34min. on a TT.
Postby mikro » Wed Mar 22, 2017 10:39 pm
Will be fun to compare on CT60. ;-) Can you post the ram disk app?
ThorstenOtto
Postby ThorstenOtto » Thu Mar 23, 2017 8:42 am
Arne wrote:I finally found a RAM-Disk that can allocate Alt. RAM and checked the turn-around time: 34min. on a TT.
That sounds better than 2h ;) Did you put everything there, including sources, or only the temporary files? And what ramdisk was that? Maybe i can add a hint to it in the README next time.
Arne
Postby Arne » Thu Mar 23, 2017 12:58 pm
ThorstenOtto wrote:Did you put everything there, including sources, or only the temporary files?
Everything except compiler-sources. 9-10 MB IIRC Copying done with Kobold in < 1min.
ThorstenOtto wrote:And what ramdisk was that?
http://archive.3rz.org/MAUS-OEPT/FR/st/TRUEDI22.LZH
Set it to 16MB, Mxalloc PrgFlags were already set to AltRAM.
Return to “Coding”
