NEW OR UPDATED ARCADE CORES
Darfpga
Re: NEW OR UPDATED ARCADE CORES
Postby Darfpga » Wed Dec 27, 2017 11:00 am
Lunch time approaching!
Burger Time VHDL arcade game source code for DE10_lite available here :
https://sourceforge.net/projects/darfpga/files/Software%20VHDL/burger_time
Feel free to port to MiST/MiSTer.
NML32
Postby NML32 » Wed Dec 27, 2017 11:04 am
:cheers: thanks, I really like Burger Time. :D
Gehstock
Postby Gehstock » Wed Dec 27, 2017 12:56 pm
Thank you verry Much
:D
Sound+RGB not testet need Feedback
https://github.com/Gehstock/Mist_FPGA/t ... ter/Arcade
DanyPPC
Postby DanyPPC » Wed Dec 27, 2017 1:47 pm
Perfect !
Thanks to all :cheers:
DrOG
Postby DrOG » Wed Dec 27, 2017 3:46 pm
Gehstock wrote:Thank you verry Much
:D
Can test tomorrow early in the morning...
hyperterminal
Postby hyperterminal » Wed Dec 27, 2017 6:51 pm
Thank you for the Burger Time core. Graphics and sound work as expected and the image is perfectly aligned at 15 kHz.
DrOG
Postby DrOG » Thu Dec 28, 2017 6:17 am
hyperterminal wrote:Thank you for the Burger Time core. Graphics and sound work as expected and the image is perfectly aligned at 15 kHz.
I can confirm, very nice work!!! :cheers:
Gehstock
Postby Gehstock » Thu Dec 28, 2017 9:42 am
OK thanks for feedback
Postby Sorgelig » Fri Dec 29, 2017 7:27 pm
Darfpga wrote:Burnin' rubber FPGA arcade game for DE10_lite available here :
https://sourceforge.net/projects/darfpga/files/Software%20VHDL/burnin_rubber/
As usual feel free to port to MiST/MiSTer.
It seems 2-player mode is broken. After first try on player-1, it switches to player-2 and never switch back to player-1 till the end of game.
Darfpga
Postby Darfpga » Sat Dec 30, 2017 8:50 pm
Can you describe more: what is wrong ? The display in cocktail mode ? The control button or the number of the player who control the game?
Postby Sorgelig » Sun Dec 31, 2017 7:50 am
Darfpga wrote:Can you describe more: what is wrong ? The display in cocktail mode ? The control button or the number of the player who control the game?
I've changed to non-cocktail mode, 5 lives. So, both players have same screen rotation.
- start the game in 2 player mode
- game played for P1 and switch to P2 upon life lost
- game played for player P2 but remained on P2 upon life lost.
- remains on P2 till all life used where each life used twice.
I see in new core you start to use such constructions:
   if rising_edge(clock_12) and clock_6 = '1' then
   end if;
Which is not correct since clock_6 goes to sensitivity list and can act as a clock while it shouldn't. The correct construction should be
   if rising_edge(clock_12) then
      if clock_6 = '1' then
      end if;
   end if;
May be this affects the core work?
Darfpga
Postby Darfpga » Sun Dec 31, 2017 2:41 pm
Sorgelig wrote:- start the game in 2 player mode
I've just tested this config : no problem here, toggle player1/player2 is ok after each life lost for each 5 lives.
Sorgelig wrote:I see in new core you start to use such constructions:
   end if;
      end if;
   end if;
Thanks for the feedback, I agree the construction isn't good and at least ambiguous and maybe handled differently by different compilers. I must correct this and avoid it in future. I've checked with RTL viewer that clock_6 signal always ends on ENA pin of DFF registers and clock_12 on CLK pin of DFF. Fortunatly compilation complains about clock_6 not being in sensitivity list and clock_6 is never promoted to a clock signal.
Anyway you are absolutely right, thanks again.
Nevertheless I cannot reproduce the problem here so I cannot find a solution. I hope that you are not misleaded by the fact there is no 1UP/2UP blinking and sometime no PLAYERx GET READY screen after the first one. It is the same on Mame, only scores counter increase make the difference between player1 and player2.
Postby Sorgelig » Sun Dec 31, 2017 3:26 pm
Darfpga wrote:I hope that you are not misleaded by the fact there is no 1UP/2UP blinking and sometime no PLAYERx GET READY screen after the first one. It is the same on Mame, only scores counter increase make the difference between player1 and player2.
ah, you are right. I didn't notice it switches between players seamlessly.
Gehstock
Postby Gehstock » Wed Jan 03, 2018 9:41 am
New Core
War of the Bugs
But Same Problem with Fonts like all Galaxian HW Cores
Download on my Github
Postby Sorgelig » Wed Jan 03, 2018 12:52 pm
looks like centipede
Gehstock
Postby Gehstock » Wed Jan 03, 2018 1:02 pm
Yeah, Mist have not yet a Centipede Core
DrOG
Postby DrOG » Wed Jan 03, 2018 1:20 pm
Gehstock wrote:New Core
War of the Bugs
Nice! Will test tomorrow morning!
Postby Sorgelig » Wed Jan 03, 2018 1:37 pm
Gehstock wrote:Yeah, Mist have not yet a Centipede Core
MiSTer too :)
What's the problem with Font?
Gehstock
Postby Gehstock » Wed Jan 03, 2018 1:54 pm
viewtopic.php?f=115&t=31112&start=325#p334834
the First picture is VGA Output , Font lacks of the first Pixel Line. RGB is ok(second Picture)
Postby Sorgelig » Wed Jan 03, 2018 2:04 pm
Gehstock wrote:http://www.atari-forum.com/viewtopic.php?f=115&t=31112&start=325#p334834
scandoubler eats first pixel. If it's hard to adjust scandoubler, then you can deactivate hblank in the core one pixel earlier.
Gehstock
Postby Gehstock » Wed Jan 03, 2018 2:06 pm
Ok Thanks will Check
Postby Sorgelig » Wed Jan 03, 2018 2:10 pm
Or, add intermediate registers for RGB data assigned by pixel clock. And it will shift the whole picture one pixel to the right.
You need to do this before scandoubler.
somethig like:
reg [..] Rd,Gd,Bd
always @(posedge pixclk) begin
   {Rd,Gd,Bd} <= {R,G,B};
end
Rd,Gd,Bd -> send to scandoubler.
Gehstock
Postby Gehstock » Wed Jan 03, 2018 2:20 pm
Thank you
Gehstock
Postby Gehstock » Wed Jan 03, 2018 10:54 pm
Sligthly better Fonts on Galaxian HW Cores and Gameboy Update
DrOG
Postby DrOG » Thu Jan 04, 2018 5:54 am
Hi!
Tested the War of Bugs and Azurian core briefly, still odd-looking, but better over VGA (see attachments).
