Cosmos EX internally operated - using the Molex floppy power cable
dbsys
Postby dbsys » Tue Feb 07, 2017 8:34 pm
I would like to operate my Cosmos EX internally and power it using the Molex connector from the floppy drive.
How do I deal with the +12 volts on the yellow cable? Do I have to disconnect the yellow cable before attaching it to the Cosmos EX power connector?
Thanks for advise.
Estrayk
Re: Cosmos EX internally operated - using the Molex floppy power cable
Postby Estrayk » Tue Feb 07, 2017 10:00 pm
In this spanish blog seems he connect directly. Use google translator if you want.
http://arananet-net.kinja.com/instalaci ... 1791969553
Postby mikro » Tue Feb 07, 2017 10:13 pm
No, you can use the internal floppy power cable as is. No cutting needed.
dbsys
Postby dbsys » Sat Feb 11, 2017 5:49 pm
mikro wrote:No, you can use the internal floppy power cable as is. No cutting needed.
Thank you!
So, Cosmos EX will simply ignore the +12 volts on the connector?
I just do not want to blow it...
Jookie
Postby Jookie » Wed Apr 26, 2017 8:34 am
dbsys wrote:So, Cosmos EX will simply ignore the +12 volts on the connector?
Yeah, it ignores the +12V line - it's not connected in CosmosEx...
Jookie
Return to “CosmosEx”
